Question about Thetford Refrigerators
Have you got a install manual for thetford n145 fridge
3 Suggested Answers
  • 68 Answers
SOURCE: thetford caravan fridge freezes all food in fridge
Thats a Norcold compact fridge. The most likley problem would be the thermister. Need to do an ohms reading. From inside of the fridge remone the thermister from the fins and unplug the wires. With a VOM set it on Ohms, touch the wires with the probes/ does not matter which probe to wire/ hold the bulb end of the thermister between your fingers, your reading should stat at about 7000 Ohms. Stick the bulb end of the thermister in a glass of ice water, reading should start climbing and go to about 22000 Ohms. If this happens the thermister is good and you need to look elsewhere. If it does not test out you need to replace the thermister. The thermister is a thermostat that controls the heat source that makes the fridge cool. If the thermister reads good you may want to get the circuit board tested.
Hope this helps
Thank you for using Fixya
Jerry
Posted on Mar 30, 2009
  • 8 Answers
SOURCE: I have a Thetford N112 which will not cool the
un plug the heating element from the circuit board and ohm it out. also check fuse on board. but sounds like the heating element has gone out. if when you ohm it its on 0 its bad
Posted on Aug 27, 2009
Where does the wiring go in the new thetford 220 toilet i have installed in my motorhome , red to power black to earth, where do the other two wires go.
.There are a few different installation manual available through Thetford Download RV Product Manuals Support Portal Thetford
follow this link and select your specific model to download the manual you need.
Apr 21, 2018 | RVs
Wiring drawing for thetford n112 fridge
bottom lower left control board has block for 12 volt hook up
Jun 25, 2015 | Thetford Refrigerators
Thetford N80 fridge will not work on mains
check fuse inside control box of fridge then check heater elements
Jan 19, 2015 | Thetford Refrigerators
Will a fridge still work if fault code 13 is displayed?
13 error code means heater element in freezer drain bad replace have to take apart whole freezer
Aug 12, 2014 | Thetford Refrigerators
I have a thetford N112 fridge which works on gas but not on mains, the element heats up but fridge does not cool
Hope this answers all your questions
Leave a comment if you need more help.
Thanks for using Fixya.
Oct 16, 2012 | Thetford Refrigerators
Thetford fridge wont work on mains power
start by putting the fridge in a cold place or if that don't work then turn the temp down inside the fridge
Dec 19, 2009 | Thetford Porta Potti
We have a Thetford N80 fridge in the caravn which will not light on gas. It clicks but no flame appears.
Try manually lighting the pilot when it is clicking. If it lights you need a new thermo couple let us know what you find out from this step
Aug 17, 2008 | Thetford Refrigerators
Refrigerators Logo
87 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
