Question about Whirlpool ER6AHKXPQ Top Freezer Refrigerator
Door open LED light flashing always with no cooling
  • 700 Answers
The door switch possibly needs replkacing, take and pop it out and make sure that its not filled with water and it's connected. if so then replace it.
Posted on Jan 30, 2009
CO1224FS00A. Why is there a beeping noise and the alert LED flashes when door is opened?
it might be the NEW normal for that make and model , letting you know it is OPEN
Aug 28, 2015 | U-Line Refrigerators
Tip
Garage Door Remote Doesn't Work
Here’s a problem I’ve run into several times lately- the garage door opener remote no longer works. The good news is the solution has been very simple. Check your wall control.
Is the led solid or flashing? If it’s flashing you’re in luck. The wall control should have two buttons, one with a light symbol and one with a lock symbol. Press and hold the lock button for a few seconds then release. The led on the wall control should now be solid and your remotes will now function.
What’s that button for, you ask? Good question. It is a “vacation mode” setting so that when you’re gone the remote function is disabled decreasing the likelihood of break-in.
Most times no one pays much attention to the lock button; they are usually going for the light button and press lock by mistake.
Now if the wall control led was solid the whole time, this gets a little trickier. Grab a ladder and take a look at the side of the garage door opener where the wire hangs down, that’s the remote antenna. Near the antenna will be the “learn button” where you program the remotes. Right next to this button is an led. Now we can test the remote by pressing the button (on the remote not the learn button) and see if the led on the garage door opener lights up.
If the led lights up but there is no reaction from the opener it may be that the opener just needs to be reprogrammed. Sometimes the garage door opener gets a “brain freeze” and loses sync with the remote. Press the learn button and quickly release it, you now have 30 seconds to program your remote. Press and hold the remote button until you get a reaction from the opener, either the lights will flash or you will hear a click. Try your remote now to see if it works. If you are still having trouble the garage door opener’s logic board (where the learn button is located) may be faulty. This would be a very costly repair unless you are savvy enough to replace it yourself.)
If the led on the opener did not light up you may have a bad battery in the remote, the remote itself is bad or again the logic board is defective.
on Jan 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Automatic door lock 1999 toyota prerunner
hi jerome
I have the procedure for Toyota auto lock, is worth to try it
AUTOMATIC LOCK SETTING
1) Step in the vehicle and make sure that all doors are closed completely
2) Insert the key into the ignition key cylinder.
3) Wait for more than 5 seconds.
4) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON).
? Status Monitor LED will illuminate for 30 seconds.
Note : In case you implement 6 times or more by mistake,
action steps 6)-8) you made will be canceled.
Please retry from step 2).
5) While the LED is illuminated :
• Open and close the driver's door 2 times.
• Turn the key to the ACC position.
? LED will continue illuminating.
? Indicator lights will flash 2 times.
Ignition controlled door lock ON :
6) While the LED is illuminated:
• Open and close the driver's door 1 time.
• Turn the key ACC-ON-ACC 1 time (Last position : ACC).
? Indicator lights will flash 1 time.
? LED will extinguish.
Ignition controlled door lock OFF :
6) While the LED is illuminated :
Jan 28, 2014 | Toyota Camry Cars & Trucks
E68 error code
This E68 is a stuck keypad.
The error E68 means the CCU has sensed a stuck button on the console. MANY times this is a false error and means that either the CCU or interface must be replaced, but SOMETIMES, there really is a stuck button. Try to run a diagnostic using the instructions I have provided below, let me know if you need any help with it.
1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound
1 time and " res" will be shown briefly in the display.
2. Immediately after, rotate cycle selector knob 5 turns counter-clockwise to the second position from the bottom.
Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control will enter test mode,
the buzzer will sound 3 times and all LED's will rapidly flash.
After entering the test mode, the cycle selector knob can now be rotated to select the following tests:
Rotate the cycle selector knob clockwise from the starting position:
0 turns: All LED's will flash.
1 turn: Drive motor runs; heat source is on. Drying LED is lit. "H" and the control thermistor reading will toggle
back and forth in the display.
2 turns: Drive motor runs; heat source is off. Cool Down LED is lit and "AF" (Air Fluff) is displayed.
3 turns: Drive motor runs; heat source is off. Drying and Cool Down LED's are lit and numbers appear in the
display showing moisture sensor readings. Opening the door (press in on door switch plunger) and placing
a finger on the both moisture sense bars at the same time will make the numbers decrease. In controls that
do not have a digit display, the More Dry LED should be ON. Opening the door (press in on door switch
plunger) and placing a finger on the both moisture sense bars at the same time will make the Damp LED
come on.
4 turns: Drive motor runs; heat source is off.
Key test:
a. When the Temperature key is pressed, all the temperature LED's should light.
b. When the Dryness key is pressed, all the dryness level LED's should light.
c. When the Options or Select key is pressed, all the Option LED's should light.
d. When the Start/Pause key is pressed, all the cycle status LED's should light.
e. When the Cancel key is pressed, all the cycle status LED's should light.
5 turns: Drive motor runs; heat source is off. Cool Down LED is lit. Control thermistor reading is displayed.
6 turns: Drive motor runs; heat source is on. Drying LED is lit. Control thermistor reading is displayed.
7-11 turns: All LED's will flash
To EXIT test mode, press and hold the Select and Cancel buttons simultaneously for 6 seconds or disconnect power
from dryer. Dryer will be reset for regular operation.
If you cant even enter this mode at all, your interface will have to be replaced. There is no way to determine whether its the interface OR CCU, but in my experience, it's usually the interface that ends up needing replacement. Here is a link to the interface board.
Oct 15, 2012 | Frigidaire Affinity ATF7000ES Front Load...
Whirlpool WBM39MW alarm when door opened
Just had one of these with the blinking light, fan pulsating and no cooling. The fault is the power supply section in the control module at the back. It is a 2uF 400VAC capacitor going open circuit. make sure you replace this capacitor with something equal or better rated - it is critical
Jun 17, 2012 | Whirlpool Refrigerators
The does not completely close and one light is green and one yellow i see no disruption. then it opens up again what can i do?
Color of lights doesn't matter. If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure they are not flickering ever so slightly. Tweak them a little. On the rear of the motor unit there is a small LED. Check to see if it is flashing a code. It will flash a number of times, pause and then repeat. Near where that LED Is you will find the down force adjustment. Increase it about 1/4 turn and try. If the LED is flashing code 5 you most likely have a bad RPM sensor board which is a small printed circuit board just in front of the motor.
May 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
My remotes will only work when the garage door opener unit lights are off. what is causing this problem?
On the rear of the motor unit near where all those white wires go you will see a small LED. Check this LED when the lights are on to see if it is flashing. If it is flashing rapidly you have some type of interference. Random flashing is normal. While this LED is flashing remove the bulbs and see if it stops. While you have the light bulbs out unplug the opener and use a small screwdriver to pull out on the center contacts of the light socket. Can't think of any other reason why the lights would cause the opener to not work.
Oct 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
What do 4 flashing lights mean on craftsman door
4 FLASHES
Safety reversing sensors slightly misaligned (dim or flashing LED).
Dec 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman 53684 keyless won't work with my Craftsman 53930DM.
I've never seen the first set of steps you mention. You always need to press the "learn" button first so the opener will be in the mode to capture the new code. As far as I know it is not necessary to hold the Enter button on the keypad (at least I never have). While the "learn" LED is lit on the opener, just key in the new code and press Enter.
Maybe you should try clearing the receiver first by pressing the "learn" button and holding it until the LED either goes out or starts flashing (depends on model). Then try reprogramming. Maybe the little computer is confused.
Nov 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Whirlpool ER6AHKXPQ Top Freezer Refrigerator Logo
149 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
