Question about Mercury P4VM800M7 Motherboard
Power problem i have a problem of Mercury motherbraod that does not powered up
    Genius:
  • 1,605 Answers
Take every thing you have installed on the board off. power it up. if it comes up, install one item at a time and narrow the problem.
make sure your CPU is in correct orientation. and the power supply are correctly connected ot he board.
the fan on the CPU should come on when you power the board, and a indicator on the board should liteup.
if nothing happen. then you cooked the board.
Posted on Oct 22, 2008
Power lock failure on my 2002 mercury mountaineer
I think there has got to be a fuse for the electric locks. I would call a dealer and ask them where it would be located
Apr 05, 2014 | 2002 Mercury Mountaineer
2004 Mercury Mountaineer Power windows are not working. What could be the problem? The owners manual shows a large 30amp circuit breaker located under the hood. Could this be the problem?
they can go bad-swap it out with another that you don't need, just to try and see if it is the relay-listed are relays that might only control, for instance, the rear window defroster-generally, relays are all the same, some just get used heavily and some don't (i.e., ABS)-worth a try
Jan 27, 2011 | 2004 Mercury Mountaineer
Where is the power window relay on a 1998 mercury mountaineer?
technically you have three relays to worry about on these power windows
and all of them are behind the center of the dash in the RELAY box
May 15, 2010 | 1998 Mercury Mountaineer
My loptop is over charging in my LCD is not working
time to get a new laptop u have probably used it to death by haveing it sit on a flat surface while u wrked right weell u fried the fan systen then the motherbraod and thus here u are alas....
Nov 17, 2009 | Dell Dimension 4600 PC Desktop
1997 mercury villager with loss of power
2001 mercury villager engine looses power speedometer goes to zero<br /><br />
Aug 24, 2009 | Mercury Villager Cars & Trucks
2003 mercury mountaineer lose power when
Hi, maybe there's a problem in your starter or your battery consume more electricity.
NephetZ
Jul 08, 2009 | 2002 Mercury Mountaineer
2002 mercury mountaineer 4.0 starter relay location
The power distribution box is
located in the engine compartment.
The power distribution box contains
high-current fuses that protect your
vehicle’s main electrical systems
from overloads.
The starter relay is in position #56 of that box.
Mar 23, 2009 | 2007 Mercury Mountaineer
My Motherbraod no power
find the power switch wire on the power supply. (usually black and red, small connector). connect the 2 pints with a paper clip. see if the power puppl comes on. if it does, then, turn it off.
remove everyting that you have installed on the board. connect the power supply to the motherboard. make sure the CPU is in correct oriantation, turn on the PC. you should have the fan on and the indicator in the board lited. if not, try to run the board w/o the CPU. and if that still not coming on. then the board is cooked.
Oct 22, 2008 | Mercury P4VM800M7 Motherboard
Mercury P4VM800M7 Motherboard Logo
57 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
