Question about BenQ FP547 15" LCD Monitor
Lcd monitor benq fp 547 power supply diagrame
SOURCE: Benq T701 LCD monitor
2SC5707 x4 (lamp driver transistor)....
Posted on Oct 26, 2007
alxz
  • 89 Answers
SOURCE: BenQ FP731 17" LCD Monitor Problem
Its a problem with the inverter. check the 4 transistors, C5707 near the connectors for the backlight. If none are defective, look for the PF751 FUSE. It sure to be busted.You can replace that with another 3A fuse. Remember, you should only replace the fuse if you are certain there are no busted transistors in the inverter board. Otherwise, you now have a refurbished Benq Monitor
Posted on Jan 07, 2008
SOURCE: benq fp737s monitor failure
try resoldering the joints on c826 &c824 near the 4 yellow transformers in the power supply.
hope this helps
kevin numbnuts07
Posted on May 28, 2008
Had the compete dark screen problem. Green/amber power light was coming on and off as expected but no image would appear on the screen.
Found PF751 to be open.
Thnaks for the help people.
Posted on Oct 08, 2008
SOURCE: Benq FP71G LCD Monitor - Can't keep POWER ON / Button Problem?
I had the same problem and found that Q808, Q809 and Q805 had failed and which if left long enough can also cause PF801 to fail. I also replaced all of the electrolytic capacitors during the rebuild as it was only a few dollars to do so.
Although in my case Q815, Q816 and Q812 were fine I suspect that they may also fail in time.
Here are the parts which should be available at most electronic stores or online.
Q808 & Q809 - 2SC5707
Q805 - IRFU9024N
PF801 - 3 AMP PICO FUSE
Posted on Jan 22, 2009
Benq lcd fp0537s on for just 2 second
There are one or two capacitors in the power supply that open," leaving a slight puff at the top" in some cases.
Mar 16, 2012 | BenQ FP92W LCD Monitor
Trying to purchase a power adaptor for benq fp781 can only find one compatable for fp 791 would this work on a fp 781 monitor ??
On the screen itself, where it plugs in, it should give you a voltage rating, and a line with a C encompassing a circle. Make sure that these two things match up between the two screens, they should, but at the same time, there is the possibility that they don't. Also, make sure the plug is the right size. Yes, it should work, but I would just take the extra precautions listed above to prevent frying your monitor.
I hope this helps!
May 04, 2011 | BenQ FP781 17 in. Flat Panel LCD Monitor
Hello,mi power supply from BenQ G2420HD 24 inch LCD Monitor is dead,i want order the new one,i need contakt with you,mi tel. num. is 0834375914,0834136011,i be waithing for your call,thanks!!!
I'm sorry, but I can't call you. The monitor uses the same power supply as most computers and can be picked up at your local computer store. Hope this helps =]
Mar 03, 2011 | BenQ G2420HD 24" LCD Monitor
I cant get correct resolution with windows 7 no apparent drivers of FP 222w under windows 7 (22 inch monitor)
You normally don't need any drivers for LCD monitors. The resolution should be 1440><900 or higher.
Samir
Feb 28, 2011 | BenQ FP222W LCD Monitor
Benq 567s lcd monitor does not power up. Switch led blinks but goes dead. Tried replacing capacitor 450v 82uf with 400v 100 uf but did not work. please help.
That cap is for the Primary power supply switching circuits. How is the DC secondary side, no blown fuse, shorted transistors in the inverter circuits? Pictures will help, budmrtn@aol.com
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
It may have the same bd as DELL since BenQ makes monitors for DELL and HP.
May 21, 2010 | BenQ FP71G 17" LCD Monitor
Power light on no screen shown
unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
Nov 15, 2009 | BenQ FP737S-D 17" LCD Monitor
BenQ FP91G+ 19" LCD Monitor black screen
Possibly either the backlight lamp or its associated power supply has failed. Power buttons (mostly LEDs) have constant availability of low voltage (for some other circuits too) otherwise they wouldn't 'wake up' on command from a computer as some do.
The blackout could also be due to a failed main power supply so the incoming video is no longer being processed.
Nov 01, 2008 | BenQ FP91G+ 19" LCD Monitor
Benq Q7S3
Video Graphics Card in Computer "BAD" !
Nov 15, 2017 | BenQ FP567s 15" LCD Monitor
Benq screen shuts down when pc is plugged in
If it's a 71g and not 71g+ resolder transistors 2sc5707 on invertor board along with grey condensers and inverter transformer.This should solve the problem if it was display shutting off with power led remaining on.Otherwise check power section.
Feb 24, 2008 | BenQ FP71G 17" LCD Monitor
BenQ lcb monitor
Monitor blanks out due to problems with internal power supply, have a quilified technician take a look at it, BenQ LCD monitors have 3 years warranty
Feb 11, 2007 | BenQ FP71E 17" LCD Monitor
BenQ FP547 15" LCD Monitor Logo
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
