Pu4vljsa trip after 10 min indoor blinking 8 times what is problem tell me
4 Suggested Answers
SOURCE: i have a lg 1.5 ton split ac , problem is
first check the compressor amps and the condenser fan rotation are correct if ok check power come to the compressor without interuption (from control in the indoor unit)if the remote setting are ok correct voltage to the compressor may high pressure stop it or low pressure compressure overheat.and if this was repeated many time the best to change the compressor.
Posted on Aug 29, 2009
  • 6 Answers
SOURCE: my indoor blower is not working it blinks 8 times
This alarm state is a CH08 alarm. Which indicates that the indoor unit fan motor has a locked rotor. Solution is to check the indoor fan capacitor and replace or test the windings of the indoor fan motor. Note: the indoor fan motor is a BLDC fan motor and can not be replaced with any other motor. It runs of a voltage regulated frequency.
Posted on Mar 22, 2010
hvac1960
  • 2133 Answers
SOURCE: Mitsubishi eletric model pu-4vljsa cu running 10
Defective input.
Posted on Oct 27, 2011
FUJITSU Inverter wall mounted split air conditioner Model : AST12LSBCW not working, flashing lights
This is a "PFC circuit abnormal" in the outdoor unit meaning that the outdoor controller board is faulty. Try turning the machine off at the isolator switch for 10 mins, then back on to see if the error resets. If not you will need a new controller PCB.
Nov 15, 2016 | Fujitsu Heating & Cooling
I want 38424 to turn on a lamp at 8 PM and turn off at 10:05 PM - Do I set it on "Timer" or "ON"
You want to set the clock after charging the device. Takes a short time. Set the time by pressing TIME and then HOUR/MIN for the current time. Now you can set the timer.
Press the "ON" and set the time you want the device to turn on.
Press the OFF button and set the time to the time you want the device to turn off.
Put the switch on the top to the TIMER position and lug into the wall socket and then the device into the timer.
Should be good to go.
Apr 13, 2014 | Stanley 38424 TimerMax Digislim Daily...
Samsung 2.0TR split ac compressor getting heated up and tripped after running for 10 mins
High limit switch set to high, obstruction in the system, or your compressor may be wearing out.
Apr 12, 2013 | Heating & Cooling
My split type 2.5hp carrier express ion shuts off (including the condenser) after five minutes of running, the indicator light blinks during this time...it restarts again after awhile, then shuts off again...
How many times is the light blinking? Also is the light red, yellow or green? The light blinking is telling you exactly what has failed.
(# of RED blinks first)
1 High Pressure Protect
2 Indoor coil freeze protect
3 Low pressure protect
4 Compressor discharge protect
5 Low pressure/Overcurrent protect
6 Indoor-outdoor communication error
8 Hi-Temp protect
10 AC Voltage Low
Each of these has maintenance required steps to resolve the errror. Let me know how many blinks your getting...
Kelly
Apr 25, 2011 | LG Heating & Cooling
Misubishi split a c 2 tons green light blinking problems
Please write how many times blinking and with an interval. Depends upon it, we can give solution.
Normally, blinking 5 times means for drain motor malfunctioning. Check drainline, oif blocked clean it. If drain motor not working, replace it.
If blinking 2 times, Indoor room air thermistor defective replace.
Thanks.
Feb 18, 2011 | Mitsubishi MSZ-A15NA Split System Air...
My split unit air con will switch off automatically every 10 minutes and the lights will blink. It can only be turned on again if the power is switched off from the mains.
May be in indoor screen there is some error code. Don't worry. I try to solve it. Normally after 3 minutes compressor will start. If compressor amps gradually increase due to condenser block or less rpm of fan motor. Please ensure with amps meter for increasing ampere It will run just 10 minutes or up to the maximum running amps and get tripped. Service your indoor and out door and check. . Is it helpful?
Dec 28, 2010 | Electrolux Heating & Cooling
My indoor blower is not working it blinks 8 times
Mar 18, 2010 | LG LS-L1210CL Mini Split Air Conditioner
I have a lg 1.5 ton split ac , problem is compressor trip in 5 to 10 minutes ang agin start in 10 min..i will call service centre , he wl change capactor and service indoor n outdoor unit ,but problem will...
Aug 28, 2009 | Heating & Cooling
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
