Question about Ingersoll Rand Ingersoll-Rand 1/2 in. Drive Impact Wrench
Parts list for IR 223 impact gun - Ingersoll Rand Ingersoll-Rand 1/2 in. Drive Impact Wrench
3 Suggested Answers
  • 16 Answers
SOURCE: my ir 223 impact trigger doesnt work ,,,I took it
You can purchase a repair kit from Ingersol that will have the spring and pin. You will need to make sure the fitting on the inlet that has the screen installed is still there or the pin and spring will come out again
Posted on Oct 12, 2009
  • 8 Answers
SOURCE: Parts for older eletric impact
Ohio power tool stocks some of these IR items, your model interchanges with model 8049.
Posted on Feb 01, 2011
244a Ingersoll rand impact gun
Yup, there is a procedure for that.
1. Use a good penetrating lubricant and soak well.
2. Make sure the motor cylinder (item #22) is installed and pressing against the rear endplate (item# 27), this will keep it straight while attempting to pull the rotor from the motor housing.
3. Grab a set of Vise Grip pliers, lock on to the end of the rotor. Tip install the hammer case screws, thread them all the way down the will give you a place to tap with a hammer and not damage the housing. Depending how old or how beat up you tool is you might have to slightly heat the housing with a propane torch to expand the housing, only do this as a last resort.
Ideally it should slide right out.
Follow this link for a parts list:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/16578791_ed2.pdf
Jan 27, 2014 | Air Tools & Compressors
Ingerroll rand 2132g how do I oil my air impact wrench?
Most I.R. impacts require grease in the hammer mechanism (clutch) and oil in the air motor.
To lubricate the air motor simply add oil through the air inlet about 3 to 6 drops at every use.
To lubricate the hammer (clutch) mechanism you will need a grease gun with a needle, the grease fitting (item# 17) is located on the hammer case assembly (item# 15) 2 or 3 small squirts will sufficiently lube the hammer (clutch) mechanism.
With heavy use grease the tool once a month, with light use 2 to 3 times a year.
Follow this link for the parts list, also indicates the grease needed:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/80164726_ed4.pdf
Aug 04, 2013 | Impact Husky® 1/2" Wrench
Instruction on how to rebuild an ingersoll Rand 231HA-2
Sorry, could not find a repair manual for this tool, but the I.R. parts lists are very well detailed and shows the parts in the order that they fit into the tool.
Follow this link to the parts list.
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/IR%20Industrial%20Tools/Impact%20Tools/04581286_ed3.pdf
Feb 25, 2013 | Ingersoll Rand 1/2" Super Duty Extended...
Model number 223
IR 2135-k303 air inlet repair kit along with a 2131-322 air inlet removal tool should get it repaired.
Nov 12, 2012 | Ingersoll Rand - Rand 1/2" Impact Wrench,...
I have a ir 5/8 drive impact #2905vw599 and need parts
the best advice i can give, after being involved with rattle guns for 30 years is for you to take it to an air tool service centre , ithink the main parts you will need willbe o rings and they will have access to the parts required ,even if they be after market, believe me ,that is the way to go .
Nov 11, 2009 | Air Tools & Compressors
IR 261 air wrench vanes sticking
NOT exactly a solution, but may help you with your problem: I'm also a Owner of a 261 ( In fact 90% 0f all my Air Tools are IR) that I used everyday when I was working on Terex Equipment & EMD Locomotives. I "Upgraded" the Major Parts inside my Gun to the "Industrial Line" rather than the Automotive Parts since the 261 is classified as a Automotive Tool..and Installing an Adjustable Regulator on the Gun Helped a Lot too...by "tweeking" my Gun out, I was Pumping almost as much torque as some of the 1" Guns...
FYI: Don't Over Oil as the Oil will absorb into the Vanes, causing them to Expand in thickness "Permanently"...just 2-3 drops of a Hi-Grade Air Tool Oil before starting the Day is enough...sounds to me like your Picking up some contamination someplace??
Feb 05, 2009 | Ingersoll Rand 3/4" Super Duty Extended...
Ingersoll Rand Ingersoll-Rand 1/2 in. Drive Impact Wrench Logo
547 people viewed this question
Top Ingersoll Rand Tools & Hardware - Others Experts
elunsford
Phil Walker
Phil Walker
Are you an Ingersoll Rand Tool and Hardware - Other Expert? Answer questions, earn points and help others
