Question about Broan-NuTone Dryers
How do I change the bulb in Broan 678 fan light combo?
Fan light combo Broan light bulb - how to change light bulb?
SOURCE: replace shower fan motor in a Broan model 678
I need to get the cover off of a BROAN fan and light kit. The two solutions listed did not provide me with sufficient information. Thanks!
Posted on Jul 02, 2009
  • 87 Answers
SOURCE: how do you access the light on a broan
Gently pull down, work it down slowly these tend to get dry over time and crack, If you do not see any exposed screws it is the basic pull down type. Not to insult your knowledge but make sure the fan is not on when you do this because the blades will be exposed.
Posted on Oct 09, 2009
Testimonial: "Didn't exactly correct, but I looked further and found 2 screws. "
omaromid
  • 332 Answers
SOURCE: How can I change the light bulb in this fan. The
They have opening clips on the top side all around the cover, you can reach it with your fingers and try opening them all, the cover will come off easily, once done you can unscrew the light bulb and install a new one.
Posted on Feb 07, 2010
SOURCE: Replace motor in Broan 678 bathroom fan
I ran into the same problem, Lowe's carries Broan exhaust vents. They had both a replacement motor for all generations of 678 fans for $18, and they also had the latest generation of the complete unit for $40. I bought the complete unit, which included the fan I needed. Just unbolted it from the new bracket and bolted it to the old one. The new light housing, trim piece, and lens also interchanged. The existing one was old and yellowed, so this made for a huge improvement. All done from in the living space as well.
Posted on Aug 01, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Broan Bathroom light fan combo. The fan
Either the plug came out, the receptacle wiring came loose or the bulb is out,,,
http://www.fixya.com/support/r6871896-broan_bathroom_fan_care_cleaning
heatman101
Posted on Nov 17, 2010
CHANGE LIGHT BULB I BATH FAN
According to Broan's site - the model you specified has no light bulb - check specifications - you can search the site for the proper model and download the instructions.
http://www.broan.com/products/product/4108f1af-c993-4327-982f-1174f091fd6f
Apr 12, 2014 | Broan-NuTone Broan 110 CFM Premium Bath...
Replacing light bulb
Gently pull the light lens away from the housing. It has two tabs holding it in place, it would help to gently squeeze on either side of the lens and pull down. Once the lens is removed you should see the bulb plug. See the website below for the diagram
http://www.broan.com/ImageLibrary/broan/pdf/InstallGuides/99042908.pdf
Mar 05, 2011 | Broan-NuTone Designer 721 Ceiling Fan
I purchased a Broan 744 light/fan combo. I want to wire the light and fan to separate switches. Do I use single pole switches and how do I wire up the switches?
Here is a link to the instruction manual. Page three shows a wiring diagram for separate switches.
http://www.centralvacuumstores.com/meta/pdfs/info/744NT+Installation+Guide.pdf
This is the Switch NuTone Broan recommends for that fan.
http://broan.com/display/router.asp?ProductID=2949
Nov 18, 2010 | Broan-NuTone N-763RLN Combination Light...
Installing Broan exhaust fan/light/night light model QTR070L. Am connecting with a single switch power source. Fixture has three whites, one blue, one black, one red and the ground (green). In what color...
Hi .. with only bone switch for this combo unit, the connections would be like this .. all ahites together with the romex white , all colors, red, black, blue with the romex black, all greens together IF you had more than one switch , then the red, black, blue would be connected separately to one switch eack and separately to a 4 wire romex from the switch to the combo unit.
Apr 17, 2010 | Broan-NuTone Broan 110 CFM Premium Bath...
Feb 07, 2010 | Broan-NuTone Broan 110 CFM Premium Bath...
Broan square bathroom fan light combo, no screws - how do I change the bulb?
The entire vent panel and light lens is held up against the ceiling by two spring clips mounted on 2 sides of the panel.
To find which two sides they are one, (they're opposite of each other), just pull on one side with your finger tips and when you see the wire spring clips, just pull down on the two sides where they are so you can get to the bulb socket.
The panel will pull down about 5-6 inches you can then either get at the light bulb, or lift up the light lens to clean it and get the bulb out.
Be sure to replace the bulb with the proper wattage bulb so you don't overheat and melt the lens in the unit.
When you're done, all you do is push up gently on each side to get the panel back in place. You might have to squeeze the wire retaining clips to get them back in, but they'll go back OK.
If you want to completely remove the cover panel, you just squeeze the retaining wire clips nearest the fan enclosure on each side and that will let you take it all the way off for cleaning, etc.
Hope you find this Very Helpful and best regards!
Sep 24, 2009 | Broan-NuTone Broan QTXE150FL Bathroom...
Dryers Logo
424 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
