Question about Kitchen Ranges
Oven door hinge replacement installation
I have a kitchenaid build in oven. The door will not stay closed tight enough to keep the "close door" light off or the oven light off. I had a repairman fix it one year ago and am having the same problem again. Can I replace the hinges myself? How do I install new hinges on the door?
  • 2 more comments
  • dwebb66 Mar 22, 2009
    Exactly the same on a KitchAid KEBC107KSS.
  • Fred Goldsmith Apr 15, 2013
    I had the exact same problem and paid A&E Factory service around $500 to fix the door springs problem about 2.5 years ago. Now it's happening again. I wrote to KitchenAid customer service via their website, A rep called today to say they have received similar complaints (she refused to tell me how many) but not enough complaints to make this a "known issue." So they would not repair or replace the 2004-purchased range and offered instead to SELL me a warranty plan for circa $300 that would cover the newly-needed repairs and others for one year. I declined. I've paid enough for and toward this oven (circa $2,400 when new). This is my last KitchenAid appliance ever. It's riduculous KitchenAid/Whirlpool won't stand behind their product. I'm considering a Bosch - Evolution 500 Series 30" Self-Cleaning oven for circa $1,100 from Best Buy. I'll sell the KitchenAid on Craigslist. I installed a Bosch dishwasher the same time as the oven with the kitchen remodel and even though it has a lot more moving parts and gets a lot more use, it's worked perfectly for now 9 years or so.
    Also, KitchenAid says there may be plenty more people who have experienced this problem but since they haven't formally complained to them they don't consider online complaints like these. So, for others' sake, if you have this or any other problem with KitchenAid products, complain to the company and also online on sites like this.
  • Michael Anderson
    Michael Anderson Oct 24, 2017
    I have spent $$$ on new hinges for my KitchenAid double oven doors over the past few years, but the springs always fail after 6 months or so. Recently I decided on an elegantly simple solution. K&J Magnetics (kjmagnetics.com) carries a line of 1/8" thick, countersunk Neodymium magnets that are perfect. I purchased a pair of their # RE22CS-N magnets (3/4" dia X 1/8" thick), attached them to the upper corners of the door just outside the gasket area with some #8 flathead screws, and viola! They do a great job of closing the door while still allowing a proper gasket seal. Lighter or heavier doors might require a different magnet, but K&J offers types with varying pull-in forces, so you should find one to match.
Kitchenaid superba oven door will not stay closed.
Posted on Nov 27, 2009
Oven light stays on and oven is inop on Kitchenaid KGSS907SSS01. Tried to go to self clean mode, Display states close door, but door is close.
I suspect the door/light switch has malfunction. Look for a plunger type of switch and press it in and see if light goes out. If light goes out, close door and gently press on door and see if light goes out. If this happens, I think the door hinges are not closing the door 100% so the door switch is not engaged. Now if door light stays on while pressing door switch, then the door switch might be your issue. Good Luck
Sep 27, 2017 | KitchenAid Kitchen Ranges
Both oven doors do not close properly. lights stay on & can't heat properly with doors not closing tight. is there an adjustment for these doors?
We have similar Jen Air double oven and with the same problem but only on the lower oven. The doors are interchangeable and the top door fits fine but the lower door will not close completely at the top. It does turn out the light but has never cooked properly. I checked with several appliance repair shops and the hinges are not adjustable, but since one door closes and our other doesn't it is not a hinge problem, just a defective design.
We let this go too long and are out of warranty so I doubt Jennair is going to do anything. I hope someone post a solution but it is clearly not problem with the henges but with the receptacle they go into.
Jan 04, 2011 | Jenn-Air WW27430P Stainless Steel Electric...
Oven door does not close tightly causing oven lites to go on
Sounds like the oven door is not closing enough for the light to go off. When that happens you have bad hinges. You need a left and right hinge replacement kit. Some hinges are easier than others to change, however, any handy person should be able to complete the job in about an hour with simple hand tools.
Please rate me a "4 thumbs" if this was helpful information. Best of luck!
Dec 15, 2010 | KitchenAid Ovens
Door will not stay closed
Hello,Sounds like the door hinge springs are weak, it will probably be necessary to replace them both.
Thanks
Jun 02, 2010 | Whirlpool GBS277PDS Electric Single Oven
My Wolrd Pool Double Oven Door will not close all
same problem, I tried to adjust the level and tip the oven back, but that didn't work either.
Two options exist, change the hinges, or close the door with a hammer handle between the door and oven. Place the handle down low by hinge, then push the door closed very firmly to pull the hinge outward a bit.
Jan 03, 2010 | Kenmore Ovens
KEBS208DSS6 doors wont close compleat
Place a hammer handle between the door and the frame at the hinge location.
Carefully apply pressure on the door to push the door closed.
This will often re-set range door hinges.
Mar 08, 2009 | KitchenAid KEBC208 Electric Double Oven
Oven door does not close properly
replacing hinges on this oven. Take a look.
Dec 14, 2008 | Hotpoint RB787 Electric Kitchen Range
Kitchenaid oven door will not stay closed
I had the same problem on my parents Kitchenaid KEMS378GWH0 oven, the door would only close enough to keep the light on. They propped a chair against it to cook. My father replaced the hinges and it worked for about a week. He noticed that pulling outward on the door at the very bottom edge often allowed it to close enough to use.
After completely dismantling the oven to get access to the brackets that the hinges slide into, we found it was not broken. We decided to expand on the only near solution we had and find a way to make the bottom of the door 'push out'. Our solution was very simple. Remove the small metal plate that covers the door insulation. This revealed that the insulation is a braided hollow rope that is held in by small clips that push through holes in the front of the oven. We threaded some small metal rods about 3/8 inch in diameter into the hollow insulation pushed the clips back in to re-attach the insulation, replaced the metal cover plate.
It worked!
Nov 22, 2007 | KitchenAid KEBC208 Electric Double Oven
Oven door just barely closes- light stays on
put a tea towel on both sides of the door [folded] down by the hinges then close door. gently push the door close try a few times with a little pressure.
Nov 12, 2007 | Kenmore 96422 / 96424 / 96429 Electric...
Kitchen Ranges Logo
1,191 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
