Question about Bosch Dishwashers
Smv50e00gb my dishwasher has stopped working. When i try to set it going it sounds like it is working then it sounds like a grumbling noise and then stops and bleeps that it has finished
SOURCE: ignis dishwasher model no. adl 347
I have the same problem. Having spoken to an engineer I have been told that the controller has gone. £120 for a new one plus fitting. So you are looking at a £200 bill to repair. Not worth it ???
Posted on Jul 16, 2008
SOURCE: SMEG DI 612CA. Dishwasher
Pisss!!! Comin from my asss!!
Posted on Jul 24, 2008
huuum
  • 750 Answers
SOURCE: dishwasher problem
Hello ramsey06,
Welcome,
You said , dishwasher starts everything is going OK. the water is going but then it stops and does not finish.
First: this is what Whirlpool says!!
And after this Is what the repair manual says when I looked it up for you!
Dishwasher is not operating properly
1.Dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
2.Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
3.Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
4.Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
5.Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
6.Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
7.Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
___________________________________________________________
BUT, the repair manual says this
Faulty Pump and Motor Assembly Some models that will not wash or drain often have a faulty Pump and Motor Assembly. If the motor is receiving power from the timer and it is not operating that is the case.
Temporary Work-around:
With the power turned off to the unit, sometimes it is possible to manually rotate the cooling fan on the motor assembly. In certain situations where the dishwasher has set idle for a period of time, this may free the bearings enough that the unit will begin to operate. Where this works as a short term solution in some cases, it is often a sign of things to come. The frequency of the motor seizing will increase until it will simply no longer work.
I think this is a hands job that needs service and hands on attention!
I hope it's not the motor or pump!
How old is the machine?
If they tell you it is an expensive motor then you need to know this!!!!
Here is an article I just read!
If the dishwasher is old it will not pay you to repair the
Here is an interesting report I just read!!!!!!!!!!
Repair or replace?
When to pull the plug on your old dishwasher
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your dishwasher,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your dishwasher is under warranty or less than four years old ,
paying for a repair makes sense.
Note that dishwashers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your dishwasher is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new dishwasher.
Data also shows that it doesn't pay to fix a less-expensive dishwasher
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of dishwashers you replace are likely to end up in a landfill.
Let me know how it goes!
Thanks for giving me the opportunity to help!
Huuum
Please do not forget to give a rating before you sign off!
Posted on Oct 20, 2008
  • 7 Answers
SOURCE: kenmore dishwasher has loud noise during fill.
This isn't a solution but rather a comment, if the problem is happening only during the fill, then it could be the water inlet valve. Perhaps there is a soliniod going in the valve, watch to see if the fill cycle starts to dimminish over time. Does the sound come anytime the washer fills, ie: rinse cycle? if so I would replace the valve, probably 50 dollars would get you a new one and you can do it yourself to save a little more cash. good luck.
Posted on Apr 20, 2009
  • 457 Answers
SOURCE: My whirlpool dishwasher is not releasing the
your machine should only get hot water going into your machine .that is the problem right there,chek faucet temp then start machine must be hot going in.the tablet even if was dropped will not dissolve in cold water. let me know if i was helpful to you
Posted on Feb 27, 2010
Grumbling noise in front drivers side of car.Worst at 30-40 mph.
Sound more like the wheel/hub bearing. An axle will usually make a clicking noise when turning, and be quiet when going straight. It probably wont break by may but it may get louder. Get it checked asap.
Apr 23, 2010 | 2000 Chevrolet Cavalier
Stopped working normally, makes low grumbling noise
have a look at the glass plate rollers first if there sticky free them off, but if the noise is from the inside of the microwave its likley to be a short in the mains coil witch case dont even think of fixing it
it would be far cheeper to buy a new microwave insted
a word of warning,,, dont think you can fine an easy fix for it, if its an internal fult, and dont go tinkering inside of it, there is very high voltage inside this microwave it can kill you if you tuch the wrong part have ever seen a police stun gun working???????
it realy hurts you,,,
your microwave has the stun guns very big brother inside of it,, it dont stun,, it kills!!!!
best to plat it safe dump it and buy a new one
there only about £50 today
so is your life worth more than £50???????/
Oct 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Just had a new 3.5 Ton Goodman GSZ13-13 SEER, heatpump installed. Its working OK in Cooling, however whe switched over to heating mode the indor unit makes a loud grumbling sound. The installer stated that...
I install them every day and I have not had one make a loud grumbling sound. Sounds like you might have a low voltage (Thermostat) wiring problem. The only thing different inside the indoors unit from heat and cool is the fan speed, electric heat when on. The fan might be loose or out of balance and it only shows up at low speeds. Either way, the noise is not normal.
Oct 13, 2009 | Goodman CLQ36AR49 Air Conditioner
Grumbling Noise
yes it could cause the noise also having 80% tread is not good on the transfer case as it will constantly be putting stress on it. replace your fronts with matching tires and the noise should go away
Jun 11, 2009 | 2000 Ford Expedition
Will not wash
sounds like the circulating pump. could be a foreign object stuck in the pump impellor. could also be the pump capacitor - cheap part
Sep 03, 2008 | Kenmore 24 in. 16693 Built-in Dishwasher
Refridgerator
There is fan in the freezer behind the metal cover. Try to stop the fan, and see if the the noise stops... If the noise stops then its possible that the fan is out of balance. If this is not the case then i would suspect that this is problem with the mainboard.
Jul 09, 2008 | Jenn-Air JCB2059G Bottom Freezer...
Dishwashers Logo
175 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
