Question about Technics Audio Players & Recorders
My 1200 Technics has a bad rca cable, how can i fix that?
  • 86 Answers
There fixable but its a pain, because it can short out at the fixed point, you could go to, radioshack, best buy or circuit city or any electronics store an buy one for like 5 - 11 dollers depending on the quality, if you get a gold plated it has better response
Posted on Oct 22, 2008
How to replace technics 1200 33 rpm speed button
open the unit from the back , remove all screw pull rca power cable through the major ugly abs and hard plastic board then you see beneath the knob at the underside a tiny pcb and the on/ off knob , Just unscrew the pcb and you can take out the button, very easy
Apr 29, 2014 | Technics Audio Players & Recorders
Technics 1200 mk3 distortion
nice table, but i need to know more info: distortion with only the record playing or also a sound with the unit only on, which cables do you use and did you have cleaned the rca cable and the sme connector(those 4 pins where you screw your om or concorde in) with cotton on a stick and the right cleaning stuff and push them a couples of times , to see if they come back easily, other wise a drip of lubricator for elektronics on them . greetings richard
Jan 10, 2014 | Technics SL-1200MK2 Turntable
Im not getting any sound out of my left rca, I cant install scratch live on the mac-pro, a vertical line appears on calibration...?
You need to have your RCA's replaced. If you are technically inclined you should be able to replace them your self. All you need is a soldering kit and a screw driver, and of course a new pair of RCA cables. You can use any regular pair of RCA cables. Cut them and strip out enough wire to solder them on. If you don't want to do that, then you can have it done at the shop and they usually just charge about $30.00 if that much. There's plenty of youtube videos that walk you through the process. Check out the videos by viperfrank. His videos helped me do this and change the light on my 1200.
Feb 12, 2011 | Technics SL-1200 Turntable
Technics 1200, no sound out right speaker
And it will be. I can almost steak my life on it. Easy to replace. Most djs had to already. Most off us went to Radio Shack and bought the 6 foot gold RCA's and cut them in half for both decks. Its not that hard to do. Any problems message me.
Oct 29, 2009 | Technics SL-1200MK2 Turntable
No sound from one channel
hi!change your rca connector..first..ok
Jun 07, 2009 | Technics SL-1200MK2 Turntable
New RCAS on Technics 1200 Getting a Loud Buzzing Noise
It is not suggested that you remove the ground cable. Performing the mod for the ground by soldering a bridge on the circuit board doesn't really do anything either than remove that buzz/ground hum. You've essentially removed the wire that grounds the turntable cabinet to the earth. The buzz is gone, but now your turntable is no longer grounded properly.
I would suggest replacing the ground cable to it's original state, then attach the Monster cables.
If this does not work, then either there is an issue with the soldering to the board, or the board itself might be damaged. You might want to look at the trace paths to make sure none are lifted, or damaged in any way on the board. Another issue might be faulty tonearm wires or not properly soldered wires.
FYI, monster cables are not good for this purpose. I would suggest the following cables:
MOGAMI RCA CABLES
- OPTiC
The ORIGINAL 1200 TECHNICIAN.
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 20, 2009 | Technics SL-1200MK2 Turntable
Computer not playing my technics table
More than likely the RCA cables need to be replaced. Torque, Serato, and all digital dj programs require a clear signal path coming from the source (turntable, cdj, etc). If it does not have a clear signal, or 1 side is louder than the other, it will not work.
You have to remember, these are analog turntables connecting to a digital system. The signal quality is different, and your RCA cables have to be prestine.
The following cables work very well for this type of configuration:
MOGAMI RCA CABLES
- OPTiC
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Feb 18, 2009 | Technics SL-1200MK5 Turntable
Technics turntable distortion emisson
More than likely your RCA cables are going bad, and will need to be replaced. Not the hardest self-repair, but you will need to have some soldering skills. In addition, caution should be taken when taking apart your turntable.
Check out the following videos for self-repair assistance on these wonderful DJ turntables.
If you think it's too much for you to do yourself, get some professional assistance. Shouldn't cost too much for repair.
Hope this helps some.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
Oct 16, 2008 | Technics SL-1200MK2 Turntable
Technics sl 1210 turntable
What sort of problem are you having with the cords?
Sep 04, 2007 | Technics SL-1210 Turntable
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
