Hp laptop issue with power light blinking not on steadily. As should be when charging. Laptop will not boot up. New power/charger has same issue. Constant broken cord repair, so went with new charger after old unit repaired and light started blinking.
    Scholar:
  • 136 Answers
Maybe you need a new battery. See if it happens when you remove the battery and run on AC power.
Posted on Oct 26, 2008
No Power on Hp 620 Laptop
If the battery does not charge then the problem is likely the charger.
If you can borrow a charger instead of buying a new one you can find out for sure if the problem is the inside the laptop its self or the charger.
Remove the battery and hold down the standby button for a whole minute to drain any remaining power in the model. replace the battery , attach the new/borrowed charger lead and see if any activity happens ie, sound, lights...ect. This is the first thing someone does in a repair shop and its to diagnose where the issue is comming from.
Feb 21, 2014 | HP Computers & Internet
My Pavilion g6-1b79dx notebook will not charge even with a new battery and charger. The light indicating the charger is plugged in is blinking white
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/replacement-hp-pavilion-g6-ac-adapter-19v-90w.html
Dec 09, 2012 | Plantronics Hp - Pavilion G6-1B79Dx Laptop...
HP lap top Charger light blinks six times?
if it's a new laptop it could indicate that the battery needs to charge for 30 minutes before use. if it's not a new laptop it could mean that the bios configuration is corrupt. if that's the case go to the hp support website and download the latest bios update and reflash your bios.
Jul 02, 2012 | HP EliteBook 8530p Notebook
Blinking blue and orange light when trying to charge
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
May 17, 2012 | Packard Bell Computers & Internet
I have a compaq presario cq61 and have been having problems with the charger for quite a while but money is an issue so cannot get a new one just yet, the laptop has 2 lights to aknowledge that the...
YOUR PACK IS NO GOOD
IT MUST RUN WITH NO BATTERY
PACK CONNECTED
SINCE IT DONT THEN THE CHARGE IS WEAK TOO.
YOU KNOW PACKS CAN BE
GOOD
BAD
OR WEAK, OR EVEN ON FIRE, (loL)
Mar 01, 2017 | HP Compaq Presario CQ61420us Notebook
Plug in charger for laptop hp g60, but not charging. How can I find it works?
Try charging the laptop without the battery. If it does not work, Check the port of the charger if it blinks any light. If it doesn't, then I guess you would have to get a new charger. If it still does not work, then the power pack should be examined by an expert.
Sep 20, 2010 | HP G60-230US Notebook
With the zd8210ca off with power cord plugged into laptop also battery is in laptop. Battery light on front panel is blinking. With laptop booted up battery condition show charging at 0%. Does any one have...
Take out the battery and try running it on the power adaptor alone. If this works, you have a dead battery. If not there's something more serious wrong in the machine.
Apr 14, 2010 | HP Pavilion zd8000 Notebook
Laptop not booting up and nothing showing up on the screen
What leds you can see blinking on laptop? Can you hear any bootup sounds? Sometimes my laptop hangs on standby or hibernat, then screen is black and some leds may blink. Usually i need to take charger and battery off for 10 seconds and boot up again. If that dont help then there must be some hardware damage.
Jan 27, 2009 | HP Pavilion FE849UA Notebook
HP Pavillion power link blinks
aa505 -
I can almost guarantee you this is an issue with the power jack on the laptop's motherboard. Even though it may not appear to be loose, its most likely the solder connection on the motherboard has broken, only allowing intermittent connection when the laptop is in /just/ the right position.
It'd be best to get this looked at sooner rather than later, preferrably if the computer is still under warranty. The connection will steadily decline, until the laptop is unusable.
Otherwise, let me know if you want to get rid of the system! I have a system, almost exactly the same model, that I need parts for!
Hope this helps!
-thinstatic
Jun 12, 2008 | HP Pavilion dv1000 Notebook
Does not turn on
if your laptop not charging better change the ac adaptor to charge but if your laptop not booting but the charger charge the the laptop the problem is you motherboard just try to reset you CMOS then try to boot again
Apr 06, 2008 | Acer Aspire 1690 Notebook
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
