Question about Dryers
Sock fell down dryer vent how do i take out - Dryers
SOURCE: sock in lint collector slot
If you turn it around there is a long black piece that you can unscrew after taking off the plate cover,,,,only unscrew the bottom and pull lightly, you should be able to see the sock among a bunch of dirt!!!! Dryer started right up!! Thank goodness!
Posted on May 23, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Sock fell down lint vent and daughter turned on dryer
Turn off you power to the dryer and then,
You could run a coat hanger straightened out with a hook bent on the end of it into the lint vent at try to hook the sock.
But probably you will have to remove the back to follow the lint vent.
You may try to remove the vent hose and run the straightened coat hanger in there to try and remove the sock.
Hope this helps
Posted on Oct 01, 2009
woobie dog
  • 1273 Answers
SOURCE: a sock fell in the vent of my whirlpool dryer
If you mean the lint trap, try this: Unplug the dryer. With a dryer brush (~$10.00 @ Lowe's/similar), bend to approximate the curvature of your cavity and try to retrieve. If this doesn't work, slide/scoot the dryer out and remove the venting duct. Carry outside and dump. If no sock there, look into the dryer exhaust (where the duct connects). Use the brush again to retrieve said sock (and generally clean as you go, as it never hurts). Also look at your vent where your dryer exhaust passes through the wall, clean as you go..... This should get you back up and running.
Regards, --W/D--
Posted on Jul 17, 2009
vostendorp
  • 347 Answers
SOURCE: Small toy accidently fell down dryer vent. What
To get to where the toy fell on this unit is a little involved. Unplug unit. take out the lint filter and gently turn the machine upside down hoping the object will fall out if not you will need to take the back off the unit and loosen or remove the blower chute to get at the blower wheel and your missplaced object
Good luck...
Posted on Aug 11, 2010
SOURCE: while cleaning out my lint
Typically you can feed a vacuum hose down into the lint trap area and **** the sock out.
Posted on Oct 12, 2010
How do I remove a sock that fell through the lint trap?
How To Fix Dryer Lint Trap Problems (Removing Items That ...
? 5:32
https://www.youtube.com/watch?v=Fcw1aPqGiSI
Feb 4, 2015 - Uploaded by UKaToNeN
Have you ever had something fall down into the lint trap on your dryer? It`s happened to more folks than you ...
how do I get sock out of lint filter shoot of electric dryer ...
www.shopyourway.com > Manage My Life > Questions
I'm sorry to hear that a sock fell into your lint screen chute and I would like to assist you. Be sure to unplug the dryer prior to servicing it! Do not run the dryer until you are able to remove the sock! There are two ways to do this.
Nov 29, 2015 | Electrolux Dryers
I have a problem with my brand new Samsung dryer. I have been looking for a detailed schematic. see below
Go to www.repairclinic.com and enter the model number of your dryer. You will be presented with a list of common replacement parts and, more importantly, a video showing the disassembly procedure for a typical Samsung dryer. This should give you some idea of how to retrieve the sock.
Feb 28, 2015 | Samsung Dryers
I ran the dryer without the lint screen and am now 'missing' some socks. The dryer makes a rumbling noise. How do I get the socks out and did I break something
you better inspect inside the exhaust vent tubes for the socks. You did not break anything but they might start on fire later. You to take off the back of the dryer to take the vents apart.
Feb 17, 2015 | Samsung DV330AE DV330 Large Capacity...
Ihave a whirlpool gas dryer and my wife droped a sock into the hole where the filter is. Made some noise and then seemed to work just fine. Where did the sock go and shoukd I be worried? Thank you
the sock ended up down below at the bottom where the vent fan blows, I would remove the back of the machine,, remove the vent housing inside, and you'll see the fan which runs off the back of the motor,, ( and probably the sock) and remove it , and any other debris thats collected there, Its a fairly simple task
May 26, 2011 | Whirlpool CGE2791KQ Gas Commercial Dryer
Takes extra time to dry the clothes.
You may need to clean out your lint trap. Not just the part that you pull out. I'm talking about the entire tunnel. Even though we empty the lint trap regularly there's a lot that gets left behind and over time can become a fire hazard. Your arms and hands cannot reach everywhere in there. For this you can attach an old sock or rag to a coat hanger that has been opened up. Go down in there a couple of times with it. You'll be surprised at how much stuff comes out. To further help this problem you can also pull dryer out and check that the vent hose in back is clear and free of debris. Cleaning the trap screen (the part you pull out to empty the lint) with HOT water occasionally will also clear residue that has built up from using dryer sheets. Over time that residue will make those tiny screen holes smaller & smaller & smaller. All of this can affect your dryer's performance.
I hope this info was helpful to you. Good luck!
Jan 29, 2010 | Whirlpool GEW9250 Electric Dryer
Hope this helps
Sep 30, 2009 | Whirlpool LEQ8000JQ Electric Dryer
A sock fell in the vent of my whirlpool dryer
Regards, --W/D--
Jul 17, 2009 | Whirlpool LEQ8000JQ Electric Dryer
A sock fell into the lint resevoir; how do I remove it?
If your dryer is the model you have this listed under (lint filter on the top panel), then retrieving something stuck in the vent is pretty simple. Just follow these steps:
1. Unplug the dryer and remove the back panel. The dryer exhaust vent is located on the left hand side (as viewed from the rear).
2. Remove the screws that hold the vent in place and remove. NOTE: Make sure you remove the two screws located on the top panel as well. The entire exhaust vent will come out.
If this is not how your dryer is configured, please post back with your correct model number. If you have any questions, please let me know. I hope this helps you.
Mar 31, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Sock in lint collector slot
Take a hanger Metal one, stick it down there and twist tell you get a good grab on the sock and pull it out. The other way is to open the back up and get in there. The machine will not work at all cause it can not exhaust
Feb 09, 2009 | Kenmore 62622 Electric Dryer
Dryers Logo
852 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
