Question about Mercury P4VM800M7 Motherboard
My Motherbraod no power
I have a problem of my motherbraod with no power i think it was damaged by electric fault
    Genius:
  • 1,605 Answers
Find the power switch wire on the power supply. (usually black and red, small connector). connect the 2 pints with a paper clip. see if the power puppl comes on. if it does, then, turn it off.
remove everyting that you have installed on the board. connect the power supply to the motherboard. make sure the CPU is in correct oriantation, turn on the PC. you should have the fan on and the indicator in the board lited. if not, try to run the board w/o the CPU. and if that still not coming on. then the board is cooked.
Posted on Oct 22, 2008
I have a crosley lcd tv, model #c42fhdhb120, and I think it was damaged by lightning. The power light comes on when pressed but it does not advance. Do you think it is repairable? What possibly could...
In most cases the motherboard found damaged due to lightning. It is repairable. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Aug 22, 2013 | Televison & Video
What is wrong when a malfunction indicator light comes on is it serious ?
It is only serious if you think that potentially getting stranded on the highway or damaging expensive parts of your car is serious. The light is what it is...a malfunction indicator light. It is telling you that one or more of the critical systems that your vehicle is equipped with is malfunctioning.
Jan 23, 2011 | Hyundai Accent Cars & Trucks
Jvc sxpw650, my house was hit by lightening and now my sub makes a loud noise and the receiver which was grounded reads overload after the speakers work for a few seconds! please help? can i just replace...
The reason it goes into overload is due to the fact that the power amp section parts have developed a short and thus causing an overload in the power supply. The affected parts need replacing and I rather suspect that the subwoofer amp section has also developed a fault. I rather think with the lighting damage that you might have to replace the lot! And not just the subwoofer!! If your house was insured replacements might be covered by that. If not you sound like your in for a big bill!
Jun 22, 2010 | Audio Players & Recorders
POWER CRAFT BY Karcher bought Aldi on 31Mar 05.2100Watts 130 bar.
You did winterize the machine? Leaving water in a powerwasher will freeze and damage the pump. It's a common happening, because people don't think of it or are not told by the maker.
Apr 29, 2010 | Karcher K2.26 Electric Power Washer
Tolerance of ingenico i6550 to electrical fault
We have i6580's and they have a theft protection feature that if they get slammed the screen will go black but the green power light is on. When this happens they need to go back to the factory to be reset. If the green light is off and the screen is blank they are not getting power. Check the cable connections. Also, sometimes the USB cable gets damaged which will cause connection failure.
Apr 08, 2010 | Ingenico I6550 (6550US0041)
BOOSTER CABLES WERE REVERSED-----HORN SOUNDED----HAD BATTERY TESTED----IT IS FULLY CHARGED----HOOKED CABLES BACK TO BATTERY---NO POWER
This vehicle electrical system was made to run on negative ground. Connecting The battery up backwards destroys electronic components in a flash.
If you are lucky and we mean real lucky you may have burned up the fusible link powering the electronic system.
RECOMENDATION:
Seek professional help.
Put this car in the shop. there will be many more electrical problums that need to be addressed.
We do not think it will easily recover from this.
We are Sorry that we can not provide you any better news, But we have seen this one before and it never works out well.
Hope this tip helps to solve your problem
R/
David
Feb 26, 2010 | Kia Sportage Cars & Trucks
My loptop is over charging in my LCD is not working
time to get a new laptop u have probably used it to death by haveing it sit on a flat surface while u wrked right weell u fried the fan systen then the motherbraod and thus here u are alas....
Nov 17, 2009 | Dell Dimension 4600 PC Desktop
My Lakewood HV2 fan just stopped working.
You have a few areas it may be -
Supply interrupted - fuses, cables, switch.
Control damaged - Power transistor or other component damaged.
Motor fault - Electrical contact worn or coil wiring shorted or open.
You will need to safely remove the unit to bench test it in these areas to locate the fault - as it could be any one of these.
Aug 21, 2009 | Dryers
LG M8003L Air Conditioner does not power on
i think there may be damage to a small electrical component in the circuit board which probably fried just before breaker popped open
Aug 12, 2009 | LG M8003L Air Conditioner
Power problem
take every thing you have installed on the board off. power it up. if it comes up, install one item at a time and narrow the problem.
make sure your CPU is in correct orientation. and the power supply are correctly connected ot he board.
the fan on the CPU should come on when you power the board, and a indicator on the board should liteup.
if nothing happen. then you cooked the board.
Oct 22, 2008 | Mercury P4VM800M7 Motherboard
Mercury P4VM800M7 Motherboard Logo
Top Mercury Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Mark Taylor
Mark Taylor
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
