Question about Drills
How to remove the chuck from a bosch gbh24v - Drills
3 Suggested Answers
SOURCE: bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Posted on Jan 31, 2009
  • 124 Answers
SOURCE: We need to replace the
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench 1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Posted on Apr 15, 2011
Remove 1014vsr bosch chuck
The greatest one that fit most chucks are 13mm but remember to remove the torxscrew (in clockwise direction) inside the chuck first and if you use a new chuck beware of to use some loctite on the screw.
The long side in a vice the short in the chuck and turn the left anticlockwise direction the L direction and pull short but fast the trigger and move the drill in the same direction turning the drill has priority to make doing this in a very short time. to not overcharge you tool.
Feb 26, 2015 | Bosch Drills
My new bosch cordless drill chuck doesn,t have a screw in it how do i remove the chuck ?
Dear Fred,
Please go to Replacement Parts in the link provided below. Too replace and remove your drill chuck on a cordless drill.
How to Remove Drill Chuck
Fare Well
Feb 07, 2015 | Bosch 13618 - 2G 18V Brute Tough Cordless...
Need to remove chuck on new BOSCH DDS181-02 18v cordless drill. No screw evident @ bottom of chuck-only small 1/16" hole. How do I remove chuck?
There is supposed to be a Phillips head LH thread screw in the chuck. I have seen the screw head worn down so you can no longer get a screwdriver to work.
We usually cut the chuck off with a metal chop saw just at the screw - thread what remains of the chuck off, which usually leaves 1/4" of the screw sticking out of the spindle - remove with vise grips.
Its not an easy prospect when that happens.
Oct 12, 2013 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
I,m having trouble getting the chuck off my 13618 bosch 18v hammerdrill. I have removed the screw then chucked a piece of hexed stock into it and reversed a half inch impact to it and it won't bre
Make sure it is in low gear on drill mode. try with just a bar in the socket and hit the end to shock it. This is sometimes better than a constant force.
Nov 21, 2012 | Bosch 13618 - 2G 18V Brute Tough Cordless...
We need to replace the chuck on our Bosch corded drill 1005VSR. We need detailed instructions on how to remove the chuck . Also, how can we order a new chuck?
Apr 15, 2011 | Bosch Drills
HOW DO I PUT THE QUICK RELEASE CHUCK ON A BOSCH HAMMER 11236VS?
I don't know that drill in detail but in general chucks for this type of machine are removed by pulling back the plastic ring behind the chuck and pulling the chuck out. So hold the drill with the chuck facing away fron you and grip the plastic ring behind the chuck (nearest you). Pull this toward you and pull the chuck away from you. Replacing a chuck is the reverse.
Jan 04, 2011 | Bosch Drills
The chuck has been pulled off. Whats the easiest way to reinstall it on my Bosch 11236vs Hammer Drill?
The chucks on the 11236 are designed to be removed, if you were not aware of this it may look like the tool has failed, it has not. To replace the chuck set the chuck back on the shaft of the tool, grip the outer collar of the chuck and rotate it counterclockwise while pushing down .The chuck will drop into a set of grooves on the shaft and lock there, give it a wiggle after to make sure its seated. Sometimes it takes a couple of tries to get it. To remove it just grip the collar turn counterclockwise and pull up, the chuck will come off.
Nov 22, 2010 | Bosch 11236VS Rotary Hammer
How do you replace the chuck on a Bosch 650 RE
while holding the drill like a gun, hold the lock button REALLY tight and pull the black part to the right really hard. this will unlock the chuck and if you keep twisting the black part to the right it will loosen it enough so that you can remove it
Jan 03, 2010 | Bosch Drills
The quick clamp chuck on my bosch 600 has seized up and I can't remove the drill bit. Any suggestions please
Hit a metal part of the clamp chuck to just create a "shock" using a hard rubber-hammer (or a metal hammer if the rubber one fails) one or two times. Chuck grip will loosen on the bit for you to remove it.
Dec 21, 2009 | Bosch Drills
Bosch 18volt brute force cordless drill how do i remove chuck
Jan 31, 2009 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
Drills Logo
23 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
