Question about IBM Lotus SmartSuite Millennium Edition 9.8
Lotus Notes Insufficient memory
Dialog 6246 2 insufficient memory - too many design elements (desk design pool_
2 Suggested Answers
Ezrahite
  • 2632 Answers
SOURCE: lotus smartsuite 9.8 millenium edition
Welcome to Fixya. To prevent this error from occurring, make sure the folder location into which you are installing Office has Full Control permissions for either the Everyone group or the SYSTEM group. Check the permissions for the parent folders because the permissions on these folders may also cause this problem. Right click on the folder or destination that you want to install the program then check the Security Tab if you have full control otherwise try to install it on a different folder or partition.
Thanks
Posted on Jul 24, 2011
Could someone help me with lotus notes issue?
Hello!
First of all try these steps
1 Open the "Start" menu and click "Computer" or "My Computer" depending on your version of Windows. Navigate to the C drive.
2 Open the "Notes" folder. Double-click on the "Notes.ini" file to open it in Notepad.
3 Place a semicolon (;) in front of the following two lines to temporarily disable VirusScan: AddInsMenus=NCMenu EXTMGR_ADDINS=NCExtMgr
4 Click the "Save" option from the "File" menu. Close Notes.ini. If the steps do not help you try to use Lotus Notes Fix Toolbox https://www.fixtoolbox.com/lotusnotesfix.html
Apr 26, 2015 | IBM Lotus Notes/Domino 6.5.3 (AH0LZNA)
Insufficient Memory in Adobe Illustrator
It is obvious your scratch disk does not have enough space. I would say that truth about the memory problem is the Very Critical Memory Bug that comes with CS4. You can try to disable all the apps that are running at the same time, but the problem can be still here. Installing of a current AI version might help. Also try to save a TIF of the image in Photoshop, it could be a quick fix to the problem. Or reduced the pixels number.
If nothing helps, use a special software that is able to recover it. There are a lot of on network, but unfortunately not all of them are so good. Try Recovery Toolbox for Illustrator https://illustrator.recoverytoolbox.com/
Oh, also i've remembered one method: Unlock all the layers and 'select all' and 'copy'. Than create a new doc and paste your image in there. Save the document with a new name.
Mar 25, 2015 | Adobe Systems Incorporated Illustrator CS4
How do i access my lotus Notes data to Outlook?
Lotus Notes to Outlook Conversion tool is an safest and secured solution to convert accurate and complete Lotus notes emails, calendars, tasks, journals, notes etc. Read more http://www.nsfpst.org/
Dec 10, 2014 | Microsoft Outlook
Spl-c error insufficient memory
Insufficient memory seems to be caused by printing large, complex images. Printing slightly smaller will often fix the problem.
Mar 05, 2013 | Samsung CLP365W Color Laser Printer
How to convert Lotus Notes Email to Outlook
I would like to advise you to try third party conversion utility to migrate your NSF file format into PST file format without any hassle. To know more about this utility you can visit here: http://www.export-notes-to-outlook.com/export-lotus-notes-email-to-outlook.html
Read more blog post: http://diskdatarecovery.jimdo.com/2013/01/23/migrate-and-access-lotus-notes-nsf-files-in-ms-outlook/
May 30, 2010 | IBM Lotus Notes (d53t7ll-bl) for PC, Mac
Hayward pool heater - p5 code
The code is "PS" for Pressure Switch and means there is insufficient pressure to operate (low flow) or the switch itself is bad.
May 26, 2009 | Hayward 116k HeatPro Heat Pump HP3100
Lotus mail client
clear.gif To configure the Lotus Notes client
  1. Click Start, point to All Programs, point to Lotus Applications, and then click Lotus Notes. Because this is the first time you have run Lotus Notes, the Lotus Notes Client Configuration Wizard starts. Click Next.
  2. On the Welcome page, click Next.
  3. When prompted, type in the name you set up for the user ID for Exchange Connector for Lotus Notes and enter the name of the user's home/mail Domino server. Select I want to connect to a Domino server. Click Next.
  4. On the How Do You Want to Connect to a Domino Server page, select Set up a connection to a local area network (LAN), and then click Next.
  5. On the Domino Server Network Information page, in the Domino server name text box, type the name of the Lotus Domino server that will act as a bridgehead between Exchange Server 2003 and Lotus Domino. In the Please provide specific network information to help locate this server dialog box, select TCP/IP. In the Server address field, type the hostname or IP address for the Domino server listed above, and then click Next. This server should be the one that you configured earlier.
  6. When asked if you want the User ID file copied to your data directory, click Yes.
  7. Type in the password for the user ID file.
  8. If prompted to set up Instant Messaging, clear the Setup instant messaging check box, and then click Next.
  9. On the Additional Services page, click Next.
  10. You will receive a message that indicates that Notes setup is complete. Click OK.
  11. Verify that the selected location is set to Office (should be displayed in the lower-right corner of the Notes client). If not, select the name displayed there and then choose the Office location.
  12. Exit Lotus Notes.
Mar 28, 2009 | Intel Motherboard
Insufficient memory
Check you disk space. [my computer] right click on Local Disk C. im a begginer myself, so i dont know much, and i cant help you a lot.
Apr 29, 2008 | Ulead VideoStudio 9
Insufficient Memory!
when i insert new memory card,i access 2 songs through bluetooth after dt it displays music player has not sufficient memory,wt wil i do...
Apr 16, 2008 | Ulead VideoStudio 9
IBM Lotus SmartSuite Millennium Edition 9.8 Logo
1,333 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
