Question about ASUS P4S8X-X Motherboard
Motherboard / CPU mismatch - Would it work?
Here's a general queston. Just wanted to updated my knowledge.
My Motherboard has FSB of 533 MHz.
Would a CPU of higher (say 800 Mhz) or lower (say 233 Mhz) speed work on my Motherboard??
I wanted to go on aim and myspace put the only problem is i'm in the and it's blocked would you perhaps know what the unblock website is?
Posted on Oct 22, 2008
    Genius:
  • 1,605 Answers
CPU with 800MHz frontend-no
CPU with 233MHZ frontend-yes
it is going to be off sync.
may go to have some issue down the line, mainly sped issue, since the frontend want to run at 533MHZ anything close to it should be fine but not more than 10% difference. spec tolerance.
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
HP Pavilion Media Center PC not detecting memory in slots 3 & 4.All memory works in slots 1 &2.Memory is all the same.
Info from the manual:
Memory configurations
You can install 128 MB, 256 MB, 512 MB, and 1GB DDR SDRAM DIMMs into the DIMM sockets using the memory configurations in this section.
• Install only identical (the same type and size) DDR DIMM pairs
using the recommended configurations.
• Make sure that the memory frequency matches the CPU FSB
(Front Side Bus). Refer to the Memory frequency/CPU FSB
synchronization table on the next page.
• This motherboard does not support double-sided 16-bit DDR DIMMs.
• Do not create a three-DIMM configuration in dual-channel mode. The
third DIMM is ignored in the dual-channel operation.
Recommended memory configurations
Memory frequency/CPU FSB synchronization
* Use only identical DDR DIMM pairs.
Sockets
Mode DIMM1 DIMM2 DIMM3 DIMM4
Single-channel (1) Installed - - -
(2) - Installed - -
(3) - - Installed -
(4) - - - Installed
Dual-channel* (1) Installed - Installed -
(2) - Installed - Installed
(3) Installed Installed Installed Installed
CPU FSB DDR DIMM Type Memory Frequency
800 MHz PC3200 400 MHz
533 MHz PC3200/PC2700 400/333 MHz
Feb 18, 2011 | ASUS PTGD-LA Motherboard
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
Best/Fastest CPU for DFI PE21-EL mobo
Your motherboard supports 2 different fsb's.
look these up @ cpu-world
you can use:
Intel Pentium 4 processor (478-pin)
- 533MHz system data bus - supports up to 2.8 GHz
- 400MHz system data bus - supports up to 2.4 GHz
Intel Celeron processor
- 400MHz system data bus - supports up to 2.0 GHz CPU speed
and here are the suppoted cpus:
Intel Celeron RK80531RC029128 BX80531P170G128 1.7 GHz 17 x 400 MHz, Willamette Any A RK80531RC033128 BX80531P180G128 1.8 GHz 18 x 400 MHz, Willamette Any A RK80531RC037128 BX80531P190G128 1.9 GHz 19 x 400 MHz, Willamette Any A RK80532RC041128 BX80532RC2000B 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported RK80532RC045128 BX80532RC2100B 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported Intel Pentium 4 RK80532PC021512 1.5 GHz 15 x 400 MHz, Northwood Any A RK80532PC025512 BX80532PC1600D 1.6 GHz 16 x 400 MHz, Northwood Any A RK80532PC029512 1.7 GHz 17 x 400 MHz, Northwood Any A RK80532PC033512 BX80532PC1800D 1.8 GHz 18 x 400 MHz, Northwood Any A RK80532PC037512 1.9 GHz 19 x 400 MHz, Northwood Any A RK80532PC041512 BX80532PC2000D 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported RK80532PC049512 BX80532PC2200D 2.2 GHz 22 x 400 MHz, Northwood A 1.525V not supported RK80532PE051512 BX80532PE2266D 2.26 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PE056512 BX80532PE2400D 2.4 GHz 18 x 533 MHz, Northwood A 1.525V not supported RK80532PC056512 BX80532PC2400D 2.4 GHz 24 x 400 MHz, Northwood A 1.525V not supported RK80532PC060512 BX80532PC2500D 2.5 GHz 25 x 400 MHz, Northwood A 1.525V not supported RK80532PE061512 BX80532PE2533D 2.53 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PC064512 BX80532PC2600D 2.6 GHz 26 x 400 MHz, Northwood A 1.525V not supported RK80532PE067512 BX80532PE2667D 2.66 GHz 20 x 533 MHz, Northwood A 1.525V not supported RK80532PE072512 BX80532PE2800D 2.8 GHz 21 x 533 MHz, Northwood A 1.525V not supported
Dec 26, 2008 | DFI PE21-EL Motherboard
I have 810 bu mother board
your board is compatible with pentium 3 processors through the "coppermine" revision, the pentium 3 "tulatin is not supported" here is a list from wikipedia of the "coppermine" processors supported by your board.:
Coppermine
  • 100 MHz FSB: 500, 550, 600, 650, 700, 750, 800, 850, 900, 1000, 1100 MHz (E-Models)
  • 133 MHz FSB: 533, 600, 667, 733, 800, 866, 933, 1000, 1133 MHz (EB-Models)
Coppermine-T (the only coppermines with an attached heatsink)
  • 133 MHz FSB: 800, 866, 933, 1000, 1133 MHz
The Tulatin core is NOT compatible with intel 810 boards, and they can be easily confused with the coppermine-t's because they also have attached heatsinks.
Aug 20, 2008 | Intel SuperMicro SUPER Motherboard - 810...
ASUS P4S8X-X Motherboard Logo
199 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
