Question about Texas Instruments TI-84 Plus Calculator
I don't know how to unhighlight stat plot on my TI-84
When I want to plot an equation and go to the Y= button the plot1 is highlighted and I can't figure out how to unhighlight it.
raklein62
  • 360 Answers
SOURCE: how do you plot two liner equations on a ti-84?
I use one of the graphing APPS or do through a program. I have a users manual for TI 84 silver Edition that shows you how to archive\ unarchive to run programs here at this site. Usually, I tell people to just forget about the programs and use the simple concepts so, that they could operate their calculator better. But, if you notice in those program are actually more powerful than the programs you get on the web, because I wrote them to be flawless, or I only used programs that I knew would not clash and were very well written. Won't y1=(2/5)x-(11/5) and -3x+8 work?
Posted on Sep 29, 2009
  • 8068 Answers
SOURCE: I am trying to drive a prediction equation. but
I assume you know how to enter data in your calculator. The keystrokes in the following pertain to TI92/92Plus/ Voyage 200 PLT. The main differences with the TI89/Ti89 Titanium is that the function keys F6,F7,F8 are not accessed directly but by the key sequences [2nd][F1], [2nd][F2], and [2nd][F3] respectively
1. CLEAN THE SLATE (so to speak) and ENTER DATA
In Home folder run F6: NewProb to reset the configuration.
Press Apps, and select 6: data/Matrix editor. Select a new data set
Give it a name: here testing.
Press OK/ENTER, The data entry screen opens, enter your values.
When you finish press F2.PlotSetUp.
2. Statistical plot setup and scatter plot drawing
b142867.jpg.
Press F1:define to configure Plot1. Choose Scatter, then choose a mark for the data point. I select 5:Dot. and press [ENTER
Select the data column X=c1, Y=c2
Press ENTER to save configuration. Press [CTRL] [GRAPH] On my TI92 the CTRL key is the [Diamond] key. On the following graph I changed the mark to a cross to see the data point better. I also played with the window dimension. You can also do that with ZoomStat. The graph remind me of a parabola (I know I chose the exact values)
3. STATISTICAL CALC. AND REGRESSION ANALYSES.
Now we have to find the equation that fits these data best.
You press APPS 6:Data/ Matrix editor but you select current to return to your data set. You are taken to the data entry editor (Figure 3 above). In that screen Press F5:Calc to edit the type of statistics you want
On first line select the type of regression model : Linear Regression, QuadReg quadratic regression (or anything else available) X is from column1, Y is from column 2. Store RegEQ The regression equation in say Y1(x)
Press ENTER to save to get the Regression Equation. Here it is
As you can see I cheated: a perfect parabola. R^2 =1.
And here the best fit represented on same graph as the statistical data
Usually you have to try different regression models, until you find the one that fits best the experimental data.
Posted on Jul 27, 2010
  • 102366 Answers
SOURCE: when i click graph it
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Posted on Sep 06, 2010
SOURCE: I am trying to do a box plot with a TI-84 Plus
Hey. I had the exact same problem as you and all I could do was reset the settings to the default settings on the calculator. All you have to do is turn the calculator on, his 2nd (it should say mem right above it). Then click reset then RAM.
Posted on Sep 30, 2010
  • 102366 Answers
SOURCE: i want to graph a
You're trying to graph a function that does not involve stat plot features but the calculator probably thinks you are. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Posted on Oct 29, 2010
Everytime I hit graph it tells me invalid dim, but I am more than positive my dimension are corrrect. What do I do ? It is not graphing any of my equations
If this doesn't do it, please reply to this post and give the function(s) you're trying to plot.
Jul 31, 2011 | Texas Instruments TI-84 Plus Silver...
My TI 84 plus silver: whenever I push the graph button the message ERR: Syntax 1:quit 2: goto appear on screen please help
Press the Y= button.
There are several possibilities:
1) Scroll through all equations, Y1 through Y9 and Y0. Make sure they are cleared.
2) The equation you typed in is not entered correctly.
3) Make sure Plot 1, Plot 2, and Plot 3 are NOT highlighted.
Feb 01, 2011 | Texas Instruments TI-84 Plus Calculator
TI-84: trying to graph an equation and ERR: INVALID DIM shows up only PLOT 1 is highlighted Window XMax XMin Ymax and Ymin are correct Any ideas? Test tomorrow
Jan 05, 2011 | Texas Instruments TI-84 Plus Silver...
My TI-84 Plus Silver Edition Graphing Calculator continues to read "ERR: INVALID DIM" whenever I attempt to graph equations.
Dec 04, 2010 | Texas Instruments TI-83 Plus Calculator
I want to graph a parabola on my ti-84. i entered the equation in y=, and then i turned on plot on, then i hit graph, but it is showing invalid dim. help please?
Oct 29, 2010 | Texas Instruments TI-84 Plus Calculator
My calculator will not graph the equations i put in under the y= button. it says "ERR:INVALID DIM 1:QUIT"
Oct 25, 2010 | Texas Instruments TI-84 Plus Calculator
When i click graph it says "ERR: INVALID DIM" i noticed under "y equal" mode that plot 1 and plot 2 are highlighted. how do i fix this, i need to be able to graph. TI-84 plus calc.
Sep 06, 2010 | Texas Instruments TI-84 Plus Calculator
I am trying to graph and i am getting error 13 dimension how can i fix it?
Press GRAPH F1 to enter the equation editor.
Plot1 Plot2 Plot3 on the top line of the equation editor displays the on/off status of each stat plot. When a plot name is highlighted, the plot is on. To toggle the status, press up, left, and right to place the cursor on the name, then press ENTER.
Sep 30, 2009 | Texas Instruments TI-86 Calculator
Invalid dim
turn off the stat plot by pressing 2nd button and then the STAT PLOT button.
Mar 12, 2009 | Texas Instruments TI-84 Plus Silver...
Everytime i hit graph on my TI 84 plus, it keeps saying "ERR: INVALID DIM". how do i make it graph again?
This probably means you have a statistics variable set to on in your graphing screen. Press . If you see one, or more of the plots at the top highlighted you should turn them off.
calcyeqx2plot1on.gifTo turn them off use the  until Plot1 is highlighted. Use the  if needed to move to a highlighted plot. Press .
Sep 16, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
276 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
