Question about Irons
Electric diagram of philips azur 80 (type hd 1729/B) iron
4 Suggested Answers
JULIANFIX
  • 975 Answers
SOURCE: help
heres a link so you can get more information for your product , hope this helps AJ .
http://www.shopping.com/xPP-irons-norelco~LO-1~CR-0
Posted on May 17, 2008
SOURCE: Problem with Philips Azur Precise 4340 Iron
i had the same problem and the Philips hekp site was no use. I turned my iron off until it was completely cooled down then switched it back on again, with the steam number turned to 5 and the heat on max. as soon as the ready light went off, i put my iron in the horizontal position and shook it back and forth (quite vigorously) and it seemed to have dont the trick!
Posted on Aug 28, 2008
SOURCE: Philips Azure self-cleaning steam iron
fill your iron with water, put the steam button to the 0 postion, plug your iron in and allow to get hot with the iron set to full heat.
Then unplug your iron hold it over the sink and at the same time hold down the calc button, repeat process until no more limescale come out of your iron, wipe plate with a damp cloth, then iron as normal,
(dont worry about the iron spitting and making a lot of noise during the calcing this is normal)
Posted on Oct 16, 2008
My Azure seam glide plus leaks water when I am ironing. What can I do
hmm sounds like the water tank could be damaged on the inside of it i would have to say it needs fixing ASAP as in some cases it could lead to electrical shock to its owner
Aug 22, 2017 | Irons
WHERE IS THE SERIAL NUMBER ON THE PHILIPS GC4890/02
I remember reading a # stamped right on the prongs of the plug in. Let me know if that works!
Jul 10, 2014 | Philips Azur Gc4890/02 Steam Iron With...
Phillips Azur Precice 4340 , lost instructions . How do you de calc it ? Thank you . Claire
Fill tank with water and put steam setting to 0.Set temp pial to hottest setting. Let the iron heat up till the light in the hand goes out. Switch off power and hold iron over sink. Push down and hold descale button until all the steam and water has gone from iron. Wipe plate and heat up iron again with no water in it.
Nov 09, 2009 | Philips HI-296 Iron
My Azure iron has just stopped working after two years. As dead as a DoDo. Checked fuse and wiring inside is intact.It still looks brand new, do I really have to bin it?! Bob Harvey.
yea you probably should! irons are no point fixing and by the sounds of things its blown up! i bought an expensive one and it didnt even last a year! we had warranty so we got a new one free
Jun 30, 2009 | Philips Irons
Steaming function stop working
its just connected with a screws on the front flap that has to be opened to seperate it into two parts,and inside there is small black coil thats is connected to the wires that wires must be short so has to be replaced with another wires. do it carefully .take care.
Feb 26, 2009 | Philips Irons
Philips Azur 4200 Iron spits out water like a water gun, burning my hand when ironing
i think you will find the solution is an easy one...you could wear some overalls and protective work wear....or.....stick some blue tack over the hole.....or .....get your husband to do it.
Nov 03, 2008 | Irons
Jul 09, 2008 | Irons
Help
May 17, 2008 | Philips HI-296 Iron
philips do not have a manual for this iron online, sorry contact them if you want; http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?sct=IR_STEAMIRONS_SU&cat=HOP_IRONS_CA&grp=HOUSEHOLD_PRODUCTS_GR&session=20070313063306_83.37.63.254&ctn=HI296/54&slg=ENG&scy=GB The best way to clean these irons is with neat vinegar - try to get white vinegar and you have less smell to get rid of - fill the iron, give it a good shake and leave it overnight, then use the iron as normal (use it on a kitchen drying up towel or similar) then leave it for another few hours/overnight and then empty out any remaining vinegar and rinse through with water a couple of times. this normally solves any problems caused by limescale - if not then just leave the iron a little longer with the vinegar, also try to pour a little vinegar into the steam vent holes with the iron upturned and leave for a while. Hope this helps :)
Mar 05, 2007 | Philips HI-296 Iron
Irons Logo
106 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
