Question about Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump
I have a STA-RITE DS3HF-01 Irrigation Pump. It is not working and I get a knock noise from the motor when I try a manual start. Any ideas?
2 Suggested Answers
SOURCE: How do I prime the STA-RITE DS3HF-01?
I have a sta-rite mkse-6 pump and it has lost its prime..... how do I prime it???
Posted on Aug 15, 2009
Have deep well vetical sta rite pump both pipes in ground staying full of water will not pump press does not looose prime but wont build press
shut off pump breaker at the lowest faucet drain completely. Turn it back on. If this doesn't work, you have to change out the pressure valve on the side of the tank. it's not hard.
Oct 08, 2012 | Sta Rite Ds3hf 1.50 Hp Self Priming...
When I turn on my STA-RITE 1.5 HP pump, it makes a humming sound.
A humming noise is fairly normal if the pump is running and pumping correctly. I am guessing this is not the case. Usually it is just a stuck impeller that is the culprit. Power down the unit and open the pump housing to access the impeller. Then gently turn the impeller feeling for resistance (some resistance is normal from the magnets of the motor). If everything seems ok close and secure the pump housing. Try powering the unit on and see if it starts up correctly. If it is still having issues manually prime the pump. If the pump runs correctly for a few minutes after manually priming but slows or stops you have a leaky seal or fitting to find. Finding the seal is not hard but will take a little time and patience. With your garden hose, very carefully run water over each joint and fitting with the pump running. It will take a minute or so of water running over a leaky seal for the pump to prime so take your time. Make sure not to get water on the motor as it can deliver a very nasty shock and destroy the motor. If none of this gets you up and running the cause may be the motor is bad and needs replacing.
Mar 19, 2011 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Rrigaton pump won't hold prime?
Check out the foot valve... it either went bad or it has dirt stuck in it...
heatman101
Aug 11, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Do I need gasket sealer on gasket between motor and pump housing on sta-rite water pump?
You will know if the housing has a gasket groove cut in it for a o-ring. if not no gasket needed.
The Pool Tech
Jul 10, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
How to prime a sta rite mse 7 deep well pump, when I've filled the 1 inch pipe plug with water and it won't fill.
have to fill the housing complete with fluid. make sure there is no more air in it. also make sure that is not poss. to **** air. also the sucktion side must be full of fluid. watch rotation direction. pump is not able to **** from under 7 meters.
Feb 08, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
My model DHH 169 won't start. I hear humming noise when I turn switch on but pump motor won't start. I replaced the capacitor but still won't start. What might be the problem/fix?
If you replaced the cap and their is nothing wrong with the impeller (check to see if it turns OK by hand) Then I'm sorry to say your motor is probally burnt out.
Feb 02, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Pump will run continuously, not disengaging, creating high pressure in tank.
have a look at the presher censor it could be a duff one may need to be replaced
Oct 26, 2009 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Feb 15, 2009 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump Logo
327 people viewed this question
Top Sta Rite Garden Experts
appman67
appman67
Jay Finke
Jay Finke
steve morris
steve morris
Are you a Sta Rite Garden Expert? Answer questions, earn points and help others
