Question about Fanner 3.5" SATA HD Internal Mobile Rack 4 drivers module MRA500 SATA Hard Drive
Blue screen,tech formated sata,vista does not recognize drive to load
Gateway mt6828 laptop, I cannot format and partition and install system files, I have windows vista 32 bit disk for new install,I can put in disk and it loads and then asks for drivers,downloaded from gateway driver for sata drive and it will accept one, but then says it is necessary a updated version which is not on the gateway site,I tried to reformat and it will not let me, I would prefer to install xp instead of vista, but when I tried to load it does not recognize the drive also and has the same problem,Please help if you can.
thank you Dennis!
  • dextra1 Dec 05, 2008
    I try installing windows XP Service Pack 2 on my toshiba labtop that was running Vista and after the setup files have copy this message came on screen "Setup did not found any hard drive on you computer press f3 to quit", later i came on the internet let and got some sata raid controller driver which I was told to place it on the root diretory of the floppy disk, I did just that, and I try installing again, during the installation I press f6 when windows XP setup files was loading. Some iaStor.sys file was load and I could see the Hard drive but when I setup windows XP the the Partition selected it says "set up found iastor.sys on the cd.
    Problem Solver:
  • 14 Answers
Almost ever new system that requires a sata driver actually requires a controller driver. most new systems will also boot from USB. so if you have no floppy drive simply copy the files to a usb.
you can get the sata drivers from Maxtor or ATI. they are all the same... just make sure you get the XP or Vista drivers and 32b or 64b.
If you can not find you can email and ask me I can zip and email to you.
Posted on Dec 11, 2008
  • 2,427 Answers
Hey !!! ok follow these steps
1.) download the SATA driver for windows XP from the manufactures web site
2.) download a program called nLITE ITS A UNATTEND SETUP UTILITY
3.) run the program and it will ask for the windows disk, insert it and then select the drive and destination..
4.) It will copy all the windows files to your hardrive and then select all the options
5.) It will ask you to slimstream any driver select yes
6.) select the location of the drivers you downloaded (UNZIPPED)
7.) it will add the drivers to the windows instillation and then offer you to burn it off select yes
8.) use the newly burnt copy of windows to format and install on your laptop :)
Posted on Oct 26, 2008
Blue 500 GB not recognized by Sony Vaio laptop
Hello, Assuming the drive works and the laptop's usb port is good then the problem could reside in a couple of areas.. 1. The file system of the Blue hard drive may not be recognized by windows on your Vaio, this is most likely due to the fact its was formatted with a Mac (and therefore probably using HFS). If this is the case and you need to read the contents of the disk then you can install mediafour's macdrive ( this will allow your vaio to read the mac disk. It is free for 5-days so if you just need to access some files you can do this at no cost. 2. The drive may not have been partitioned and formatted yet, in which case for windows XP follow this microsoft guide and for windows 7 follow this
Hope this helps
May 04, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
I have partitioned my C drive and now have a 2nd
On the setup you need to select the xp partition if its not visible you will need to load additional SATA drivers when the setup asks you to
Mar 21, 2009 | Computers & Internet
How to replace the Hard Drive?
1. First, back up your critical files (don't forget your Outlook .PST archive) to optical discs, an external drive, or online storage.
2. Examine data and power connections (SATA or IDE, depending on the drive), a power adapter cable (with some SATA drives), and screws.
116hdrive2a.jpg116hdrive2b.jpg 3. Mount and connect the drive
When installing SATA drives, jumper settings usually aren't an issue. That's not true of IDE, where a jumper indicates whether a drive is a primary ("master") or secondary ("slave") drive. Check its documentation for the proper setting
4. Configure the BIOS, Next, boot into your PC's BIOS-setup utility to verify that it recognizes the new drive and positions it correctly in the drive hierarchy. (Check your PC's startup screen to determine which key launches the utility.) If the utility lets you select the boot order, give your intended boot drive priority over any other hard drive
Save changes and exit the utility. Your PC will reboot
5. Partition and format your hard drive, Click Start > Control Panel > Administrative Tools > Computer Management, and choose Disk Management from the tree at left. Your new drive should appear, with a black bar indicating it isn't partitioned. Right-click the bar, and choose New Partition to launch the New Partition wizard. Click Next, and check that Primary Partition is selected; click Next again, to the Specify Partition Size screen (don't change the partition size in the "Partition size in MB" field); and click Next to advance to another screen, on which "Assign the following drive letter" should be selected. Click Next yet again (to the Format Partition screen), and ensure that "Format this partition with the following settings" is selected and that the "File system" drop-down reads "NTFS." Click Next a final time, hit Finish, and formatting begins.
Good Luck Delgado...
Feb 15, 2011 | Computers & Internet
XP, Vista and Win7 recognize this HDD as an external HDD but I can not see it in Windows Explorer.It shows up in the bar(down right) as external HDD is connected.HDD= WD Scorpio Blue(1 TB). Model=...
You'll need to check and see if the disk is formatted and recognized as a logical disk. To do this, Go to Start, and locate the Run option, and type in diskmgmt.msc or you can go to My Computer, right-click it and select "Manage" from the popup menu. Then, at the bottom of the list to the left, you'll see the Disk Management submenu.
Once you're in the Disk Management applet, click on the WD from the list of available hard drives from the list, and see if the partition is recognized as formated. If it's not formated you may need to format it. If the disk is recognized as RAW disk, then you'll need to first create an extended partition and then format it with NTFS file system. REMEMBER, if you can access the drive from another computer and it's recognized properly in Explorer, then formating it will erase all data on the disk. But if you never used it before (i.e you dont have any data on it) then you can go ahead with the formatting, which should solve your problem if it's a software issue.
If you heard your disk clicking for a while in the past, and you had problems with it: slow reading of files, sluggish in copying files etc. then your hard drive may be mechanically failing and in this case there's nothing you can do to save it. If this is the case and you still have warranty, return the disk to where you bought it from, and ask for a replacement.
If this was informative and helpful please vote with a Thumb Up. Thank you.
Feb 01, 2011 | Western Digital WD Scorpio Blue WD10TPVT -...
Hi..i have HP pavilion dv5 laptop with preloaded Windows Vista. i want to istall windows xp instead of vista. i tried installing it using xp bootable disc. but after loading the required installation files...
its very simple....
enter the bios setting...The BIOS settings menu is accessible by pressing the f2 or f10 or the f6 key on some computers.
if the BIOS provides an option to disable the native-SATA configuration in the BIOS, do the following steps to Disable the native-SATA in the BIOS
1. Use the cursor to navigate the Configuration options to locate the Native-SATA setting. 2. If there is a SATA setting, select the Disable option, and then press F10 to save the change and restart the computer.
if your system bios does not contain such option.... then find "Native SATA mode" or "SATA IDE"
then change "AHCI" to "ATA"
Jan 16, 2011 | Computers & Internet
Stop:0x0000007B tried to boot in all modes..we go to blue screen with stop: cannot get a command prompt either
Issue : Blue screen with Error0x0000007B
I recognize the importance of resolving this issue and I look forward in providing you with the necessary assistance you need.
The above error comes if the boot volume is corrupted and cannot be initiated by Windows XP. or You are installing Windows XP on a mirrored boot partition that was created by Microsoft Windows NT 4.0.
To completely resolve your issue i think you have to reinstall the OS.
Have to format the Hard drive
the OS - XP Home / Premium Installation CD
Disk formatting is the initial part of the process for preparing a hard disk or other storage medium for its first use. The disk formatting includes setting up an empty file system. A disk formatting may setup multiple file systems by formatting partitions for each file system.
Check this following Video Link
Help you with uninstall and reinstall the XP
Jan 03, 2010 | Dell Microsoft Windows XP Home Edition
I have a Gateway MT6728 . I hate Vista on it and wanting to run Windows XP Pro because it less memory user than vista. When I downloaded the SATA Driver for the hard-drive . I made a floppy disk to boot...
Do you see the FDD been read after the F6 key?
Do not go with the quick formatting option.
Try without partitioning the driver and proceed with the installation.
Let me know
Jul 20, 2009 | Gateway Computers & Internet
I have a new hard drive and no operating system for my laptop
well you donot need special programs you can use the same operating system to format, partition and load your operating system, after you connect your harddrive to your board go to setup Bios and look for the hardware that installed on your chip and you will see if your hardrive is recognized, After that load your operating system cd on your dvd rom and let the pc boot to that dvd drive, here the you will start loading the operating system, so you have to format, partition and then install windows, Try windows vista will make it easy for you.
Best Regards
Feb 28, 2009 | Dell Latitude D600 Notebook
Failed vista uninstall
do install the vista only, coz xp could not recognize the sata hd, it gives the blue screen error, if u want to install xp otherwise, install sata divers from the supplied disk with computer.
Nov 21, 2008 | Acer Aspire 5920-6727 Notebook
Fanner 3.5" SATA HD Internal Mobile Rack 4 drivers module MRA500 SATA Hard Drive Logo
296 people viewed this question
Top Fanner Computers & Internet Experts
Nathaniel Berrios
Nathaniel Berrios
Dilum Senarath
Dilum Senarath
Are you a Fanner Computer and Internet Expert? Answer questions, earn points and help others
