Question about Mitsubishi WS-55805 55" Rear Projection Television
To fix or not
I am getting sound. However, I am not getting any form of a picture. I can not get the menu to appear. Any suggestions?
    President:
  • 3,130 Answers
Could be many things but if your not a tech you shopuld call a pro to assist you with this repair, as a TV set is no where someone should be tinkering in. If you know electronics, the first thing to check on if you hqave high voltage otr not . If you fo check with a scop the PIP board as they go bad all the time in this set. Also capacitors in the sweep supply goes bad all the time also/ good Luck
Posted on Jul 31, 2006
SOURCE:
Problem is no picture.
Does the menu appear? If so try a factory reset, if not contact lg for repair
Nov 20, 2013 | LG 60PG3000 60 in. HD-Ready Plasma TV
How to get Photos From memory card to computer
  1. Hi
  2. Plug your Samsung mobile phone's USB flash cable into the phone and into the computer's 2.0 USB port outlet. When the computer detects a USB connection, a notification screen will appear in the lower right corner of the screen, above the task bar. The phone's software driver will be automatically installed to your computer's hard drive.
  1. Import your pictures to your computer. Click on "Import Pictures" when the "AutoPlay" dialog window pops up. Close the "AutoPlay" window to configure the import settings.
  2. Choose a gallery title for the pictures you are importing. When the blank data form appears in the bottom right corner of the screen, type a name for your gallery in the data form. Click on the "Import" button to begin the downloading process.
  3. Remove the Samsung USB flash cable from the computer and then from the mobile phone. Click on the "Start" menu icon, then select the "Pictures" tab folder. Your newly imported pictures should be stored in this folder. Please Rate this solution. Regards.
Nov 12, 2010 | Samsung Cell Phones
Using the usb cable how can i get the pictures to my computer?
connect the camera's usb interface with your computer. Set the camera's menu dial to the lightening bolt, turn on the camera
Look see in the my computer menu on the desktop
Removable media should appear in drive form. open that up and look see in the folders for your pictures.
Block copy and paste in you designated folder on the C drive
Aug 26, 2010 | Sony Cyber-Shot DSC-P92 Digital Camera
When i turn the tv on i get sound but just a black screen
Try pressing the menu button on the remote to see if the menu comes up.
If it does it's possible the light and colour have been turned right down, find the option on the menu and turn it up.
Also check no cables are unplugged at the back of the tv, picture is usually yellow make sure it's in tight. Check other end as well so sky box or DVD player.
If you're using an AV port on your tv try using a different one, so switch form AV1 to AV2.
Jul 23, 2009 | Proscan 19LA25Q 19 in. LCD Television
Toshiba Regza sound but no picture
I had the same problem last night - sound but no picture form any of the inputs - DVD, VCR, FIOS or antenna. I could still see the TV menu. If you go to the TV menu - you can go to the settings (far right top), from there you can choose to restore factory settings, usually needs a code - 0000 (if you did not choose a different one), select yes when prompted if you want to restore factory defaults. This brought my picture back. I lost all of my picture preferences i had set - but at least I got a picture! I hope this helps!!
Marilyn
May 30, 2008 | Toshiba REGZA 47HL167 TV
Sony TV snow at startup
Bad solder connection in tuner.....replace with new or rebuild.
............................T.
Mar 09, 2008 | Televison & Video
Black screen when in picture mode cant take pictures
PER007 in solution #3 is correct.
  • Follow the URL: http://www.nikonusa.com/email_images/nikonusa/service_advisory/launch_all.html
  • Fill out the form
  • Mail in your camera if it's listed
  • Receive your working unit free of charge
I had the same problem with my CoolPix5400 and this resolved the issue.
Nov 11, 2007 | Nikon Coolpix 5400 Digital Camera
No pic or sound
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Oct 22, 2007 | Philips Magnavox 42MF521D/37 Television
No sound
go to you menu settings and be sure speakers are turned on and are not set to external,if this does'nt fix remove your dish input to see if you have noise comming through with no picture only snow, if yes the dish is the problem.
Sep 08, 2007 | RCA D52W19 52" Rear Projection Television
Mitsubishi WS-55805 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
