Question about Proform Exercise & Fitness
Need new/used/refubised console for pro-from crosswalk caliber elite mod# pftl71505.0
Med# pftl71505.0 need to replace console board
5 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: I have a proform crosswalk
1) TRY TO CLEAN THE CONTACT, by corroded or dust, or loose connection(tight).
2) try to open the control panel and clean with contact cleaner.
3)adjust the Reed swithc +Optical sensor
4) Do not connect other pins, you can provoke some short circuit or bad functions, and provoke another errors or jamming some I.C.
Posted on Nov 15, 2011
ercupa190
  • 12223 Answers
SOURCE: no replacement console for PFTL71505.0 Proform Crosswalk Caliber Elite
go to www. fitnessreairparts.com or www.doctortreadmill.com or www.treadmillpartszone.com
God bless you
Posted on Jun 19, 2012
ercupa190
  • 12223 Answers
SOURCE: profrom crosswalk caliber elite control board pftl71505
Adjust the REED switch, see the diagram attached, clean it, and tight very well the plug or connector.
2) tight the ribbon cables inside for keypads, clean it use the eraser pencil, and tight very well
and try it. see the block attached.
God bless you
Posted on Oct 13, 2012
Profrom crosswalk caliber elite control board pftl71505
God bless you
Oct 12, 2012 | Exercise & Fitness
Pro-Form Crosswalk 395 - Incline goes up and down with no tread movement. Calibration doesn't work - only on display.
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion.
God bless you
Sep 29, 2012 | Proform Crosswalk 395 Treadmill
No replacement console for PFTL71505.0 Proform Crosswalk Caliber Elite
God bless you
Jun 19, 2012 | Proform Crosswalk 500 Treadmill
Pro form 780 cs console does not respond
Dear Sir:
Thank you by your request. I hope everything is fine in union with your family.
Now I will help you inmediately.
Please do the following:
ercupa190.jpgSchematic for Reed Switch
Thank you in advance, sincerely. God bless you.
If you need further assistance, please contact us.
E.CUADRA MANAGUA, NICARAGUA. C.A.
Sep 27, 2011 | Proform 780 CrossWalk Treadmill with...
I have a proform crosswalk caliber elite treadmill model # PFTL71505.0 and only buttons #3 and #9 work and no others. Should I try the same fix that I see on other posts where they slice the ribbon cable...
Sep 08, 2011 | Proform Crosswalk 500 Treadmill
The fan on my Proform 570 treadmill fan does not turn on . Any suggestions?
The fan control goes through the console, and if both of them quit......... well you need a new console. The power comes from the small circut board inside the console. You can get a new one at iconservice.com.
Hope this helps,
Matt
Dec 07, 2010 | Proform 570 CrossWalk Treadmill
My control board does not work...buttons cant be pressed to engage the treadmill? I have a Pro-Form cross walk>
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
Jul 21, 2010 | Proform Crosswalk 500 Treadmill
Proform crosswalk has no lights on the top panel. What can be wrong. There is light on the control board.
If you know how to use a multi-meter you will need to do the following:
Will need to disassemble upper console to 1.Check ribbon connection and continuity from upper to lower board 2. Check continuity of safety key switch 3. check dc voltage from lower to upper boards.
If ribbon is defective replace it. If safety switch is defective replace it. If lower board is defective get pricing for component If upper board is defective get pricing for component
go to icofitness.com
Feb 27, 2010 | Proform Crosswalk 500 Treadmill
Exercise & Fitness Logo
99 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
