Question about Music
Manual for an Ibanez Troubadour 25 Watt Acoustic Amp
How to adjust or set the amp for different tones and sounds
  • 5603 Answers
SOURCE: my spider III 15 watt buzzes whenever i have a cable plugged in.
MAKE sure you have it connected to a three wire circuit that has the ground. A lot of these style amps will buzz if they are left ungrounded.
Also search for sources of buzzing light light dimmers.
Further, power supply electrolytic filter caps are suspect.
Posted on Aug 27, 2009
bob_computer
  • 3153 Answers
SOURCE: Ibanez suddenly quit sending signal to the amp
First off make sure it hasnt had a KILL switch installed and that its not in kill position.
These models have suffered some wiring issues in the past and your may be one of those.
If you feel comfortable with a soldering iron then here is the wiring diagram
If not a local music shop will check it out for you and suggest any repairs.
Posted on Nov 19, 2009
  • 5603 Answers
SOURCE: would like to know what siz allen key needed to
Read this site for important information:
http://www.ibanezrules.com/tech/setup/truss.htm
Posted on Jan 06, 2010
lock123
  • 6831 Answers
SOURCE: how do you string ibanez electric guitar? i'm a
Hello
Ok, at the link below you will be able to watch a video on exactly how to string your electric guitar.
http://www.youtube.com/watch?v=DrLKlJS1wEo
Just click on the link above.
Hope this can help you.
Kind regards
Andrea
Posted on Jan 17, 2010
  • 5603 Answers
SOURCE: Low volume for a 180
Welcome to the world of "specsmanship!" I could not find the exact COMPLETE schematic for this, but based on the schematics of the ACX1000 and ACX450 I will answer your question. This amp will have two separate amps... not saying how big yet... since the preamp schematic DOES have two complete channels and shows independent drives to the power amp section. Each of those power amps is probably made of a LM3886 chip. Looking at the spec of the chip, it will deliver 38 Watts to an 8 ohm load or 68 Watts to a 4 ohm load... which is likely what they have. Two of these in the amp and you have an amp with 68 x 2 or 136 Watts RMS... Now for the specsmanship... or in other words legal lying used by almost ALL sales departments... The power they post is NOT RMS continuous, but "Peak Power"... just like the shop vacuum specs saying 4 HP when you know the power input from a receptacle can't run a 4 HP motor... The peak power they can say is double the RMS power... so the 180 Watts is actually two, 90 Watt "speced" rating amps.
Now let's get down to the real issue: This amp has two 8 inch speakers... very good ones to handle decent frequency response for acoustic instruments... NOT LOW FREQUENCY BASS guitars... If you want to run BASS guitars, you have the WRONG amp... you need one with at least a 15 inch speaker. The key measurement is the SPL or sound pressure level you can get out of this. Myself, I have three ACX450 (baby brothers to the 1800) and use them for violin and can get all the sound I need. The amp is VERY versatile and has many good features. Remember that the dispersion of the sound is conical and probably is a cone 45 degrees wide. At a large venue you will want to tie the amp into the mains to cover a wide area. This amp will easily get to 100 Db in a 20 by 20 foot room. You shouldn't be over 100 Db for more than an hour for hearing loss protection anyway.
Posted on Jul 08, 2011
My Ibanez acoustic electric has very weak volume and makes a constant white noise hiss when plugged into an amp or sound system. Batteries are new as is the pre-amp and under saddle piezo. Ideas?
It will be either the saddle pickup or the guitar pre amp. If you unplug the pickup and the hiss is gone, there was your fault. Otherwise fit a known good pre amp.
Feb 02, 2017 | Ibanez Music
Ibanez Pre amp problem
It sounds like the guitar pickup may be faulty. It may be a loose connection on the which could be soldered easily or it may be damaged in some other way.
As this is isolated with your G string, I suspect the individual pickup unit is at fault.
Apr 16, 2014 | Ibanez Music
When i plug in to an amp i have no output
Check you battery and/or connections. You need to know in particular if the pickup wire is intact, and going to the volume/tone preamp. There would also be another wire going from the preamp to the plugin socket. If it uses a battery, check the power connections there. I hope this helps
Mar 12, 2014 | Ibanez EW20-MBE Acoustic-Electric Guitar
Frying sound from amp intermittantly
then the problen is in the power amp section after the preamp stage. Contact Crate for your nearest service center.
http://www.crateamps.com/support/index.php
Mar 03, 2014 | Crate Ca6110dg Gunnison 60 Watt Acoustic...
Chorus emits a pulsating noise
Sounds to me like low-end gear. You honestly get what you pay for. If it happens to be high-end then you have either bad cables or just a bad effects processor. If you have on-board effects built into the amp, then get better equipment.
Hope this helps.
Aug 31, 2012 | Ibanez IBZ10A 10 WATT ACOUSTIC AMPLIFIER...
Well, my Ibanez TBX150R Tone Blaster Xtreme Guitar Combo Amp worked fine for the longest time, and suddenly after a show, every time I turned it on the "hot" channel it popped and banged every...
Sounds like a problem with the channel itself, if the clean channel works then its not the lead, input, guitar or the drivers. You have to be careful when opening up amps as some can hold a residual charge and there can be danger of electrocution.
I would recommend getting it looked at by a pro, it doesn't sound like an expensive fix.
Jun 30, 2011 | Ibanez Tbx150h Tone Blaster Xtreme Guitar...
My s5470 does not sustain well at all.also,the bridge pickup sounds ok but lacks ''attack'' in upper register.great guitar otherwise.i use a peavy 5150 60watt amp.
I personally use Seymour Duncan Humbucker pickups, and have never been disappointed. You might want to take your guitar up to a music shop and try it on different amps to see if your amp is your problem, or if it is your guitar's pickups or wiring. You could also try adjusting the height of the pickups until the sound you are looking for is achieved. I have also had guitar cables make a big difference in the sound. Make sure you have a good set of cables, and you may want to adjust the EQ settings of your amp to make up what the guitar lacks.
Apr 15, 2011 | Ibanez S5470 Prestige Electric Guitar
I have a power acoustic 2000 watt amp and a set of power acoustic 10s my amp keeps getting very hot and im scared i will blow it
Make sure the airflow across the heatsinks is not restricted. The airflow should not be blocked by other modules, Also buy fans to force air across the heatsinks,
Mar 26, 2011 | Music
Low volume on acoustic and jazz amp type
Ok, so I hope you realize the Fender FM25DSP guitar amplifier is an "entry level" NON-valve amp with a DSP chip that has model shaping tones. I am sorry but this is a toy and Fender did not spend the tens of thousands of US dollars to have built-in tones that truly 'kill". This not digital modelling like Line 6 or Fractal Audio did and so you have a problem from the start. This amp was always intended as an entry level amp for the bedroom only and never to be used on stage.
Jazz and acoustic modes have some similarities requiring mid-range boost and some rounding. Not easy to achieve with a DSP chip that costs about US$10 to manufacture. Sorry, consider using the amp for practice but look at a more serious valve amps for live on stage
Apr 01, 2017 | Fender Fm25dsp 1x10' Guitar Combo...
Music Logo
304 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
