Question about Uniflame 200209 Open Flame Patio Heater
Patio Heater constantly goes out for no apparent reason
I have a Patio Sense heater that worked great for about a year and a half. Now it will light and burn anywhere from 3 minutes to 10 minutes and on rare occasions - an hour and then just cut off and not relight for 10 or 15 minutes. I have cleaned with air and tried multiple tanks to no avail. Patio Sense says I have to spend 80 bucks plus shipping and buy a whole new head. Any one know of a less expensive way to fix this problem? Thanks
    Problem Solver:
  • 9 Answers
I wrote this for another person with a heater problem and thought it may help you as well.
Before you go changing parts, clean up the pilot assembly. When you heat metal and let it cool and heat it again it causes it to corrode. Also for some reason these areas seem to attract little spiders who make their homes here. This causes gas flow problems which in turn could affect the size and direction the pilot flame. For if it does not touch the thermocouple, thermopile or whatever that little thingy is called that tells the gas valve to allow the gas to flow...it will not tell the gas valvle to let it flow. Remove the corrosion, spiders, spider webs and any other insects then sand the thermocouple, thermopile or whatever that little thingy is with a rough sandpaper to remove corrosion. It will likely work after that.
I had them do the same thing. The gas flow problem caused a week pilot. Any slight breese pulled the pilot off of the thermocouple and out it went.
Pull the gas line off of the pilot and make sure you have good gas pressure when you press the pilot button. If you feel, hear and smell it it is good gas pressure.
Posted on Mar 24, 2010
Patio heater goes out
If your patio heater goes out when you turn on the pilot and let go, this is usually a worn thermocouple. They last between 1 year (if you are unlucky) up to 6 years and are a consumable item. Found this site very useful patio heater problem solving.
May 24, 2012 | Dayva HS041 (LP) Open Flame Gas Patio...
I have a Kirkland patio heater model # PTH-106SS-3G the pilot will not stay lit. Do I need to replace the whole pilot assembly
Hi, If the pilot light goes out when you turn the gas knob to full power on lighting them the most likely cause will be a worn thermocouple, these usually last between 2 years up to 6 years. Found this site very helpful, patio heater problem solving. They have a few solutions to checking patio heaters.
Oct 12, 2011 | Williams 2509612 Ceramic Mid-Size Heater
Pilot on my patio heater will not stay lit. goes out when i release the knob
If the heater is the same as this type of patio heater and it lights on pilot and goes out it is generally a worn thermocouple. These are designed to switch off the patio heater when something is wrong, changing one fixed 90% of the problems. Sometimes it can also be caused by a worn tilt switch but always start with the most likley and work backwards. Found this site very useful, patio heater problem solving page.
Jan 04, 2011 | Stainless Garden Sun Steel Propane Patio...
Fire sense patio heater won't light...
you prob need a new theromocuple on your pilot or just cleen it with sandpaper this may help
Apr 14, 2010 | Fire Sense 01775 Patio Heater
Patio comfort heater won't light
Sometimes you have to completely disassemble the pilot assembly to clear the blockage, the orifice for the pilot jet is very small and you can not get directly to it unless you take it apart. If this does not help, you may need a new valve.
Jul 12, 2009 | Stainless Patio Comfort Natural Gas Steel...
Patio Heater
The pilot light has to heat up the thermocouple. Is the thermocouple in the flame? If so, the them. could be bad. Replace
Jun 28, 2009 | Endless Summer 1501 Patio Heater
Charmglow patio heater
Looks like the knob or the contacts are faulty.
Nov 07, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Well, I just went out this morning and worked on the heater after it would not light last night. Turns out that a spider or moth set up camp in the pilot light intake housing and plugged up the two small mixer holes that pull in air for the pilot light. This would explain the 'yellow-flame'. I took a punch awl and some compressed air and cleaned out the hole, then re-installed the cover and knob. Lastly, I turned and depressed the knob and the pilot light ignited almost instantly, stayed on when I let the knob up, and the heater turned on normally after that. Good luck, I hope this helps.
Oct 20, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Outdoor patio heater won't stay lit
I'm told by Charmglow that the problem is the Thermocouple. iHowever,it took me several calls to get someone to admit this. They are sending a new thermocoupler. My heater is less than a year old and under warranty--but it's a shame things like this happen.
Originally I was told it could'nt be the thermocoupler as they normally last at least 5 years.
Try it--as it may solve your problem as well.
Sep 21, 2008 | Heating & Cooling
Uniflame 200209 Open Flame Patio Heater Logo
439 people viewed this question
Top Uniflame Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
John Rodgers
John Rodgers
Are you an Uniflame Heating and Cooling Expert? Answer questions, earn points and help others
