Question about Irons
How to put water in Sunbeam Steam Valet
I cannot figure how to place water in the steamer.
4 Suggested Answers
jaylex
  • 417 Answers
SOURCE: Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Posted on Feb 11, 2008
SOURCE: Steam Fast SP-660 Iron will not steam with distilled water.
Steamfast Brand SP-660 steam press
Mfg by Top Innovations
Phone 1-800-711-6617
Posted on Dec 09, 2008
  • 3 Answers
SOURCE: Steam Press sp-660 will not steam with distilled water
My Steam Press (SP-660) the Mercury switch went out. An electrician looked at it to find out the problem. The question is now, how to get a mercury switch since most hardware stores do not carry them any more. Due to certain state regulations.
Posted on Nov 29, 2010
I want to see the wiring diagram for a sunbeam steam Iron
Go to wow.com and search for steamer wiring diagram.
Mar 27, 2015 | Sunbeam Irons
How do I put water in the Sunbeam Steam Iron #GCSBBV-200
If the GCSBBV-200 is similar to other Sunbeam steam irons, fill the iron when it is cool and unplugged. With the ironing surface flat on the sole plate, set the Steam dial to dry and the Fabric Select dial to Min. Then use an easy-pour measuring cup to pour water into the opening at the top front of the iron. Make sure not to fill past the maximum fill level. (Tip the iron up as if you were resting it between passes with the iron to check the level.)
I hope this helps.
(Sunbeam has the manual for the GCSBBC-395 on their support site: http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/garment-care/other/garment-care-other-manual.html . The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-sunbeam-Site/Sites-sunbeam-Library/default/v1425126445413/documents/instruction-manuals/160253.PDF . Check how similar your iron is to the newer models.)
Mar 01, 2015 | Sunbeam Irons
Need manual for sunbeam steam valet 10079
http://pdfretriever.com/frame_somemanuals.php?ID=92334&lg=E&src=28
Dec 10, 2013 | Irons
How to flush brown fluid water from Sunbeam Steam Master
Run a tank of 50/50 water and white vinegar through the steam cycly. Run two or three more tanks of plain water. This should clean it out safely.
Mar 13, 2013 | Sunbeam 4214 Iron
Sunbeam steam valet instructions
How to fill your Sunbeam Steam Valet
Here is how you fill your Steam Valet. Press the small button on the back of the handle and pull bottom of handle apart from the top half of steam valet. Then take off the white cap on the inside of the handle and fill with water to top. Place cap back onto the opening and slide handle back and click in place. Plug in and you're ready to steam within a few minutes. If it spits out water let heat up a little longer if that doesn't stop it then tie a thin cloth over the top part where steam comes out to keep the water from spitting out onto your fabric. Hope these instructions are clear enough. More questions about this iron go to www.manualslib.com.
Feb 29, 2012 | Sunbeam Irons
My rowewnta steamer is not producing steam and I have lost the manual
if u have heat and no steam its prolly plugged with salt/calcium deposits, putting white vinager in the water chamber might clear the clog
May 25, 2011 | Rowenta Commercial Garment Steamer - White
We own a SmartLiving Steam Mop, and have really enjoyed it. It suddenly quit steaming. We tried putting vinegar through it in case it was hard water deposits, but no luck. Any siggestions?
yep i have one,,,,,dont use vinegar,,,thats good on chips? no good in steam mops!
go get yourself some kettel cleaner ,,,the stuff for cleaning the lime scale off the inside of your kettel,,,,mix it up in a jug with warm water,,,,and tip that in your steamer,,,dont breath the fumes?
this will clean out any lime scale for you,,,next time fill it with rain water,,,,there is no lime scale in rain water?
Nov 27, 2010 | Hamilton Beach Steam Excel 14770 Iron
Find water demineraliser for use in a steam iron
Any undersink reverse osmosis system will give you the low tds high quality water needed for the steamer. Make sure the ro system does not have a mineral cartridge to add back calcium that it removes from water.
Feb 26, 2010 | Sunbeam Irons
Model #4214 iron doesn't work properly
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Jan 16, 2009 | Sunbeam 4214 Iron
Irons Logo
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
