Question about Bosch HBL 5056 Electric Double Oven
Double ovens model hbl 53/54/55/56
The fan in the top oven keep running when turned off
  • 116 Answers
SOURCE: Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Posted on Mar 11, 2007
SOURCE: Bosch HBN 455 Oven Cooling-Fan Issue
After the oven is switched off, the after-run of the cooling fan is controlled by an electromechanical thermostat switch. The fan can switch back on, due to residual oven heat that accumulates within the oven's outer case and reactivates the cooling fan temperature switch. Considering yours is making buzzing sounds and activates on and off, the fan's thermal switch may have dirty contacts or just be defective and require replacement.
Posted on Oct 02, 2007
SOURCE: Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Posted on Dec 11, 2007
ginko
  • 19396 Answers
SOURCE: Bosch oven won't pre-heat/heat with door closed
Some oven has a door sensor, which prevents heating when door is open, evidently this is faulty, you need a service manual to identify and replace the part, If I find something I will post here.
Posted on May 24, 2008
barkencoa
  • 3463 Answers
SOURCE: bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Posted on Dec 17, 2008
F31
If the cooling fan is constantly running then means thermal overload probably faulty, it has failed in closed position.
Best to get an engineer to help
warmest regards
Richard the Repairman
Mar 30, 2014 | Bosch HBL 455 Stainless Steel Electric...
Tip
Common heating faults with Bosch HBL 455 Stainless Steel Electric double oven
For all Free appliance repair videos visit our VIDEOTUTORIALS 1, If the Bosch fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the BOSCH element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your BOSCH fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 455 Stainless Steel Electric...
I think the bearings have worn out on the fan in my oven,are replacement parts available?
We have the cooling fans in stock for the upper and lower ovens. Enter your model # at www.appliancehelponline.com. Select your part diagrams will also come up. All parts come with installation instructions.
Sep 18, 2010 | Bosch HBL 755 Stainless Steel Electric...
Top ovan will not start when I put ovan on the blower does not wo
the problem is not the motor. You have a problem with the door switch or the operator interface.
May 04, 2010 | Bosch HBL 455 Stainless Steel Electric...
We have a neff double oven and the bottom oven wont heat up, the fan works ok but no heat???
If the fan is working o/k, then it it is likely to be the oven element that has failed.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thankyou.
Jan 30, 2010 | Bosch HBL 5052 Electric Double Oven
HBL 5056 Top oven 200º low
Can you be more explicit by what you mean by saying top oven 200 low?
Jan 16, 2010 | Bosch HBL 5056 Electric Double Oven
Bosch Double oven - top oven will not open - seems like it is locked
i am not aware of a bosch oven that locks the top door usually only main oven will lock if self clean pyro oven,the small oven never has this feature sounds more like a hinge problem check nothing is fouling the lower part of the oven door.
Dec 30, 2009 | Bosch HBL 755 Stainless Steel Electric...
Oven works when it is open
sounds like the oven door switch got bent or misaligned
Dec 20, 2007 | Bosch HBL 5056 Electric Double Oven
Oven
oven has two fans. the second fan is out of sight and cools the casing. it is operated by a seperate stat. not unusual for it to run for up tohalf hour after switching off. if it runs for an excessive time may be a fault nwith fan stat
Mar 20, 2007 | Bosch HBL 5056 Electric Double Oven
Bosch HBL 5056 Electric Double Oven Logo
54 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
