Question about Sony Handycam DCR-HC30 Mini DV Digital Camcorder
Can i charge my battery in camera thru my usb on my computer/
    Top Expert:
  • Sony Master
  • 74,243 Answers
No. You can't. Never attempt to charge it by USB port.
Posted on Feb 07, 2012
Camera wont connect to Computer thru USB, was OK, now not ! Camera screen displays connecting, but, waited for 10mins !, nothing on computer, but camera still trying to connect. With camera in off...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Aug 17, 2013 | Sony Cyber-Shot DSC-HX200V GPS Digital...
My dcr sr 80 is not charging
Depending on your camera, the battery may be able to be charged on the camera or by using a separate battery charger. Refer to the section below that relates to the charging method you are using.
Charging while the battery is attached to the camera:
  1. Make sure the battery is firmly attached and the AC adapter is securely connected.
  2. If your camera can charge the battery with a USB connection, use the built-in USB cable to connect it to the computer. If you use a USB charger instead of the computer, check the compatibility of the USB charger.
  3. Turn off the camera. The battery is does not charge if the camera is turned on.
Charging using the battery charger:
  1. If the CHARGE lamp does not light or blinks when charging, the terminals may be dirty. Wipe the dust away with a dry cloth and charge the battery again.
  2. Make sure the metal contacts on the battery are free of corrosion.
Dec 28, 2012 | Sony Handycam DCR-SR80 HD Camcorder
Can i charge an Olympus fe-4000 with a usb cable connected to my computer?
No. The camera does not incorporate any charging circuitry. You have to use the supplied battery charger to charge the battery. The USB cable is strictly for transferring pictures and videos to the computer.
Jun 28, 2010 | Olympus Cameras
My camera, M1063, will not turn on and the battery will not charge when I plug in the USB charging adaptor. I have only had the camera two months and it seemed to be working fine until a week ago or so. I...
The Camera should have came with a U-8 USB cable
Connect your camera to a Computer via USB cable and when it starts blinking green it means that it is charging
Charging thru Computer is way better....
Sep 22, 2009 | Kodak EASYSHARE M1063 Digital Camera
Cannot start camera
That simply means that the battery is dead. It lights up thru USB port as the port has charging facility. But battery being dead does not hold the charge. Change it.
Sep 12, 2009 | Vivitar VIVICAM 5188 PINK BNIB Digital...
Can i charge my garmin 255w thru my laptop
Yes you can,Connect your nuvi to a computer using a USB cable.The computer must be on for the nuvi to charge.A camera USB cable can be used to do this,or any USB cable that fits both the nuvi and USB port on the computer.
Jul 15, 2009 | Garmin nuvi 255W GPS Receiver
Charge
You need a separate battery charger for this camera. It does not have a battery charger built into the camera itself and can not be recharged thru any cords connected directly to the camera. The USB cords only transfer the files to the computer, they don't recharge the camera.
Dec 30, 2008 | Sony Cyber-Shot DSC-P50 Digital Camera
My camera is not charging
I got this camera from my friend's daughter. She told me she only used it a few times and won't charge. At first, I tried to charge it thru the USB port, got a brief green light then 3 red blinks just like others. So, I tried to charge it thru a powered USB hub and it charges. Once it fully charged, I took some pictures and tried to charge it again thru a regular USB (not the powered USB hub I used earlier) and it is charging right now. This is also true for a certain cell phones. If you let the battery drained its power completely all the way, you must charge it with a high current charger to wake up the battery before you can charge thru USB port.
Dec 22, 2008 | Kodak EasyShare M853 Digital Camera
Not charging
does the charging light come on. if it does the battery is charging is it plugged into a usb hub if so the camera will not charge. it has to be connect to the computers usb port directly.also some computers have a built in usb hub witch cause this to happen. try using the usb plugs in the back they are diffrent addresses. also check you cable for any damage. I thing about USB is they are touchy pains. I had to fully reload my computer twice because of a USB problem best thing to do is get a seperate charger for your battery and a memory card reader to transfer your pictures.
Jan 11, 2008 | Kodak Easyshare M753 Digital Camera
Open Questions:
See all Sony Handycam DCR-HC30 Mini DV Digital Camcorder Questions
Sony Handycam DCR-HC30 Mini DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
