This problem should be removed because:
Problem with Canon MF3110 All-In-One Laser Printer
problem in canon
I can not find driver of canon mf3110 for windows vista 64 bit.
Solutions (6)
Best Solution
i found a solution for printing with Canon MF 3110
1- Download Driver For MF5730/5750/5770 For Vista 64-Bit
File Name : L7602ENx.exe
http://software.canon-europe.com/products/0010260.asp
Follow These Steps
1- Add Printer
2- add a local printer
3- Use an existing Port : Choose : USB ( Virtual Printer for USB )
4- Have Disk
5- Locate the File Name : MF5700AK.inf
6- Printer Name : Change From Canon MF5700 Series To Canon MF3110 Series
7- Print Test Page
it Work for me on Vista Home Premium SP1 64-Bit
P.s
still Cant Manage to use the Toolbox 4.9.1.1.mf04 for Scanning ( Any Ideas ? )
Regarding solution #2:
Thank you so much for the info, works great! But one thing you must do after you installed the driver is change the default paper size setting on the computer so it would stop giving out the change paper size alarm on the printer.
For solution 2, I downloaded the MF5730 driver from the US site.
I needed to change "Canon MF5700 Series" To "Canon MF3110" (and not "Canon MF3110 Series") in file MF5700AU.inf (which should be the US equivalent of MF5700AK.inf)
I've seen this fix on other sites (also with the scanner issue unsolved). However, they leave out the detail ("miracle step") on editing the .INF file.
Here's how to get your Canon MF3110 scanner to work under Win7-64 bit. Wherever you unpacked the 5730 driver files, locate the file named MF12SCN.INF.
Look for this section:
[Models.NTamd64.5.1]
Add this line to the section:
%LPTENUM\MF3110.DeviceDesc%=MF5730Install_XP,USB\VID_04A9&PID_2660&MI_00
Save the file.
In the Control panel, open Device Manager and find the MF3110 device that has the exclamation mark. Open its Properties. Pick Update Driver. Pick Browse My Computer. Pick the folder where you found the MF12SCN.INF. Windows will find the driver and install it. it will give it a strange name, but the scanner will work.
Worked great on two Windows 7 laptops 64 bit. This and solution 5 saved me from having to buy a new printer-scanner!
Thanks so much for Solution #2!!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=239&modelid=10519#DownloadDetailAct
download the drivers for 2000/xp, it will work on vista as well
Suggested Solution (3)
Get MF5700 drivers for vista 64 bit, your MF3110 will work fine with it for printing, although i am still having problem with the scanner.
Source: No 64 bit drivers for MF3110
Go to Canon MF3110 Support
If the Drivers & Downloads tab is not selected, click on it.
From the drop down menu, select your Operating System (Vista).
A link will appear in red in the Drivers block that appears. Click on the link to download it. The best thing to do is to select Save when the download window opens and save it to your Desktop. You can then begin the installation once the download is complete.
The Setup Guide is also on that same download page if you need it. Just remember when it says to insert the CD, just double-click the file on the desktop.
Thanks for using Fixya.
Testimonial: "Excellent advice thanks"
Source: Vista 32-bit driver for MF3110
From the manufacturer's web-site:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=10519
there _ONLY_ is a 32-bit driver for Windows Vista -- no 64-bit driver.
Source: I need a driver for vista 64 bit
I am looking for drivers for my MF3110 for Vista on a 64 bit computer.
I need a driver for vista 64 bit for canon mf3110
how to get the driver for this printer for
how to get the driver for this printer (canon MF3110) for windows7 64 bit
looking for a printer driver for canon mf3110 to...
Looking for a printer driver for canon mf3110 to work with windows vista 64 bit
Add Your Solution
Canon MF3110 Printer on home network
I have home network with two computers. First one is win XP, where the printer is installed and the second one is win 7...
I have had this printer for a year now. Then all
I have had this printer for a year now. Then all of a sudden the alignment of the printing is completely off the page. I...
Fix-O-Meter
4,853
4,853 people viewed this problem
- 59 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Canon Printer Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
