Question about Whirlpool DU1301XTV Builtin Dishwasher
Reset buttons from whirlpool quiet partner II du1300xtvb
SOURCE: Dishwasher (whirlpool quiet partner II)
I think I solved the door leaking problem by cleaning out the plastic filter screen on the inside (left) door panel. Didn't even know it was there, never knew it was suppose to be cleaned! It was so clogged and gross. I also discovered that my washer had shifted and was off balance. It has wood shims under the steel casing and one block was loose. No doubt from slamming and banging the door open and closed. Had to take the front skirt and kickplate off to see. I had my son use a lever and hoisted it up a little while I replaced the block shim now making the washer level again. Ran a light wash before fixing problems and it leaked. We ran a light wash after the fix's and so far so good. Haven't ran a regular longer wash yet. My water level was fine, no gasket problems, no washer wand cracks, etc... My husband was thrilled! When he came home, I informed him I have good news and not so good news. The not so good news was dinner was going to be late, the good news was I fixed the leaking (for months!)dishwasher and saved alot of money on repairs!
**Cleaned filter screen, made dishwasher level again.
Posted on Sep 09, 2008
SOURCE: Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Posted on Nov 23, 2008
SOURCE: whirlpool dishwasher # quiet partner II
THIS WORKED FOR ME!
push" heated dry",then "normal" then" heated dry" then "normal"--it worked like a charm..did the happy dance,washed dishes and saved $130.00!!
Posted on Jan 26, 2009
Take the back of the door off and remove the panel where all the wires lead to. If you look at the handle that holds the door shut there are 4 wires on a connector there on its switch. There should be a brown one. Follow that wire back and about 12 inches later there is a little switch it connects to. That switch is your problem. Remove both wires connecting to it, splice the 2 wires together and your dishwasher should work fine until you get the actual replacement part. If not you can just leave the wires spliced and it will still work fine. Hope this helps.
Posted on May 30, 2009
tbirdfan1
  • 3051 Answers
SOURCE: My Whirpool Quiet Partner III has no power. I
Hello there: It doesn't work at all If your dishwasher doesn't work at all, check these: Door switch Wiring Timer or selector switch Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker. Door switch
The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors. Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Posted on May 16, 2010
Lock light stays on my whirlpool quiet partner II
If pushing and holding the lock button till the light goes out doesn't work, you likely have a problem on the circuit board.
May 24, 2014 | Dishwashers
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Whirlpool quiet partner ii dishwasher has quit working. Power is getting to the dishwasher but it is not coming on at all. There is water standing in the bottom of it and a very foul smell is present.
This dishwasher has a thermal fuse that attaches to the main control board that may have failed, it can be tested with a meter for continuity if it does not have continuity then it is your problem.
Apr 21, 2012 | Whirlpool Dishwashers
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner 980
Bad control board ,replace it.
May 26, 2008 | Dishwashers
clean light blinkin???? ry pushing the sanirinse-heated dry--sanirinse--heated dry. tha tshould put in diagnostic mode, there also should be a trouble shooter underthe lower acess panel
Apr 09, 2008 | Dishwashers
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 26, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool DU1301XTV Builtin Dishwasher Logo
195 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
