Question about Texas Instruments TI-30XA Calculator
How do I multiply 1.04 to the 20th?
I don't know how to multiply exponents to more than the 5th power
SOURCE: exponent key
On the Upper right corner, below the OFF button.
Key in the number, press that YtotheX key, and input the integer. Press =. That is your answer.
Posted on Mar 05, 2009
  • 8064 Answers
SOURCE: i don't know how to multiply by a negative
Press [2nd][,] to activate (EE) which appears on screen as a lower case E, enter the change sign (-) right of the [dot] on the bottom row of keys, enter the value of the exponent.
Ex: Enter Avogadro's number of Generalk Chemistry fame
6.02[SHIFT][,] (EE) (-)23
Here is screen capture of what it will look like.
Posted on Feb 27, 2010
  • 102366 Answers
SOURCE: imy TI-83 plus calculator won't
Having gone over a month without a response to my query, I assume it was simply a matter of using (-) instead of -.
Posted on Oct 15, 2010
  • 102366 Answers
SOURCE: how do i multiply 1.04 to the 5th power using the
To raise 1.04 to the fifth power, press
1 . 0 4 y^x 5 =
y^x is the key just above the divide key.
Posted on Feb 20, 2011
  • 102366 Answers
SOURCE: don't have user manual. How do I key in
http://education.ti.com/educationportal/sites/US/productDetail/us_ti30xa.html?bid=6
Posted on Feb 25, 2011
What is most common power problem?
If by power, you mean exponents, there are several rules.
Multiplication with the same base - add the exponents
Division with the same base - subtract the exponents
Exponent to an exponent - multiply the exponents
Negative exponent - 1 over the same number to the positive exponent
Zero exponent - anything to the exponent 0 is 1
Good luck,
Paul
Jan 26, 2016 | Casio ClassPad 300 Calculator
How do you simplify the exponent on the calculator?
I assume 13m/2 is the radius of the sphere and you are trying to calculate the volume of the sphere.
The first thing we have to think of is BEDMAS, the order of operations, as some calculators do them correctly, while others do not. Let's be safe and do the BEDMAS manually so we know we will get the correct answer.
B - brackets - enter 13/2 in the calculator - hit enter
E - exponents - with the answer from the first line in the calculator, use the hat key (^) or the y to the x key to raise this to the third power (exponent 3).
M - multiply - with the answer from the line above, multiply this by pi or use what you are instructed to use or use 3.14159, then multiply by 4 and divide by 3.
You should have your answer.
Good luck.
Paul
Jul 12, 2015 | Office Equipment & Supplies
What is the answer to to this (x^5)^3(x^3)^4
We have to follow BEDMAS, the order of operations, where brackets are first, then exponents, followed by division and multiplication, and finally addition and subtraction.
Also, we have to use the exponent law of an exponent to an exponent, we multiply the exponents with the same base.
If we forget this, we can always do it the long way.
(x^5)^3 = (x^5)(x^5)(x^5) = x^15
Similarly, (x^3)^4= (x^3)(x^3)(x^3)(x^3) = x ^12
Now that we have done the exponents, we can multiply x^15 by x^12 and get x^27.
Good luck.
Paul
Oct 05, 2014 | Office Equipment & Supplies
Just got a SHARP EL-531X, it won't do simple calculations with scientific notation, It keep saying
To enter the power of 10 with exponent use the Exp key followed by the exponent. If the exponent is negative, you must use the negation key (-) not the - key (for subtraction).
When you press the Exp key you do not type in the 10.
Mar 10, 2012 | Sharp Office Equipment & Supplies
I am trying to multiply in scientific notation but I don't how to do it when the power of 10 is a negative i.e 1.67 time 10 to the 21st power multiplied by 9.11 times 10 to the -31 power. thank you
Make sure you use the +/- key just to the right of the decimal point key when entering negative values, including exponents.
1 . 6 7 EE 2 1 * 9 . 1 1 EE +/- 3 1 =
Aug 30, 2011 | Texas Instruments TI-30XA Calculator
I don't know how to multiply by a negative exponent. ex: 10(-8) ....the -8 is the exponent.
Feb 23, 2010 | Texas Instruments TI-83 Plus Calculator
How do I add Exponents on my T1-30xa calculater
There is a rule of Algebra, that says
(a^m)[x] (a^n) = a^(m+n)
a is the base of the power, n, and m are the exponents. As you can see, multiplying two powers of the same base is equal to the power of the (common) base with the sum of the exponents.
If that is what you had in mind, the calculator uses the rule correctly and no intervention from you is necessary.
If you enter (2^4)[x](2^6), the calculator will give 1024, which is 2^10.
I may be wrong, but what you call add exponents refers really to performing addition where addends (the terms you add) are arbitrary powers, such as
2^7 + (5.5^3) - (1/3)^4
Once you enter a power term, the calculator calculates it and the result is now just a number. It can be added, subtracted, multiplied
For the exemple above
2 [Y to the x] 7 + (5.5)[Y to the x] 3 -(1/3) [Y to the x] 4 [=] yields 294.3626543
For the cube of 5.5 you can use the key combination [2nd][X^3]
Hope it helps.
Oct 08, 2009 | Texas Instruments TI-30 XIIS Calculator
Multiplying exponential numbers
I am needing to find out what key I can push for an exponent. I have an exponent that is 2520 and I dont know what button to push for it.
The problem is as follows:
3000 ( 1+ 0.06/360) exp.2520
3000 ( 1.000166667) exp. 2520
3000 - 4565.72
Final Answer
1565.72
Now how in the world did they get 4565.72. What buttons am I needing to push.
Mar 12, 2009 | Texas Instruments TI-83 Plus Calculator
EE button ("enter exponent" button) Retuns Wrong Value
I dont think you got a lemon.
You acn always enter the powers of 10 as 10, [y^x], but is is less efficient than the EE key
This EE representation is a shortcut.
If you want 10 to the 5th power you just enter [2nd] [EE] 5 and the calculator displays 100000. Of course if you need any other number multiplying the power of ten you enter the following e.g. 2.677[x][2nd][EE]5.
You will not get any error with a positive exponent. But if your exponent is negative you should use the change signe key to the left of ENTER and symbolized by (-)
To avoid all errors I would use parentheses to enclose my exponent.
Here is how to explain the seemingly erroneous result
10 [EE] 5 ) (-) is interpreted by your calculator as 10x(10^(-5)) which evaluates correctly to 0.0001 because [EE] by itself stands for 10^ .
Hope it clarifies this point for you.
By the way some new calculators (Casio) don't have this EE key. Instead you find a key labeled x10^X .
Hope it helps
Mar 12, 2009 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Logo
209 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
