Question about RCA HD52W58 52" TV
Problem with rca hd52w58 52" tv
When i turn on the tv, there has always been a very slight delay to see the picture but now it is taken much longer, we hear the sound but the picture only comes to view 20 seconds or more later. also the picture is not clear and the color is mostly green in background. we try to adjust and change but still too much green background
what do you suggest.
    Scholar:
  • 146 Answers
This can be a green crt or green driver pcb problem. You can try and unplug the tv for 30 min. and plug it back in and turn it on, but the problem will most likly still be there. A repair shop will need to fix it from there.
Posted on Nov 10, 2008
I just purchased a Kodak Eastshare c182 and I would like to know how to take time delayed pictures.
Manual:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg01041/C182_xUG_GLB_en.pdf
Page 11
Using the self-timer
Use the self-timer when you want to be included in a picture, or to ensure a steady
Shutter button press. Place the camera on a tripod or flat surface.
1 In any picture-taking mode, press the Info button to turn on the shortcut icons.
2 Press to highlight the self-timer icon. Press to choose a setting:
10 seconds- A picture is taken after a 10-second delay (so you have time
to get into the scene).
2 seconds- A picture is taken after a 2-second delay (for a steady, shutter
release on a tripod).
2 shot- The first picture is taken after a 10-second delay. A second picture
is taken 8 seconds later.
3 Compose the scene. Press the Shutter button halfway, then completely down.
The camera takes the picture/pictures after the delay.
Use the same procedure to take a 2- or 10-second self-timer video, but press the
Shutter button completely down.
Mar 18, 2011 | Cameras
How to get the blur off
Blurred photos on a digital camera are almost always caused by camera movement while the picture is being taken. Remember to hold the camera still after the shutter is pressed, as there is usually a slight delay.
Oct 18, 2010 | Cameras
How do i turn on the auto timer?
Hi, Follow these steps:
1. In any Still mode, tap Settings to open the Settings panel.
2. Tap Self-Timer/Burst repeatedly, until the desired Self-timer icon appears at the bottom of the LCD: 10 seconds—A picture is taken after a 10-second delay (so you have time to get into the scene). 2 seconds—A picture is taken after a 2-second delay (for a steady, auto-shutter release on a tripod). 2 shot—The first picture is taken after a 10-second delay. A second picture is taken 8 seconds later.
3. Compose the scene. Press the Shutter button halfway, then completely down. The camera takes the picture/pictures
Apr 13, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
The problem of my camera is, when i take picture the output is very blured but when i use the video the output is okay. Please help to solve this one. thanks
The problem with most digital cameras is that there is a slight delay between when you press the shutter and when the picture is actually taken. The only real solution is to continue hold the camera steady for a second or two after you think you've taken the picture. You can check the camera is ok by placing it on a firm, steady surface and using the self timer to take a picture. This picture should turn out ok. The reason that video looks ok is that as it's a moving picture slight movements by you are constantly disguised.
Nov 25, 2009 | Olympus FE-280 Digital Camera
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
Sony KV-32S42 (See Description)
It may be a fruitless effort. The main reason this occurs is that the Picture Tube is drawing too much current and the AKB circuit will not let the video circuit diplay the picture. Outside
of replacing the Picture Tube there is no fix.
You can varify this by turning the screen control up. This is usaully located on the HV transformer and is marked. the other location it may be is on the CRT board. It also would be clearly marked. If you adjust this slightly and the picture appears, the Picture Tube is the problem. I'm betting 100% it's the Tube.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony KV-32S42 32" TV
Using self timer on my digital camera
1 In any Still mode, tap Settings to open the Settings
panel.
2 Tap Self-Timer/Burst repeatedly, until the desired
tripod).
Apr 29, 2009 | Kodak EasyShare V1073 Digital Camera
The audio and video are not in sync
Are the movies you're watching store purchased DVDs? Sometimes with downloaded movies, the audio and video are just out of sync.
If they're store bought, it's possible that you've got a delay set in your receiver. Consult your receiver's operating manual to see if there's a "delay" option.
It's also possible that you're hearing that delay in the TV speakers.
If you've got the audio coming through the receiver AND the tv, you'll hear a slight delay when the audio's traveling from the DVD player to the television itself. This could happen "sometimes", if the tv volume is on, and not happen when the tv volume is off.
Mar 19, 2009 | Sanyo DVW-6100 DVD Player/VCR
HDtv picture and av reciever sound do not match
I have a hdtv hooked up with a virgin v+ box but slight delay Why?
Dec 06, 2007 | Televison & Video
RCA HD52W58 52" TV Logo
81 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
