Question about Rosetta Stone V3 German Level 1-2-3 Personal Edition (Win/Mac) for PC, Mac (1580229085)
Rosetta stone problem 9119 - Rosetta Stone V3 German Level 1-2-3 Personal Edition (Win/Mac) for PC, Mac (1580229085)
    New Friend:
I have 9119 error problem and the add time of languages.,,
plzzzzzzzzzzzzz help me
Posted on Apr 23, 2013
SOURCE: Rosetta Stone Microphone Not Found
This worked for me:
1) Right click on the Rosetta Stone icon in the Start menu
2) Click the "Compatibility" tab
3) Set it to run in compatibility mode with Windows Vista SP2 (mine was defaulted to run in XP compatibility mode, which seemed to be the problem)
4) Start the program again, if you are lucky all mics will now show up
Posted on Jul 20, 2010
  • 10 Answers
SOURCE: rosetta stone won't recognize my logitech headset
Make sure that your device is set as your default device by making sure that there is a green check mark next to the device. If not, right click and select "set as default device" (or something like that... I have vista and not win7)
If that does not work, right click on the headphones and go to "Properties" then go and under the "General" tab, change the name of the device to "Microphone HS" For some reason, Rosetta Stone does not recognize the headset unless it has the word "Microphone" in its name... Kinda stupid if you ask me. Hope that helps...
Posted on Mar 03, 2010
taran_2005
  • 10515 Answers
SOURCE: Off Ebay, I purchased Rosetta Stone for Mac,
This usually confirms that there is a problem with the product. Have you tried to contact the seller?
On Ebay, there is a buyer's protection policy. You could go to ebay and file a dispute and leave negative feedback for the seller. This would be a big hit to the seller. Moreover, you always have an option to dispute the charge with the credit card company. Unfortunately, these are the only way to resolve the problem.
I wish i could have a better solution.
Thanks and Regards
taran_2005
Posted on Apr 15, 2011
SOURCE: I fave a microphone in my web camera. And Rosetta
I solved by going to Control Panel, Sound, Recording, then click on your mic and click on Configure, and then Set up microphone... Thats probably going to fix your problem... That easy... xD
Posted on Apr 27, 2010
  • 10 Answers
SOURCE: my rosetta stone cannot or will not recognise that
The disk may be defective or there may be other problems that cannot be diagnosed given the information that you have provided. The best solution would probably be to call Rosetta Stone's free tech support directly at 1-800-767-3882. They can provide step by step problem solving and can help you find a solution.
I need the activation codes for rosetta stone Latin America Version 3. I think I have the 2007 Rosetta stone program set up.
You will find the activation code inside the box on a small card, If you don't find it contact Rosetta Stone with your Order number to get new one.
Thanks,
Questions Rosetta Stone Community
Dec 09, 2014 | Rosetta Stone V3 Spanish (Latin America)...
Rosetta stone 9114 on mac
You get Error 9114 on Rosetta Stone if you have a bad disc or secutity settings. Find the fix at Questions Rosetta Stone Community
Jul 02, 2014 | Rosetta Stone 3 Farsi Level 1 2_3 Set Full...
Error 9119 rosetta stone
When you install Rosetta Stone it puts its language files in a different folder. When you uninstall the program the language files are left intact and are never touched. If a problem occurs and one of the language files becomes corrupt and unreadable you're going to get that error 9119 every time when you try to re-install your language pack. Each language level has THOUSANDS of files in hundreds of sub-folders. Each file in those sub-folders has an hexadecimal name of 40 or more characters in length. So good luck trying to find the corrupt file(s). Also, because the file or files are corrupt, they can't be read or deleted. You're going to have to perform chkdsk on your hard drive to recover the bad sectors...eventually. The quickest and simplest way to fix your Rosetta Stone problem is to rename the folder where it puts its language files to something else. On an xp system the default name is "C:\Documents and Settings\All Users\Application Data\Rosetta Stone". I changed mine to "C:\Documents and Settings\All Users\Application Data\Garbage Files". That way when Rosetta Stone goes to install its language files it will recreate the folder cleanly instead of trying to overwrite the old folder and its corrupt files. That will solve your problem. You can then run chkdsk at your leisure. Good luck and spread the word.
Dec 05, 2013 | Rosetta Stone V3 Spanish (Latin America)...
Error 9119 rosseta stone
When you install Rosetta Stone it puts its language files in a different folder. When you uninstall the program the language files are left intact and are never touched. If a problem occurs and one of the language files becomes corrupt and unreadable you're going to get that error 9119 every time when you try to re-install your language pack. Each language level has THOUSANDS of files in hundreds of sub-folders. Each file in those sub-folders has an hexadecimal name of 40 or more characters in length. So good luck trying to find the corrupt file(s). Also, because the file or files are corrupt, they can't be read or deleted. You're going to have to perform chkdsk on your hard drive to recover the bad sectors...eventually. The quickest and simplest way to fix your Rosetta Stone problem is to rename the folder where it puts its language files to something else. On an xp system the default name is "C:\Documents and Settings\All Users\Application Data\Rosetta Stone". I changed mine to "C:\Documents and Settings\All Users\Application Data\Garbage Files". That way when Rosetta Stone goes to install its language files it will recreate the folder cleanly instead of trying to overwrite the old folder and its corrupt files. That will solve your problem. You can then run chkdsk at your leisure and delete the Garbage Files. Good luck and spread the word.
How do I install Rosetta Stone on my iPad?
Go to Rosetta Stone. Click the little box on your safari browser. Click add to home screen for a great shortcut almost like an app :D
Jan 21, 2013 | Rosetta Stone Computers & Internet
Error 9119, 9114 rosetta stone
Dec 29, 2012 | Rosetta Stone Computers & Internet
Rosetta stone error 9114
I'm using Windows 7 and was getting the 9114/9119 "minor error" when trying to install the language files. I copied my files to a flash drive, tried adding exceptions to my AV software (Microsoft Security Essentials), both to process and extension, no go. Then I tried setting the program to run in Compatibility Mode, and lo and behold it worked.
Steps: right-click on the file, click Properties, then the Compatibility tab, and check the box to run in Compatibility Mode.
Hope this works!
Apr 12, 2012 | Rosetta Stone V3 Spanish (Latin America)...
There is an error with this application
I started getting "Error 2123" recently, and spent A LOT of time searching for the fix. Here is what finally worked:
Find the hidden file "tracking.db3". It's in the hidden folder "ProgramData/Rosetta Stone" under the "C:" directory. Copy and paste it to the Rosetta Stone install directory (Program Files/Rosetta Stone).
Error 2123 should be gone, but now there will be Error 2125. So, in the Rosetta Stone install directory, run the "service_installer" .exe file by double-clicking it.
Nov 23, 2009 | Rosetta Stone V3 Spanish (Latin America)...
Rosetta Stone error 2123
1.)Open BitDefender Antivirus in Expert Mode,
2.)click on the Antivirus module
3.)under the Shield tab click on the Advanced Settings button.
(BitDefender Active Virus Control Settings window should be displayed)
4.)adding an exclusion for Rosetta Stone solved the problem
or
If you have any other antivirus software
adding an exclusion for Rosetta Stone solved the problem.
Jun 16, 2009 | Rosetta Stone V3 Spanish (Latin America)...
Open Questions:
Rosetta Stone V3 German Level 1-2-3 Personal Edition (Win/Mac) for PC, Mac (1580229085) Logo
1,646 people viewed this question
Top Rosetta Stone Computers & Internet Experts
vince
k24674
Vladimir Frolov
Are you a Rosetta Stone Computer and Internet Expert? Answer questions, earn points and help others
