Question about Measuring Tools & Sensors
Can you give me instructions how to read the stanley 77-030
How can I calibrate a FatMax digital level?
Mark, Automatic calibration, check the little pockets on case instructions inside, the instructions show how.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Stanley FatMax Digital level mp4
Stanley fatmax digital level instructions Measuring Tools Measuring Tools
STANLEY HAND TOOLS Measuring Leveling Layout Levels Stanley FatMax Digital...
http://www.microprecision.com/equipment/STANLEY-CALIBRATION.html
Mar 04, 2016 | Measuring Tools & Sensors
How do I set the timer?
Google (Stanley)(DR1212)(instructions) without the parens, of course
This approach got me instructions for a Stanley model 28442
Dec 21, 2015 | Stanley Hardware & Accessories
HOW TO LOAD BRADS IN STANLEY TRE500
Please download the instruction sheet from the following link which explains how to load the brads. Make sure you have the correct size of brads mentioned at the bottom of the instruction sheet.
TRE500 Sharpshooter Stapler Instruction Manual
Aug 13, 2014 | Electric Stanley Tre500 Staple Gun /...
What do all the numbers on a framing square mean and how do read them?
The numbers on the side of a framing square are used for many things. The small leg allows you to quickly lay out a wall on16" centers. The other rows of numbers help you figure the correct sizes to cut for hip roofs (roofs that have slope on all four sides.)You can get an instruction Manual from Stanley or it may be availabile on the net. Google (framing square instructions)
Aug 05, 2013 | Stanley Homeowner Carpenters Framing...
Lost the manual to a stanley outdoor 6 plug timer with ground stake.
1) Copy following link to help identify Stanley (Westinghouse) timer, and download possible instructions:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
2) Add comment and describe timer in detail
Dec 09, 2012 | Hardware & Accessories
Can I charge a Polaris battery at 2 amps to keep it charged?
use a small solar panel ,cheap and it will keep the battery up
Nov 09, 2011 | Stanley Black & Decker Stanley Bc1509 15...
I was looking at buying a stanley lock S836-171. Do you have to use the key every time you use the gate? Or is the key just to lock the gate when on vacation?
Hi maraleequanb... I do not know this lock personally but according to what I am reading you do not have to use the key every time, only if you want to lock it while your away. I have found this quote about it on a website along with some others you might be interesting in reading . Please take time to rate me thumbs up **************************************************************************************************************** "4.0 out of 5 stars Great Gate Latch - Installation Instructions lacking, May 4, 2010 By M. D. Heidenreich "DIYWhenICan" (Dayton, OH USA) - See all my reviews
(REAL NAME) Amazon Verified Purchase(What's this?) This review is from: Stanley Lockable Gate Latch With Dual Access (S836-171) [Misc.] I installed this gate on a 6' tall by 4' wide cedar gate latching to another smaller gate section. The smaller one has the post the larger side has the catch. The ability to push a button and open from the inside was the key selling point for me, being able to lock it is secondary but still will be nice when on vacation. We had one similar but we had to drill a hole and run a string and half the time manually latch the gate. This latch solved that problem completely. Gate now shuts and latches without a hitch. Now to the installation instructions: First - DO NOT USE the little grey PVC tube unless you have a hollow vinyl post - would of been nice if this was in bold print somewhere in the instructions. I tried to use it on the wood gate and spent 45 minutes on it before I finally found the teeny tiny writing saying not to use unless on vinyl. Second: I typically do well with pics. in instructions rather than a bunch of drawn out written explanations - not so with these instructions. From the look and my experience you could install on any gate set up so chances are you can make it work. I read other reviews complaining about the plastic and was prepared for that but was pleasently surprised with the solid feel and sturdy construction - time will tell but if it lasts two years, for the money, I'd say it's money well spent. My 4 stars are due to the instructions not the product. "
More quotes and pictures of the lock.
http://www.amazon.com/Stanley-Lockable-Latch-Access-S836-171/product-reviews/B002L2R7K6
Sep 12, 2011 | Stanley Garden
Measuring Tools & Sensors Logo
261 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
