Question about Acer Computers & Internet
Acer model veriton 3900 Pro CPU fan won't stop after shutdown system
Buschchris1
  • 474 Answers
SOURCE: ACER Veriton 5600GT how to turn off USB power after shutdown
Not likely.
What you have is power over USB which is good because it allows the hard drive to get enough power to run without a seperate power cord. This is also usefull for IPODS and other media that Charge through a USB. It means you can turn your computer off and still charge something.
If its an external hard drive, its meant to be removed. You can right click and disconnect it from the bottom right and then remove it safely.
You may have a port that doesnt provide power when turned off, maybe a front USB port, you could plug it in there.
There most likely isnt a way to change any jumpers unless your system board instructions specify that you can and how to. Dont go tinkering around because if you put jumpers on the wrong spot, you can blow some of the small components on the board.
This would render the USB completely useless.
If you want a permanent extar HDD for back up, just get a new IDE for the internal, There cheep these days. you can get a 250 gig IDE for under $60.00
Posted on Feb 03, 2009
rulds2008
  • 3866 Answers
SOURCE: sytem fan is kaput
You geetin a false readin how can core 0 being a diffrent then core 1 when there the same waffer this is funny as all get out.. The ystem fan on this unit would be just below the power supply fan if you have one. If you do not have one then there will be little round holes there and you could look right into the case that means there is not fans present, Some manufactures do not power up the fan using the motherboard the piggy back it off one of the drive power cables thus you will get no reading at all Hence the sensor will not sense that there is a actual fan connected. If you where at 128 C you would burn the cpu you probably talking Fahrenheit? Anyway to remedy any situation you would need to buy a fan and put it where there is a place to put it in you case and plug it into the motherboard it should say FAN 1 etc etc.. Good luck
Posted on May 15, 2009
SOURCE: What CPU can the Acer Veriton 5500 support ?
Below is your manual.. download it has all the info http://www.nodevice.com/manual/newmans/1152773920Veriton_x500-x500g_sgpdf/get10131.html
Also you are limited to only socket 478 P4's, any P4, would work...
Posted on Mar 05, 2010
ruwidperd372
  • 279 Answers
SOURCE: I dont have drivers on my acer veriton 3900 pro
You may go to internet station or use friend's pc to download the drivers, copy them to flash disk then install the driver to your pc. Go to this link to download the drivers:
http://support.acer-euro.com/drivers/downloads.html
Posted on Apr 26, 2010
merbuquis358
  • 94 Answers
SOURCE: Acer Veriton 3900 Pro - I have a green light on
If your computer no beep when starting just check the videocard and RAM or memory inside and remove it then clean with the pencil eraser or rubber in the pin and insert back again then try to power on your computer. If did not solve the problem just check your monitor if did not have a problem. But if your computer have a one beep when starting it means no problem on your computer. The problem is in your monitor it could be have a damage.
Posted on May 29, 2010
Recovering bios on acer desktop motherboard
Make sure your computer is off. try resetting the CMOS look on your motherboard and find what looks like a big watch battery about the size of a nickle take that out and leave it out for about 30 minutes and put it back in, that will reset BIOS back to default settings this should solve the problem if it doesn't you have problems elsewhere
Jun 23, 2013 | Acer Veriton 3600G PC Desktop
Acer Veriton M498g - ui3540c won't start
Need more info, Give as much detail as you can. What happens when you push the on/off button? Fan spin? LED's Blink? Any thing on the screen? Sound? Does the computer try to start and a second later shut down? Check the power cord, check the AC outlet? Is it on a UPS? Try AC outlet? Can you get to BIOS or Boot Menu? ETC.
Feb 14, 2013 | Acer Veriton M498G-UI5650W Desktop PC...
How to solve heating and shutdown problem while playing games or ani media
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jul 19, 2012 | Acer Aspire Notebook
Touch screen on acer z290 goes blank after 2 seconds
mine after few second turns off.
cpu remains cod and fan is working and nothing getting hot on matherboard.
Feb 23, 2012 | Acer Veriton Z290G 185 320GB
My computer shutdown automatically while i used it
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Jan 19, 2012 | Acer Aspire One PC Notebook
I have acer veriton series desktop, but i dont no what is my acer veriton model number. i need download drivers for this system. system s/n- AWC23GT164A136110LE. pls help me thanks vikram
it is difficult to download drivers if you do not have the model number, BUT you may be able to use one of these WEB sites that detect the drivers you need automatically and download the drivers for you.
Driver Detective
http://www.drivershq.com/Driver Guide
http://driverguide.comDriver Pro
http://driver-pro.com/related/english/device-driver-updates/?a=15810&gclid=CO6FoNDKtp4CFRhfagodEQhWlQ&hit=1&l=45
Apr 29, 2011 | Computers & Internet
Acer Veriton 3900 Pro - I have a green light on the front but the computer will not power up
May 13, 2010 | Acer-Veriton-M410-US3800P AMD Desktop PC -...
I dont have drivers on my acer veriton 3900 pro computer where can I get a dis. I can not connect the computer to the internet.
Apr 26, 2010 | Computers & Internet
I have a custom built computer w/ xp pro. my computer shuts its self off. why? sometimes it will do it 4-5 x a day, then there are days it won't do it at all. any suggestions?
Automatic shutdown can be due to mostly over-heating of the CPU or CPU fan not working properly. Blow the CPU areas plus the CPU fan with an Air-blower and check if the CPU fan is working properly or not. If the CPU fan is malfunctioning then replace it. Your system will work fine.
Make sure your system is free from virus and worms as it too can be the cause of  system shutdown (but this cases are very very rare).
That's it.
Mar 22, 2010 | Acer Aspire One Netbook 8.9" Notebook
Replace CPU Heatsink and Fan
okay as long as the heatsink fits it will work. socket type is for the processor. also dont forget the thermal paste. look up www.ribbitcomputers.com
Apr 29, 2008 | Acer Veriton 3600G PC Desktop
Computers & Internet Logo
157 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
