Question about HP PSC 1215 All-In-One InkJet Printer
Hp psc 1215 Mechanism Error: The print cartridge cradle cannot move.
All Office
  • 58 Answers
SOURCE: Mechanism Error - Print Cradle won't move! - HP 5650
This "plastic strip" is called the "carriage encoder strip". This strip dictates the timing of the carriage assembly. If the end slots aren't broken, you can re-attach it. Otherwise, you'll need to replace it. They are about $10.
Posted on Jul 03, 2007
  • 4 Answers
SOURCE: hp psc 1215 wont scan
It sounds like you need a TWAIN driver. I would suggest that you do a google search for one. My daughter had the same problem but with a different all in one machine and finding the TWAIN driver solved her problem. Hope this helps.
Posted on Feb 10, 2008
Dipu007
  • 2110 Answers
SOURCE: hp psc 1215 installation
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&lang=en&product=412187&dlc=en
here u can download driver...
Posted on Feb 16, 2009
myjosh007
  • 530 Answers
SOURCE: HP psc 1215 all in one error message
hi im josh in cebu phils.may i help you? Friend try to use thse solutions surely it will help you:
The first item to check is whether your printer is connected correctly to your computer. Check the connecting cable to make sure that the connections are tight. You also should unplug each end of the cable to ensure that none of the connecting wires are bent, making a bad connection. You might also want to change the printer cable. Cables can get old, and the wires inside can break; try a new cable and see whether this change fixes the problem.
caution
caution_icon.gif Anytime you change any connection between your system unit and any external device (such as your printer), you probably need to turn your computer off and then back on again for the connection change to register with your system. So if you're plugging in cables, reboot your system when you're done.
Next, you should make sure that the printer is connected to the correct port on the back of your computer. Checking the port connection is not always as simple as it seems. Some computers come with more than one printer port, and your printer might be hooked up to the wrong one. If you have multiple printer ports, try plugging your printer into the other ports.
Next, check the paper feed of your printer. If you're out of paper, your printer can't print. You also should check the paper path inside the printer to make sure that no stray pieces of paper are lodged inside. Make certain, too, that your printer is online, or set in the on position.
You should also check to see if your printer is paused. Check your front panel buttons to make sure that your printer is online. You should also double-click the Printer icon in the Windows system tray to open the Print Manger and make sure the job isn't paused from within Windows.
Another potential cause of this problem is having the "manual feed" option selected in Windows or on your printer. If this option is selected and there is no paper in the manual feed tray, your printer just sits there waiting for someone (like, oh, you!) to insert some paper. The solution to this is to either add some paper to the manual feed tray or switch off the manual feed option.
It's also possible that you have the wrong driver installed or selected within Windows. Right-click on this printer's icon in the Printers window and select Properties. Check the Details tab to make sure you're printing to the correct port using the correct driver. If you need to change drivers, pick one from the pull-down list, or click the New Driver button to add a new printer driver.
note
note_icon.gif The tabs in the Printer Properties dialog box are specific to the brand and model of printer you have installed. If your Print Properties dialog box doesn't have a Details tab, look for a Ports or Advanced tab instead.
It's possible that the correct driver is installed, but something has gone screwy with how Windows reads the driver information. Go to the Printers Window and delete the current printer, and then use the Add Printer Wizard to reinstall the printer driver. You might also want to check with your printer's manufacturer to see if there is an updated version of your driver available.
In addition, it's possible that a recently installed device has somehow mucked with your printer configuration in Windows. Try deleting your printer driver and then reinstalling it, as described in the previous paragraph. Because the last device installed on your system can overwrite previous configuration information, go ahead and make your printer the last installed device.
If none of these suggestions solves your problem, you're looking at a major computer or printer problem. Try hooking up another printer to your computer; if the new printer works, it's time to take your old printer into the shop. If the new printer doesn't work, you probably have a defective port in your computer. good luck!
Posted on Mar 04, 2009
bob_computer
  • 3153 Answers
SOURCE: Just replaced the black ink cartridge on the HP
Take a look at my tip on cartridges it may save you a lot of time and money
http://www.fixya.com/support/r3845491-ink_cartridge
OR
Read on and see if any applies to you.
Check that you removed the protective tape. some cartridges have two of these pieces of tape one over the head and possibly on on the contacts to the printer.
If you recently re-filled or had the cartridge refilled or even bought one of the many cheaper replacement cartridges you should read on
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a
chip resetter around on the INTERNET or maybe even local
OR
Even better empty cartridges that
never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well.
cheaper cartridge problems have been on the rise recently and that is for ALL makes of printer.
If you try to clean the contacts be VERY careful cleaning contacts and ONLY use isopropynol on a lint free bud or cloth.
Also be very gentle.
I have seen the contacts cleaned and cartridges ruined with other methods of cleaning.
Rubbing too hard can also cause a badly set chip to move making it inoprable.
I dont like full prices replacements either which is why I always provide the links
I usually reccomend that people take back any cartridge that does not work right from the get-go.
I dont know of anyone who has had a problem doing that be it a shop refill or otherwise.
No matter if I paid $1 or $100 for a cartrdige I would still expect it to work
Hope this gives you the information you need
Bob
EXMod
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Posted on Jan 14, 2010
Hi, my HP Deskjet F380 wont printi. Ths error message comes up : "Mechanism Error: The print cartridge cradle cannot move. Turn the printer off, free the cartridge cradle, and turn the printer back...
when you open the cover of the printer where is the cradle located? if it is in the right push it to the left corner,then plug the unit observe, if still not work check if it is on the left push it to the right, be sure to unplug first the unit before executing this method, then on again the unit
Aug 07, 2011 | HP DeskJet F380 All-In-One Printer
I have an hp psc 1215 all-in-one. My black cartridge won't print. It recognises if I swap it out for a new one, and goes through all the motions. It registers the correct ink levels. The cradle...
The problem is not with the ink-cartridges. You've proved that, by swapping BLACK cartridges.
The problem is that the ink-jets that spray the BLACK ink onto the paper are clogged.
Thus, no BLACK ink reaches the paper.
Open the HP Printing Assistant, and open Utilities, and run a few "print-head-cleaning" cycles, to try to unclog the print-head.
Jul 19, 2011 | HP PSC 1215 All-In-One InkJet Printer
How do i change the cartridges of hp psc 1215
1. Turn on the unit, then open the print cartridge access door by lowering the handle. -- The print carriage moves to the center of the unit.ionstorm_0.jpg
2. After the carriage stops moving, push down on the print cartridge to release it, and then toward you out of its slot.
3. Remove the new print cartridge from its packaging and, being careful to touch only the bright pink plastic tab, gently remove the plastic tape to uncover the ink nozzles.
Caution! Do not touch the copper contacts or ink nozzles.
Once you have removed the plastic tape, install the print cartridge immediately to prevent the ink from drying in the nozzles.
4. Push the new print cartridge into the appropriate slot at a slight angle until it clicks into place.
Caution!
Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
The tri-color print cartridge goes on the left and the black cartridge goes on the right.
5. Close the print cartridge access door.
May 06, 2011 | HP PSC 1215 All-In-One InkJet Printer
HP PSC 1500 series print cartidge cradel cannot move?
Does is look/sound like the cradle is attempting to move? Make a loud popping sound? There is small belt that is used to guide cradle across the platen. Take a closer look to see if anything is obstructing that belt. It's rubber and looks like it has gear teeth on it and fits around white gear wheels on side of cradle.
If it doesnt' move at all, a hard reset might clear it. You'll have contact HP support for that as each printer model is different. Some you just hold the power button in for a certain number of seconds.
A soft reset can be tried by unplugging power cord from printer and waiting 15 seconds then reattach power.
Oct 05, 2009 | HP PSC 1510 All-In-One InkJet Printer
Same or similar problem
Try to download the updated driver for this printer, I have the same problem and solved with the newest driver.
Jul 10, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hp 812c cartridge cradle is stuck on the right, not moving to the
unplug the printer and try to move carriage by hand, if it does not move, the carriage mechanism is broken, if it does move, plug the unit back in, if same error occurrs, it is an issue with the printer carriage mech.
Feb 27, 2009 | HP DeskJet 812c InkJet Printer
Printing photos on hp psc 1215
Are u using the original HP ink ? The HP ink is formalated to dry fast. You might try using a different ink cartridges, but try a couple sheets of HP photo paper to see what happens.
Apr 21, 2008 | HP PSC 1215 All-In-One InkJet Printer
Cradle jam after inserting ink cartridge, wont align
May-15-2008
in a HP-PSC-1210, replaced empty HP56 black-inkjet cartridge.
Afterward, printer gave error message AND unable to "dismount" the cartridge.
Finally discovered that an HP57 color-inkjet cartridge had accidentally been mounted/installed. A handyman relative was able to dismount the (wrong) cartridge.
Cradle did not actually jam, though printer would not print.
Apr 21, 2008 | HP Office Equipment & Supplies
Print cradle cannot move error
hi,
this seems to be a hardware problem..... anyway try this...
> unplug the powerchord
> open the rear access door, and check whether there is any paper jammed or any bit of paper or thread stuck inside.... if so remove it
> clean the rollers using a lint free cloth
> close the rear access door
> open the door so that you will get full access to the cartridges...
> move the cartridges to and fro for several times manually with your hand
> close the door
> plug the power chord
> try again to copy multiple pages
thanks and regards
agnel
Mar 17, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1215 All-In-One InkJet Printer Logo
56 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
