Question about Hisense Televison & Video
How to reset the setup wizard on t.v.
Cant get tv to work , when I first tried to use the set -up wizard it was canceled during loading . I need to know the steps to reset the set-up wizard.
mastersaintx
  • 928 Answers
SOURCE: Router cannot connect on internet at setup wizard
Hi pag Smartbro ang gamit mo hindi mo pwede gamiting ang setup wizard. Iba kasi ang paraan ng connection sa SMartBro. Mahirap explain it would be best if you call Linksys Philippine support since there are so many ways to connect Smartbro to a Linksys router. The number is 1-800-1-114-1695 toll free. or kung gusto mo sa Yahoo ID ko nalang mastersaintx message mo ko sa umaga.
Posted on Sep 03, 2008
  • 120 Answers
SOURCE: denon 3801.cant display setup on tv
Hello gerrydav, What might be happenening is the refresh rate for your blu-ray is offsync for your preferred display. You should be able to change it by plugging it into another TV and playing around with the settings. If you have further problems please feel free to post again.
Please post what you do and how you did it. I look forward to your posts.
Posted on Nov 11, 2008
RickOz
  • 145 Answers
SOURCE: cant access set up wizard for d-link DI-524UP wireless router
Here is a link to the D-Link's site based wizard:
http://support.dlink.com/emulators/di524/h_wizard.html
Posted on Mar 25, 2009
SOURCE: won't allow manual clock set - tv guide not loading
To initialize ALL parameters to factory defaults: With the unit OFF, press "Skip Rev" ( |<< ) and "Time Slip" and "Open/Close" for 5 seconds.
will self check, say test L1, power off, on again.. go thru setup. no data was lost.
Posted on Apr 06, 2009
SOURCE: i dont know how to access setup wizard for cwr-854 cnet router
To access Router type that --> http://192.168.1.254 into your browsers address bar, a password & logon box should appear, The USERNAME is root The PASSWORD is 1234
Now you should be able to access wizard.
Here is a better manual.http://www.cnetusa.com/eng/Manuals/Wireless/CWR-854/CWR-854%20ver%20F%20Quick%20Install%20Guide.pdf
Posted on Feb 09, 2010
Samsung tv mute button is not cancelling tried to get volume back but cant get any sound
  1. On the TV remote, find and press the Menu button to enter the display for audio and video settings on the TV screen. ...
  2. Locate the Audio menu to turn the speakers on or off and select "on"
  3. Select "Fixed" in the Audio out section of the setup menu if available.
If this does not work add the model number to your post.
Sep 25, 2017 | Samsung Televison & Video
Can't login to Netgear WNR3500L router
try 192.168.1.1
if that don't work try to reset to factory default
press and hold reset button during the whole process and only release when completed.
1)press reset button 30 seconds
2)remove power cable 30 sec
3)plug in power cable 30 sec and then release.
You should no be set for 192.168.1.1
username admin
password is password
Jan 30, 2012 | NetGear WNR3500 Router
Tb100mw9 dtv converter I cannot access setup wizard.
Unplug,replug the converter box back like about an hour later.The box will resetting itself back to the factory setting,should able to bring up setup wizard than.
Jun 06, 2011 | Magnavox TB100MW9
We have the M220MV. Cannot change channels using the numeric keypad on the remote. I know it should be possible, the manual says you can change channels this way. If not, the last channel button would be...
Hello
Reset your Tv to factory settings. It will unlock all locks including front panel lock.
Reset All Settings
Return all Picture and Audio settings to factory default. A screen will come up to confirm your
selection or to cancel it. Press Left or Right Navigation buttons to make the selection, and then
press OK to accept it.
Setup Wizard
Use this function to return to the Initial Setup menu
Go to its user manual for Initial setup menu details.
OK.
Apr 24, 2011 | Vizio M220MV 22 in. HD-Ready LCD TV
TV will not remember settings Sony Bravia KDL 40S4011
Probably you are in "shop" mode of TV. Try to reset your TV and go through initial setup. Most important - choose "home" instead of "shop" when asked during initial setup. Resetting - keep up arrow pressed and switch of TV. Keep the button pressed when TV automatically switch back on. This will reset TV to factory defaults.
Apr 17, 2010 | Sony BRAVIA KDL-46V3000 Television
We recently installed a new replacement router WRT 160N V3 and something called Network Magic keeps interupting and trying to sell their service. We keep canceling them and then the router does not work...
To clear out the problem if Network Magic has something to do with your connection.
1) Uninstall Network Magic from host computer.
2) Remove Ethernet connections to router.
3) Reset the router (press & hold reset button for at least 15 secs.)
4) Run Setup wizard on host computer and follow on screen instructions on connecting PC to router.
5) Setup wizard prompts on installing Network Magic, just ignore it.
6) if it automatically installs Network Magic just uninstall the program before you fully use your router.
Resetting router clears all settings made by Network Magic application made on the router.
Hope this helps.
Mar 13, 2010 | Linksys Wireless-G WRT54G Router
Cant set up wireless on daughters laptop
Click connections check you have a net connection loaded.
If no icon, you will have to set a network. Look to the right wizard to setup a network.
Nov 13, 2009 | Panasonic Toughbook CF-51 Notebook
No access to set up wizard
what is the model of the Wireless acces point. Check is there any reset button. If so, press it for 10sec. and try the same
Jun 30, 2008 | D-Link AirPlus DI-524 Wireless Router
Mitsubishi CS-32509 TV
Unplug the TV for 4 hours or more. This is called a 'Hard Reset'. Then plug it back in, turn it on and let the TV do it's thing. It will set itself up. Just follow the TV setup prompts. Guide Plus is a feature on the TV. Much like a TV guide showing all channels, shows, description of shows, times, etc..
Jun 30, 2007 | Mitsubishi CS-32509 TV
Televison & Video Logo
177 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
