Question about Panasonic Lands Phones
How do I add more rings to my phone before it goes to voicemail on a model kxtg6645 sk
It rings three times then goes to messaging
5 Suggested Answers
SOURCE: I need to change the number of rings before phone goes to voicemail
First, call your voice mail. After the messages you will be given a menu to follow. On the Sony Ericsson W350 I went to Personal Options (4) then to Administrative Options (2) and finally Prompt Level (3). After reaching Prompt Level you have the option to shorten or extend the number of rings. At this point I chose to shorten the prompt and then I exitted the system.
Posted on Apr 13, 2009
  • 12 Answers
SOURCE: phone only rings three times before going to my message bank
If its going to your carriage service provider message bank then you need to reset this for a longer period. The carrier message bank is managed by the carrier.
If the cordless has an answering service, then you need to scroll through the menu on the phone to select answering functions and select 6 rings or longer.
Posted on May 05, 2009
  • 547 Answers
SOURCE: KX-T7633 Voicemail rings
The Voice Mail feature is set by your phone company, not by the phone. Typically the phone company will set it for 20 seconds, or approximately 4 rings. This is called your voice mail "Ring Cycle"
Call them up (the customer service number should be on your phone bill) and they should be able to increase or decrease your ring cycle for you at no charge.
Posted on Dec 02, 2009
consultel1
  • 860 Answers
SOURCE: The phone rings 3 times and goes to voicemail on
I don't think its a good idea to back the vms cover rings to 8. The furthest I'd go is maybe 6.
Changing the VMS cover rings on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#321"
the display should say VMS Cover Rings and ask for an extension number
enter the extension number you wish to change
The current ring data should be displayed
enter in new data (8 ring if you wish)
press feature "00" to logout
Posted on Dec 10, 2009
KX-T7710
The KX-T7710 isn't an answering machine. The ring count is controlled by the answering machine or voicemail system connected to the phone line. Could you tell us the make and model?
Nov 21, 2013 | Panasonic KX-T7630 Corded Phone
Hi I have a Panasonic cordless phone kx tg2511al. I sometimes find that incoming calls go straight to voicemail without it ringing first. How do I make sure it rings at least a good number of times...
Remove the battery and allow the set to phone to reset. Now check for the ringer setting at teh back of the base phone to be set to the maximum rings, there can be three settings.
Some times this is also set on the menu.
Connect and test the timing to confirm
Jun 13, 2011 | Cell Phones
THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
Mar 30, 2011 | Uniden Cordless Phone
Incoming calls goes to voicemail, then to receptionist. Also rings at three extensions at the same time.
It sounds like all the incoming calls are going to a hunt group. This would explain why three extensions ring, then it goes to the receptionist, and then ends up in voicemail.
Try looking for a hunt group that distributes to the three extensions in question, or that only has those 3 extensions active.
Dec 10, 2010 | Avaya 4610SW IP Phone
Incoming calls ring 3 times at main extension, then phone stops ringing at main & rolls over to ring at all other phones. Phone rings once at those extensions before going to voicemail. (We have...
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Jul 22, 2009 | Cell Phones
Voicemail timestamp & "on hold" too long
Yes Music can be played from your system during transfer. Simple connect any radio or cd player to the RCA jack located on your KSU (main box) For setting the time in voicemail log into box 999 with sec code 999997 or just 997 and press 8 for admin features. More guides and ACTUAL manuals can be found here
http://guides.idacomusa.com/
May 18, 2009 | Toshiba DKT-2020 Corded Phone
Incoming calls
Messaging then Voicemail this is where the settings are stored you can disabl all then your phone wll just keep rining or change ringing time
Jun 22, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Voicemail
It sounds like you are using a voicemail service from a provider, meaning you did not buy the voicemail system with the phone system. If you confirm, I can tell you how to fix this.
Apr 29, 2008 | NorStar M7310 Corded Phone
Lands Phones Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
