Question about Maytag Dryers
How do I open the top of a maytag bravos xl gas dryer?
I need to install a propane converter, and I can't get the dryer open.
5 Suggested Answers
  • 9 Answers
SOURCE: converting back to nat gas from propane
Typically, conversion from natural to propane and visa-versa is just a simple connection behind the appliance. Look in the box of the conversion kit (or on the back of the packaging,) and you should see the conversion instructions. Since you are dealing with gas, you need to make sure the shut-off valve is... shut off so no gas can leak while do the exchange. Also, make sure there are not open flames anywhere near the work area. Take your time and follow the directions...
Posted on May 25, 2009
SOURCE: samsung gas dryer convert to propane
I purchased a Samsung steam gas dryer and found that no one in our area knew anything about them, Fortunately I am a gas tech. but have never worked on this brand. The first thing is you should always use a gas technician before doing this. Secondly turn off the gas and electricity. You must remove the two screws from the back that hold on the top of the appliance and set this aside. Then lift up the front electronics and disconnect the wiring harness, once you've done this there are 5 screws along the top of the silver strip or door area. This will alow you to lift up the front and disconnect the wiring harness and set aside. now you can follow the instructions on converting your dryer. PLEASE check for LEAKS and proper gas flow. Follow the same steps in reverse to put the dryer back together and happy drying.
Posted on Jul 01, 2009
SOURCE: Convert Whirlpool dryer from propane to gas
I have a whirlpool dryer as propane and needed it converted to gas. I have the orifce -gas kit which consist of two parts. Which part do I use? Is it the one which screws in and mist hole is on the other end, or the other one it comes with that has the mist hole on the other side.
The one i placed was the later ( one with mist hole on the side)
Posted on Aug 02, 2009
canbruce75
  • 1776 Answers
SOURCE: I need to convert my gas dryer to propane. I
Here are the basics of the conversion process:
Make sure the gas is turned off and the dryer2.gif is unplugged from the power source. Extreme care needs to be taken when installing the kit and making the conversion, since there is a very obvious safety issue if the kit is not installed properly. The kit will consist of a brass fitting with a nylon pin sticking out of it. This is called the blocking pin. At the gas valve and regulator you will remove the plug on the gas valve (called a leak limiter) and replace it with the fitting containing the blocking pin that comes in the conversion kit. That will change the gas regulator pressure setting from gas to propane.
Next, you will have to change the orifice metering plug in the burner. This does just what the name implies... it meters the amount of gas that enters the combustion area. The fittings that come with the conversion kit (blocking pin and orifice metering plug) are made of brass, which is a soft metal, and since they are being connected to a much harder steel, make sure that the fittings are not overtightened. I generally use some pipe dope on the threads. Once the conversion is completed, you want to check for leaks. I generally mix up some soapy water and spray it around the fittings to check for leaks. Look for bubbling which is a sign that there is a leak. The last thing to do is to reassemble the dryer. Start it up and make sure that it is operating correctly and that there are no obvious smells that would indicate a leak. If so, shut down immediately.
These are the basic steps for a gas/LP conversion. If there is any doubt that you feel comfortable making the conversion, then I recommend that you contact an appliance technician for assistance. Hope this helped and best wishes.
Posted on Oct 02, 2009
Testimonial: "This is good advice. Thanks! How do you get to the gas valve and regulator?"
Maytag neptune gas dryer Model # P MD64000AWW converting to propane and would like to convert back to natural gas
NEED TO CHANGE GAS ORIFICE. THEY ARE DIFF. BETWEEN NATURAL GAS AND PROPAIN THATS ALL YOU HAVE TO DO.
Oct 06, 2013 | Maytag Neptune MCG8000AW Gas Dryer
Have a Maytag Bravos XL MEDB9504WO that works, but very noisy. Bought a pulley that sits on top of
Sounds like you need new drum rollers, so you need to disassemble the front of the machine and remove drum replace all drum rollers and idler pulley also check blower for damage.
Jul 31, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag Neptune wont heat up what is problem
We just converted my neptune gas dryer to propane. It ignited yesterday but we could smell propane. So, my husband fixed that ,now it won't ignite and heat up
Nov 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Need to convert electrical Maytag Performa Dryer (Model:PYET244AYW) to propane gas system. It can be converted?
No that can not be done fairly inexpensivly...it could be converted but would actually cost more to purchase all needed parts that it would be to buy a brand new gas dryer
Oct 16, 2011 | Maytag PYE2300AY Electric Dryer
Dryer has been converted to propane using conversion kit #131776600 and I need the info needed to get it back to run on NG The dryer is a Fidgaire Gallery series model #FDGC648GHS0 any help greatly a
Hello there. If the parts were saved, they can be reused. If not, contact your propane provider and tell them that you plan to convert back to natural gas. They will be able to get you the kit you need, and will possibly have a technician come out and install it for a fee.
May 27, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Accessing burner and installing LP conversion on Maytag Bravo
you need to obtain a jet (orifice) of the correct size for the gas you wish to use. remove the burner and, replace the existing jet; that is all there is to it.
May 19, 2009 | Maytag Dryers
Natural GAs to Propane
Call Maytag or whirlpool!
Whirlpool makes Maytag now same company
They make a conversion kit!
ngafm at your service.
Please rate me before you sign out!
Sep 01, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
218 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
