Question about Cadence Weslo 825 Treadmill Walking Belt
Which is the adjustment side on a weslo cadence ts5
The allen head or the hex head side is the adjustment side on a ts5
5 Suggested Answers
joboo1
  • 257 Answers
SOURCE: How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Posted on Mar 14, 2009
SOURCE: can not find my manual for my weslo cadence ts5
try this site and type in model and type...manual will be a PDF booklet
http://www.iconservice.com/CustomerService/manuals.do?dr=WL
Posted on Jan 10, 2010
SOURCE: Weslo Cadence 450 Treadmill Manual
When turned on it acts like the walking surface is grabbing.Itgoes and stops its not as bad when speed is increased,but it still feels like it is grabbing.
Posted on Jun 20, 2010
Robert Braun
  • 77 Answers
SOURCE: The belt keeps moving towards
There are Allen bolts on both sides of the bottom on the front (away from the console) of the treadmill. Turn one one way and the other the other way to adjust the belt. If this does not work, your belt is probably worn and stretched and needs to be replaced. See Treadmill Parts to order a new one.
Posted on Aug 31, 2011
I have a weslo cadence ts5 treadmill with no manual - not sure how to change the incline.
Hello Mimac,
Please provide the Model no and Model Name of the Weslo Cadence TS5 Treadmill.
So that we can help you fast.
Oct 10, 2011 | Exercise & Fitness
The belt keeps moving towards the left side of the treadmill and rubs the side. How can I adjust the belt to fix the problem? It is a Weslo Cadence SR12 model. Thanks!
Aug 29, 2011 | Cadence Weslo 825 Treadmill Walking Belt
My weslo cadence 845 treadmill belt is off centered, How do i get it back on track?
There are Allen bolts on the bottom front of the treadmill as you face to console before getting on. Turning one one way and the other the other way will center the belt
Jun 14, 2011 | Weslo Cadence CT 4.8 Treadmill
My Weslo Cadence 840 treadmill mat keeps trying to run off to the left
Check that the plastic end cap has not broken first. If it is OK, adjustment should be simple.
Start the machine running. With the allen key provided (3/16) simply tighten (clockwise) the left hand rear roller adjustment screw about 1/4 turn and observe the belt. If it is way off, you might need to turn 1/2. Let the belt do a couple revolutions before adjusting more. A very small adjustment id usually needed to straighten the belt. If it is way off, there may be a more serious problem..
Feb 26, 2011 | Weslo Exercise & Fitness
The walking deck on my Weslo Cadence 975sel slides to the right and causes a loud rubbing noise. How can I correct this problem? Thanks,
Find the allen key that came with the machine. If you don't have it, you will need a 3/16" allen key to adjust the roller.
If the belt is pulling to the right, adjust the right screw by turning it clockwise 1/4 turn with the belt moving. You may need to do this more than once. Between adjustments, watch the belt closely to see how much it moves to the left.
Unless something dramatic has happened to the frame or some other part, the amount of adjustment should not be too great..
Dec 17, 2010 | Treadmill Doctor Weslo Cadence 930...
I have a used Weslo Cadense 927 treadmill. I need to adjust the the tread, it's rubbing the side.
When you purchased the treadmill it came with an allen wrench to assemble the machine. That is the adjustment tool.
Inspect the rear plastic cap (the adjustment bolts are there) make sure it is not damaged. If the plastic is broken, it will need to be replaced. This job is not easy. If it is not broken, adjust the belt as follows..
If the belt is already rubbing, locate the adjustment screw at the back of the treadmill on the side that is rubbing.Adjust that screw tuning it 1/2 turn clockwise. Move the belt manually 3 full rotations.. If it is still rubbing, turn another 1/4 turn. Again move the belt manually 3 rotations. Once the rubbing stops, run the machine slowly and watch the belt from the back of the machine..
Dec 16, 2010 | Cadence Weslo 927 Treadmill Walking Belt
The walking belt slips to the left when walking
There are two allen bolts (one on each side) at the end of the machine. These bolts adjust the tension on the belt. If they are not adjusted evenly the beft will gradually shift of the more loose side.
Sep 29, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Can not find my manual for my weslo cadence ts5 treadmill and need a free manual for it please
Apr 01, 2009 | Cadence Exercise & Fitness
Mar 14, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Cadence Weslo  825 Treadmill Walking Belt Logo
65 people viewed this question
Top Cadence Exercise & Fitness Experts
Jim London
Jim London
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Cadence Exercise and Fitnes Expert? Answer questions, earn points and help others
