Question about NetGear WGR614 Wireless Router
Wireless router WGR614 - Internet frequently disconnecting.its not remaining connected consistently so causing lot of discomfort.my laptop is Dell Inspirion 6400 - Windows XP SP2. Any solution will be appreciated highly.
    Problem Solver:
  • 11 Answers
It looks like you need to set the Idle Timeout to zero in the basic settings of your router.
Basic Settings:
Idle Timeout 0
Hope this helps
Posted on Oct 27, 2008
My router disconnect frequently
Question: the connection to router disconnects OR the internet disconnects,
If router disconnect: then try being in range, choose a better spot, keep router in a good spot,
If internet disconnects, cal ISP get it checked, make sure you run ping test to make sure its consistent , here is an example,
E.g:
open run: type cmd, hit enter,
type : ping google.com -t
hit enter, it should give regular pings without timeouts....if too many timeouts, internet service has issues,
call them and report..
Nov 29, 2013 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
My cisco/linksys router is having a lot of problems connecting wirelessly though my hard wired connection works just fine
Log onto your router and change the Channel that is used for wireless connections. There may be something that is using the same channel area and causing problems. I had wireless speakers that were causing frequent disconnects on my laptop because they were on the same channel.
If you have an Android phone you can download a free wireless scanning app that will let you see what is being used in your area.
Oct 06, 2013 | Cisco Computers & Internet
The internet in my CompaQ works fine, but i cannot seem to get it to connect to a Dell laptop.
It must be the wireless settings on your Dell. Go to wireless network settings and add manually the wireless profile for your wireless network
Jun 14, 2009 | NetGear WGR614 Wireless Router
Slow wireless internet connection for select PC's; fast for other
Make sure that your wireless mode is set to "mixed mode".
Intermittent Connectivity:
NOTE:
Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 20, 2009 | Linksys Wireless-N WRT150N Router
Internet connection disappears.
You may either need to do a firmware update, or reset it back to factory default, you can download the firmware from the netgear site, or you can log onto the router and do a reset of the router.
Hope this helps,
Daid
Mar 15, 2009 | NetGear WGR614 Wireless Router
The internet connection keeps disappearing.
Change the router's IP address to (192.168.10.1) maybe you have an IP conflict between the modem and router.
Mar 15, 2009 | D-Link DSL 300G+ (DSL-300G+) Modem
Netgear
There are two things involved in getting disconnected either your comp is getting disconnected or your router.
Instance 1
Computer getting disconnected connect your comp and router with ethernet cable if using wireless. Because at times it's not router but the wireless connectivity that gets loost.
Instance 2
Router getting disconnected...
Reset your router by holding the reset pin at the back of your router for 15 secs and lights will start flashing on router wait for 1 min you'll have router reset to default settings and now check that dsl or internet light on your router is flashing or static if flashing contact your isp issue with the line if static run the disc for router installation again and it'll remain connected after successful installation.
Apr 22, 2008 | NetGear WGR614 Wireless Router
Netgear Router WGR614 will not connect to internet
Looks like when you reset the router you have lost all yur configuration and back to the default factory settings.
Bridge the 5100 first.
1. In your web browser browse to »192.168.0.1 This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. Select Advanced from the blue buttons on the left.
4. Click the PPP locations button.
5. The modem may ask your for the Modem Access Code again. If so type it in again and click continue.
6. Select the radio button labeled, "Bridged Mode (PPPoE is not used)"
7. Click Save Changes.
8. A "PPP Location Warning" page will come up. Click "Change PPP Location."
9. A "Restart Needed" page will come up. Click "Restart"
10. Reboot your computer and and then connect the router
11.Configure the router for PPPoE using your ISP uid/pass
12.Configure your wireless using WEP
13.Desktop : Using Dell wireless client configure the client using the same SSID ,wep as configured in the router
Laptop : follow the same as desktop
(by default dell wirelesss client takes over the wireless configuration in dell pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | NetGear WGR614 Router
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
348 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
