Question about Honeywell Heating & Cooling
Opt appears on the cm67ng hand set?
OPT code appears on the hand set which means the heating is coming on at random times
  • 97 Answers
SOURCE: no sound output
Sounds like you sorta know what your doing but the most obvious answer is the source and output (selection) dont match. Double check your mute button and all the obvious things first, make sure your connections are to Zone1 inputs as well. None of those are it? Do you get sound from the Radio? Try unhooking all inputs (video also) and hooking up just one at a time till you get it right.
Posted on Mar 18, 2008
tech435
  • 284 Answers
SOURCE: panafax DX2000(au)opt
if its frozen try to do a shipment set, and maybe a firmware update .. try these and if they dont work might be a main board
Posted on Oct 15, 2008
Bubbabear64
  • 2794 Answers
SOURCE: FORMULA NEEDED FAST
Yes you can create the formula outside the cell or you can create it one time and copy it down to the other cells. That way it will populate once it is used.
The formula should be Base Rate * .05 to get the result then add the result back to the base rate.
Posted on Dec 18, 2008
  • 11 Answers
SOURCE: Ruud furnace Model URKA A030jK08 Code opt 589
sounds like the circuit running to your condenser powers your furnace. when u disconnect power to the furnace it will reset and run the blower on startup. check the tube connecting the vacuum switch to the induced draft motor. maybe a leak. good luck
Posted on Nov 24, 2009
SOURCE: set opt(chan)
This problem occurs because of wireless channel type issue.
Make sure your wifi router mode enable B+G+N .
Also change channel type to 3 or 6 or 11 these channel type is best for wifi.
Then save settings and restart router.
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings Then channel type change to 3 or 6 or 11 1 by 1 set which gives best result you need to save settings and restart router every time for change take effect.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jun 09, 2010
How do i opt out of euro traveler
Do you mean the Vodaphone tariff?
Vodaphone says:
You can opt out of Vodafone EuroTraveller at any time by dialling 5555 or texting REMOVE to 40506. On the day you opt out, Vodafone EuroTraveller will be removed from your account immediately. You'll be billed the daily charge if you use your phone in the Europe Zone on that day.
Jun 23, 2014 | Computers & Internet
I want to java update
try this code
type *#6984125*#
select opt 4----->internal
type *#9072641*#
select opt 6----->storage setting
then opt 3 update java db
done
Sep 28, 2010 | Samsung Star GT-S5233 Cell Phone
CM67ng will not turn heating off
Are you running some type of program on the tstat??
Jul 06, 2017 | Honeywell Programmable Thermostat Heater
Lenovo Thinkcentre Problem?
Try setting the time and date in the bios, also check to see if the jumper setting on the back of the drive is set to master and reinsert it to 1st opt.
Feb 10, 2010 | Lenovo ThinkCentre M57 Desktop - Intel...
Cannot find voice mail password
In such case u need to reset ur mailbox password.
F983 password is 1020000 if u have three digit extensions.
1.Select opt of M.Box
2. Select opt of chng.
3. Enter ur mailbox number which will ur extension number( most of the time.)
4.Select opt. of password.
5. Select opt of re-set.
Ur password has been changed now and its set to default which is "0000".
After that it will prompt for must change the password where u can set the password as per ur wish..
Jul 06, 2009 | NorStar T7316E Corded Phone
UF-585 (AU) OPT is showing on the screen...can't send or rec faxe
Open the toner door
press
function
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
set
set
wait for machine to reboot
Jan 29, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
G on My Screen
1. That symbol-G is the symbol that is seen when you opt for GPRS in your cell phone.
2. You can remove that by following these steps.
go to settings- go to connectivity settings--go to packet data--packet data connection--opt for when needed to get rid of that G symbol.
Jan 07, 2009 | Nokia 2610 Cellular Phone
Honeywell CM67ng thermostat not working. Have tried various programmes but still seems to have mind of its own. Can we replace with something else?
The cm67ng has a feature which attempts to get the temperature to the desired point before the actual time you set. In reality this "feature" just makes the device turn on and off randomly in a really bemusing fashion. You can turn this off with the following:
1, Set timer mode to "OFF"
2, Hold down "Info i" and press "prog 3" and "prog 4" together. Display Should show a spanner in the left hand corner.
3, press "prog 2"
4, repeated press "clock +" till the characters in the display after the colon read "OP" (the number before the colon seems to vary with model).
5, Press the "temp down" button. The 1 in the right hand of the display should become a 0.
6, Press the "info i" button to save your changes.
7, Switch the mode back to auto, the timer should now behave normally.
You should note that a number of other parameters can be changed in this service mode. Some of which could probably do bad things to your central heating system if set incorrectly.. So this is at your own risk! Either way it's best to read the installation manual before attempting to change anything:
http://content.honeywell.com/UK/homes/Technical/CM/cm67i.pdf
Nov 09, 2008 | Heating & Cooling
No sound output
Mar 18, 2008 | Audio Players & Recorders
Heating & Cooling Logo
41 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
