Question about Vizio VW46LFHDTV10A 46 in. LCD TV
Have vertical lines on Vizio VW46L FHDTV10A
Replaced T-con board. vertical lines are still there.
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: I have a 46" Vizio
Hi.
From description it looks like the shadow on top is one of the lamp not turning on completely.Or staying off. If the lamp stays off it can still be the inverter. If lamp turns on partially, then the lamp tube must be replaced.
The symptoms do not belong to any common fault. The fault seems involving back light system (inverter, lamps, wiring).The fault responds to whack test, and then it is likely a broken contact (wiring, connector or broken solder joint).
When problem is the inverter you usually do not get any back light, or lights go off altogether. If the inverter is located near to where you tap (the slave more than the master), then this can be part involved.
In fact, if when you tap the top of the screen the situation changes, that means that there is a bad contact in that area. The test is called whack test. Test inverter terminal contacts (connectors and wiring) using a multimeter to ensure that there is continuity between different point of the circuit (zero or low impedance), from inverter to back light lamp. Replace the inverter if you find a problem, or you risk replacing the wrong part. Continuity testing is done with power OFF(ensure that power cord is out).
Regards.
Ginko
Posted on Feb 03, 2011
tunde007
  • 2382 Answers
SOURCE: I have a Vizio LCD
Hi, vertical lines when the television is on may be related to issues with the television's screen resolution. Resolutions set higher than 1280 by 720 can create visual disturbances on the screen. You can reset the resolution through the control panel's display settings menu. This should correct the issue immediately, although you may need to power the television off and then on again in some cases..
Posted on Mar 26, 2011
Should the T-CON board be replaced on a Samsung LN40C650 LCD TV to fix the vertical lines problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 08, 2015 | Samsung LN40C560 LCD TV
LG LCD TV 42LK450 - Sound but screen is black..
Sorry but you have a bad panel. Repair cost is prohibitive. The T-con was a good choice, but is the last step to the panel.
Feb 13, 2014 | LG 42 42LK450 42 LCD TV
TX-52F480S lines
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Oct 11, 2012 | Westinghouse TX-52F480S 52 in. LCD TV
Blue line going vertical on my vizio VX42L
Check all the connection sockets from T'Con board to LCD panel for any loose. Re-seat them. If this do not help you, T'Con board is faulty, and should be replaced.
Aug 17, 2012 | Vizio VX42L 42 in. LCD TV
We have a KDL40V5100 which is about 18 months old, we are now seeing a vertical line in the center of the picture which appears to be worst when there is a lot of action going on. It is almost like the...
Yes,this causes are bring it on by a board that call the T-CON board.This T-CON board it is slowly shorting out and slowly dying to bring these vertical lines up and showing up onto the tv LCD screen panel.This T-CON board jobs are to control and filter all the tv pictures pixels before it show up on the tv LCD screen panel.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a new refurbish T-CON board for the replacement.
Aug 18, 2011 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
I have multi colored vertical lines across the entire screen. The menu screen is perfectly legible when selected on the remote and will go on and off like it is suppose to.
If this tv vertical colors lines problems happen by itself,tv problems not causes by u or an object by hitting forces to the tv LCD screen panel itself.The tv board that call the T-CON board it is dead,this board sit in the bottom in the middle of the LCD screen panel.Must be replaced the T-CON board to solve tv vertical colored vertical lines.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.If causing by u or an object by hitting forces it to the LCD screen panel itself.The tv not worth a whole tv anymore,because by replacing the tv LCD screen panel will cost the same as a new tv.
Jul 28, 2011 | JVC LT37XM48 LCD TV
I have a 15 inch Advent LCD TV in my kitchen. I turned it on today and have no picture. When I switch stations I get a picture for a minute then it is replaced with vertical lines or a blank screen with...
U have vertical lines for a few second.That mean u tv have a dead board call the T-CON decoders is board.This T-CON decoders board sit at the bottom wright in the middle of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Dec 11, 2010 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
I have a sharp 52d62u with a lot of vertical lines on the whole screen. They vary in color. Is there any fix for this or do I need to find a new tv?
Anybody or an object hit the LCD screen panel,that cause truama to it,than it not repairable.The LCD screen panel it dead.Nobody or an object hit the LCD screen panel.If vertical colors lines it happen,by itself.Than the T-Con board is dead.The T-Con board,that the board,that sit right in the middle bottom of the LCD screen panel.Replaced the T-Con board should solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con board for the replacement.
Sep 17, 2010 | Televison & Video
I have a 42JC2D TV. Vertical color bar lines
It is hardware issue related to LCD Panel (screen).
Regarding fixing it, it depends if you are handy with electronics stuff repair and can replace circuit boards in tv etc then please check T-Con (lcd controller board) on top center position at rear of lcd panel, this board would be covered with metal shield. Need to take off back cover of tv to get access to T-Con board. If T-Con board does not solve lines problem of screen then LCD Panel is bad and will be replaced.
If you fee uncomfortable doing so then repairman option is better choice.
Hope this info will help you.
Thanks.
Feb 27, 2010 | LG 42LC2D 42 in. LCD HDTV
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Vizio VW46LFHDTV10A 46 in. LCD TV Logo
166 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
