Question about Watches
How do you set chimmies on ansonia mantel clock
4 Suggested Answers
  • 15 Answers
SOURCE: I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMIN
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
Posted on May 10, 2010
  • 5 Answers
SOURCE: Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
Posted on Jun 05, 2010
reyjoshua07
  • 1157 Answers
SOURCE: i need to know how
Hi ajhazel1,
Please follow the steps below on how to set the alarm on your seth thomas mantel pendulum clock.
1. Determine if your Seth Thomas mantel clock is a 7-day clock or an 8-day clock. On most models it will say right on the face of the clock which type it is. Seven-day clocks must be wound every 7 days, and 8-day clocks must be wound every 8 days. If you are unsure you should wind your clock every seven days.
2. Look on the back of the clock. You will see three large holes (just large enough for the clock winding key to fit into) plus one or two smaller holes (often just large enough for the small end of the key to fit into). The two smaller holes are for speeding up or slowing down the clock and for turning the chimes off and on. The three larger holes are the ones we are interested in--they are the ones we will need to wind every 7 or 8 days. On some models the three winding holes are on the front of the clock. Winding instructions are the same, regardless of where the winding holes are located.
3. Push the large end of your clock winding key gently into the hole on the right as you look at the back of the clock. This hole allows you to wind the 15-minute chimes. Gently turn the key clockwise. Keep turning it until you feel resistance and the key stops turning. Remove the key.
4. Insert the large end of your key gently into the center hole. This hole allow you to wind the main clock mechanism, which allows the clock to run and to keep time. Turn the key clockwise firmly but gently until you feel resistance. When the key no longer wants to turn simply remove it.
5. Insert the large end of the key into the hole on the left. This winds the hour chimes. Turn the key clockwise firmly but gently until you meet with resistance. When the key no longer turns easily remove it and place your clock back on your mantel. Your clock is now set to run for 7 or 8 days, depending on the model you own.
6. Use your hand to start the pendulum swinging once the Seth Thomas mantel clock has been set to the right time. The pendulum should be located in the back of the clock. The clock will not keep time if the pendulum is not moving.
Hope it helps.
Thank you for using FixYa.
Posted on Aug 24, 2011
Bulova mantel clock won't keep time
Sounds like a broken escapement, definitely a job for a horrologist (watchmaker)
Sep 29, 2013 | Watches
Bulova mantel clock won't keep time. New batteries and will chime. It's about 25 years old at least.
Try CAREFULLY cleaning the mechanism with naphtha lighter fluid. Lighter fluid is high grade naphtha. Be careful not to allow it to run on to the face and electronics. It may damage the face with stain or remove any decals or cemented numerals. It may only take a small amount to clean the shaft bearings. The lighter fluid cleans and lubricates without leaving a film. If you can, while the fluid is on the gears, manually turn the clock forward 12 hours. That will rotate all the gears fully. Us the fluid sparingly!
Apr 14, 2011 | Bulova Watches
I have a 1976 hamilton mantel clock. It has a + and- on the back to set the time. i need to advance the time but am not sure where the adjustments are. Can u help me out.
mcdevito75 here, There nshould be some sort of lever or knob, very close to that a+ and minus- Best bet visit a small watch repair shop in your area, try to draw a sketch of the back of the clock, meanwhlie look on the clock for this lever, it may look like a half moon slot with a lever just in side this half moon slot. Hope this helps.
Jul 01, 2010 | Watches
The clock runs fast , 20 plus minutes a day... Is there an adjustment and or how do I deal with this problem? Mantel 8 day clock. Thanks Ron
mcdevito75 here, There should be a F/S on the back of the clock, if so place it in the middle, if not, check out a small watcg repair shop in your area.
Jun 26, 2010 | Bulova Hyannis Desk Clock With Engraving...
Need manuel fo operation and set up
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CITIZEN watch/CLOCK manuals.Rate me, please
Mar 15, 2010 | Seiko Mantel Clock With automatic world...
The pendulum stopped swinging...the clock and chimes work well
Hi
This clock short of needing a full service may simply be out of beat.
Taken from my web page located at:
http://antiqueclock.clockstop.com/CLOCK_BEAT.htm
"HOW TO PUT YOUR CLOCK IN BEAT"
-Included below is a 10-second sound <snip> of a clock both in and out of beat.
IN BEAT ////////\\\\ OUT OF BEAT
· Turn on your sound and click on the clocks above for a sound clip.
-One little known fact is that a clock does not have to be level to be in beat. I had a customer that had a mantel clock in an old farm house, it was brought in for repairs and sent back running great just one problem: I put the clock in beat on a level surface [a small problem] because the mantel it had set on for it's entire life was not level. I had to literally go to the house to put it in beat where it sat.
-I have often found most Grandfather or floor clocks are set up out of level and put in beat where they stand, This is fine.
-As I'm sure we now realize a clock must be in beat but not always level to function properly.
· Above is the verge with a slip clutch.
· Often found on Grandfather clocks and requires only a long swing to get it in beat.
-To get the clock on the right side in beat you would need to push the verge assembly to the left.
-If it must be bent to put it in beat, do it slightly, but don't bend any of the suspension parts.
R/ David
Nov 08, 2009 | Seiko Chiming Pendulum Tambour Mantel...
Antique Forestville Mantle Clock
Middle Key hole for the time.
Left side is for Chime
Right side is for the strike.
r/
David
Aug 25, 2009 | Seiko Chiming Pendulum Tambour Mantel...
I have a Bulova Mantel clock that is chimming off the hour how do I reset it?
I have a B1987 bulova baradwell mantel clock that is chiming off I can't find my instructions book. please help me to fix this problem thanks
Aug 02, 2009 | Bulova Watches
I purchased an old Hamilton mantel clock that did not run. I have cleaned and oiled it and now it works well except it losses five minutes per day. This has a German movement, spring escapement type,...
This clock has a floating balance escapement.
Hold the balance snuggly with 2 figures. Take a small screw driver and push one of the 4 legs above and attached to the disk to the "+" direction. Move it about 1/4 turn. Set the correct time and check again the next day. If the clock is still slow, move it again and set the hands. Do this until the clock is accurate.
Disclaimer: If this movement was made in the 1970 or early 1980's (The date is a 2 digit # above the movement model number). Those years the clock manufac. (Hermle) did not do well in quality materials. The may need an overhaul or movement replacement. I can provide more information if needed.
Apr 01, 2009 | Watches
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
