Question about Home Security
Vertical lines on security camera
I get vertical lines sometimes on pc monitor displaying security camera captures. Can anybody tell me if it is a software problem or not?
  • bulentya Nov 13, 2008
    Yes I found it, it was software problem. I removed the program from PC, deleted register recordings related with the program, reinstalled the program, and everything is fine. Thanks for all.
  • paul_romano1 Mar 31, 2009
    my wireles security cameras I have hooked up to my dvr and that is hooked up to a smaller television- my problem is there are static horizontal lines that run up and down the screen the picture would be fine if the running static lines werent there
    Scholar:
  • 64 Answers
Sounds like a monitor that is on its way out....I would do a quick test and swap that monitor out with a different one and see it the vertical lines come back.....Let me know if this helps.....
cbinny1
Posted on Oct 29, 2008
Display vertical line
Turn off the monitor and disconnect it from the back of the pc. This way you will isolate the monitor from the PC. Now turn on the monitor, if you still see the vertical line then that means the screen is bad and you would need a new monitor.
If the monitor doesn't have the vertical line then that means your video card is the issue or if you have an integrated vga port on the back of the computer then the motherboard is bad and would need to be replaced.
Sep 23, 2013 | Acer V173 Monitor
Getting vertical line in acer monitor
Apparently it is a display hardware problem. Try another monitor with the same cable and video card. Then you should try another cable. Then another video card. If vertical line doesn't show in either case, then you should replace the appropriate device\cable. If it shows anyway, then bring your monitor to service center for diagnosis.
Jul 13, 2010 | Acer Aspire™ T180 PC Desktop
Video displays vertical lines then goes blank
There could be 3 possible reasons for a vertical lines
1. Driver for graphics card needs to be updated
2. Grpahics card faulty
3. LCD problem
try connecting an external monitor and see if the display is also vertical on the monitor, if yes the problem is graphics card, if no, the problem is the LCD. Hope this helps
Dec 11, 2009 | Acer Aspire 5100 Notebook
Vertical multicolored lines appear. Sometimes there are couple of vertical white stips and vertical lines
Connect an external monitor to your laptop. If the problem appears only on the display of the laptop and not on the external monitor in the same time that means the video card is ok and the problem could be : the screen of the laptop or the invertor or the cable that attaches the screen to the mainboard. Have it checked by a professional.
Oct 05, 2009 | HP Pavilion zd8000 Notebook
The monitor just goes out. It displays vertical
vertical lines can mean either a connector problem on the lcd itself or on the motherboard connector or a problem with video ram or the chip. Unfortunately none of those are cheap or easy to fix. You can try an external monitor and if that displays normally then the problem is connector or lcd. You can sometimes find a replacement display at fair prices so if that is it then it might be worth fixing. If it is the motherboard then the repair can cost as much as a new replacement laptop.
Sep 25, 2009 | Gateway MT6451 Notebook
Asus 1000he red vertical line in monitor will not
Hi
If you have External Monitor check by connecting it
if you get display on external monitor without line it means Display screen is Bad, if Line appears on external display as well then there is either Display driver issue or motherboard problem.
Jul 19, 2009 | ASUS Eee PC 1000H Laptop
Multiple lines on screen
Try connecting an external monitor to the your laptop and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Mar 15, 2009 | Compaq Presario M2000 Notebook
PAL Problem and ADVC110
It's difficult to tell what's really going on by looking at the PC monitor. You should generate a DV file and play it back through the ADVC to a TV and see.
The issue is interlacing. Since the two fields of interlaced video are originated at different points in time, when you play both fields on a non-interlaced display like a PC monitor, you see the two combined and they don't match up. So you get half of a ball before the line, and half of the ball after the line and it looks funny.
Apr 17, 2008 | Canopus ADVC-110 A/D Converter...
Home Security Logo
829 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
