Question about Panasonic CT-27HL14 27" TV
Why are the people blue on my television screen?
Just under 2 years ago I purchased a Panasonic HDTV. The last 6 months the people's faces have been turning more and more blue. I have tried adjusting the color hues and everything else I could, but to no avail. My warranty is up except for the CRT, but it expires in 5 days. I just wanted to know what the problem could be before I sent it in to get fixed. Thanks for your help!
    Novelist:
    Champion:
  • 275 Answers
If there is a warranty, even if only for 4 days, use it. Do not delay
Posted on Jul 31, 2006
I have a LG 32inch Flat Panel LCD that I purchased 2 years ago at best buy in canada. About 6 months ago periodically I would see vertical strips of see thru blue appearing on the screen. That continued...
The T-CON (Timing Control) board on the panel is/has failed. If it is available, it can be replaced. If not, the entire panel will need to be replaced to correct the TV.
May 07, 2010 | LG 32LG30 32 in. LCD HDTV
Blue spot on screen center. Peoples faces and show blue tint
if you have a Sony LCD projection ..Theres good chance optical block needs replacing .This spot will get bigger and will eventually cover most of screen the longer you use it .needs repair.If there is no warranty on this unit..I would estimate repair around 6- 8 hundred dollars ..
Aug 06, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Blue smear on the middle of my screen
I just had the same problem with my Panasonic 52' A serviceman came and up date some info inside the set, took out the blue and red spots. it was covered under warrienty. TV is 3 yrs old. Try to call your local service center, that what I did. Hope this helps.
Apr 02, 2009 | Hitachi 60V500 60" Rear Projection...
I have a Panasonic HDTV 1080i, We started to experience a yellow and blue arc at the bottom of the screen about a month ago. Last night the picture went black. Only the sound is left. What happened?
The convergence IC's are definitely bad. This is a big repair involving taking out the main board and soldering in two new IC's. They are not plug-in components and you would need a professional to do this job.
Mar 30, 2009 | Panasonic PT-53WX54 53" Rear Projection...
I have 2 panasonic tv's now have both green and blue spots present
Call Panasonic and they will schedule this problem to be corrected in home and pay for it.
Sep 09, 2008 | Panasonic PT-52LCX65 44" HDTV
My panasonic HDTV bbl 1080i was purchased about 6 or 7 years ago. The image shows two or three other images from the original image which are florence green and pink. So basically I see a triple image of...
I have a Panasonic PT-47WX53 rear projection TV and the picture was pretty dark for the last year but for game it was OK but know the blue is out of sequence, do I need to change the lamps?
And where to find them?
Jul 26, 2008 | Panasonic Televison & Video
Light green and pink spots on my hd tv!!!
Tiny particles of dust on the light engine lens can cause this (and was a service call for me about a month ago), or possibly the expensive light engine.
May 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No screen display - VIzio 50" Flat screen TV
If you purchased the TV 6 months ago, still under manufacturers warranty. They normally give customers 1 year warranty coverage.
It looks like the main board will have to be replace on this TV or fix to the component level.
Mar 21, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
NO VIDEO
I have a Samsung 50" plasma, that has been blacking out over the last 6 months. A 9/2005 set. Now its practically unwatchable as it happens 3 times in an hour. Its not heat related - I have a high volume 9" fan activated on TV power on. Turning the set offf/on usually makes it come back for a now short while. Considering to go put it in the back of my pickup and park it in front of Best Buy and discourage Samsung purchases. This is the 2nd Samsung TV I've purchased (the other a 32" tube) I gave to my folks a couple years ago and its gone bad as well. Samsung product may look good, but their video engineers are not.
Jan 19, 2008 | Samsung HP-R5052 50 in. Plasma HDTV
Blue haze around image, yellow streak
the tv color circuit is off frequency change the color ic take a look on the crystal that gives the 4.8.mhz burst could be that it needs to be replace dont rule out the video IF change the two ICs you mention.good luck.from the look of your tv screen that is my conclusion.good luck.email me at nicodhem@yahoo.com
Apr 04, 2007 | Samsung HC-P4241W 42" Rear Projection...
Panasonic CT-27HL14 27" TV Logo
138 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
