Question about Cycling
Crank hits chainguard
Pedal crank hits chainguard on schwinn krate bike
  • 50 Answers
SOURCE: My Schwinn 230 Recumbent bike makes a clanking
try the bearings.
Posted on Mar 03, 2009
goalie39
  • 469 Answers
SOURCE: How to disassemble crank bearing on Schwinn Mesa Mountain Bike
You wil need a couple of special tools, or be fairly creative with the tools you have.
  1. remove the dustcovers in the crank arms at the crank axle
  2. loosen the crank retaining nut/bolt.
  3. thread in a chank puller and pull the crank arms.
  4. remove the lock ring on the adjustable side of the crank axle (Requires lock ring wrench)
  5. remove adjustable bearing cup.
  6. remove axle and bearings
  7. replace or repair as needed.
Once you have it opened up ou can determine if you need new bearings or crank axle.
to assemble, reverse above procedure, insuring bearing play is minimalized.
Hope this helps.
Ed
Posted on Apr 19, 2009
smokinB
  • 55 Answers
SOURCE: My Schwinn hybrid bike makes a popping noise in
Your pedal berrings are going out try replacing it.
Posted on Jul 14, 2009
  • 1788 Answers
SOURCE: Bad crank bearings can move crank arms small amount.
clicking can be a stiff link in your chain.
Posted on Aug 04, 2010
  • 456 Answers
SOURCE: My pedals are squeaking while pedaling on my
hi.
i cannot see any problems with wd40 on any bike and have used it myself for many years.
just wipe away any excess, and do not spray it on the pedal tops (where your shoes go) as they may get slippery.
light oil (3in1 or simillar) is also excellent on bikes instead of wd40. same advice as above.
i find wd40 works faster, especially on squeaks, but oil works for longer.
i usually use wd40 first to cure the imediate noise, and then use a few drops of the oil to keep it quiet for longer.
hope this helps
Posted on Apr 24, 2011
How do I know what model Schwinn bike I have?
The model is written on the frame or on the chainguard. If the frame has been repainted the model doesn't matter much, as any value has been severely reduced, especially if it was not a professional paint job.
Dec 24, 2016 | Schwinn Cycling
I have a schwinn serial number dp509984. I would like to known what year make and model it is as well as a price range if at all poossible. Thanks for ur help
It would help if you had at least provided the type of bike (old coaster brake, 3 speed, 10 speed, etc.) The make is Schwinn, the model is written right on the bike frame or chainguard. If the bike is repainted so that the model is not visible it's not worth much. As far as year, just Google "Schwinn serial number" (and note info about date codes) and see my tip for more info: How to determine the year value etc of your bicycle
Nov 05, 2016 | Schwinn Cycling
Schwinn cruiser frame serial number U22Y48168 under crank, forward facing drop out. the tubes run on outside of seat post, not welded into it on both sides. what can you tell me about this frame?
The serial number alone is not always helpful, including in this case. You need to specify what the model is (written on frame or chainguard). If the bike has been repainted it does not matter much how old it is, most of the value is gone. Look for an additional number on the head tube - may have a date code. Google "Schwinn serial number" for more info or check my tip:
Jun 08, 2016 | Schwinn Cycling
I bought a meridian trike from schwinn, my kids took a hammer to the chain guard and my wife is upset, is there any way I can just buy a new chain guard for this trike? Also want to put a motor plz
Schwinn Meridian chainguard - schwinnbikeforum
www.schwinnbikeforum.com > ... > WELTERWEIGHT PLUS
Oct 20, 2012 - 5 posts - ‎5 authors
A little help please... My daughter needs a new chainguard for her Schwinn Meridian. She loaned her trike out, to be used in a parade, and ...
I need a new chain guard for a Schwinn Meridian Adult - Fixya
www.fixya.com/.../t10679393-need_new_chain_guard_schwinn_meridi...
Oct 16, 2011 - SOURCE: Meridian Adult 26-Inch 3-Wheel Bike: Schwinn Meridian Tricycle rear brake adjustment... ... Schwinn Meridian Adult 26-Inch... ... Have a manual for Schwinn Meridian Adult 26-Inch 3-Wheel Bike?
Brian riding on his new Schwinn Meridian 24-inch 3-wheel ...
Dec 26, 2015 | Cycling
The left pedal to my Schwinn Windwood women's cruiser will NOT go in. I have verified that it is the left pedal and had no issues getting the right pedal in. What can I do?
Answered in your previous post, The left pedal is opposite threading. You screw the pedal in the same direction as the right side - toward the front of the bike.
Facing right side crank - Right pedal screws in normal, toward the front of the bike.
Facing left side crank - Left pedal screws in counterclockwise, toward the front of the bike.
Dec 27, 2010 | Schwinn Windwood 26 Women s Cruiser...
That would depend on the style of bearings (loose ball or caged balls vs sealed bearings) and possible bottom bracket damage.
Either way, a Bike Shop mechanic would probably need to assess it for you. Special tools are usually involved.
http://parktool.com/repair/byregion.asp?catid=61
May 23, 2010 | Schwinn Mesa Gs Mountain Bike
Cycling Logo
70 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
