Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
(Work this one out) My access point works but I have never been able to set security settings on interrogate it.
Out of the box I connected the access point as per instructions and powered it up. Connected my laptop to the wired network and inserted the setup wizard disk. The wizard couldn't see the access point.
After much restarting, reseting, wizarding and searching on the network I gave up and tried to reconnect to my other home WIFI network only to find the access point is working perfectly as an unsecured access point which is fab.
The problem now is I need to setup the security on it to keep the network secure, I don's seem to be able to get onto the access point admin page at all. It is unrecognised via the wired or wireless networks.
Anyone have any ideas?
  • ronjonsmith Oct 22, 2008
    How do I find the IP address of the access point. It is connected to an existing network and can only guess it has asked the TCP/IP (think thats right) thingy for the next free IP address as my laptop would when I connect it each time. I have tried 192.168.0.1 to no avail and 192.168.1.1 just opens up a google search for the numbers.
    As you can guess I can work out the basics but other than that I'm stumped.
    OK tried that and it keeps timing out, whoever I get to try to do it from different machines. I take it I can connect to this access point wirelessly and perform these functions.
    It is worth mentioning the DHCP server on this network is at 172.18.110.1 the DNS server at 172.18.110.220 and the defauly gateway for wireless connection is at 172.18.110.250.
    Still cannot see it whatever I try and do. any more ideas? Will try anything at this point.
  • 2,794 Answers
First of all the disk isn't needed. Go into internet explorer and type in the ip address of the gateway. A user id screen will appear. By default the user id is admin, the password it linksys. Select Wireless for the links at the top of the router screen. Select security. You will see a screen for generating pass phrases. Once that is enabled a WEP key or whatever security key you decide to use will be enabled.
Posted on Oct 22, 2008
  • Tim Babcock
    Tim Babcock Oct 22, 2008
    Goto networks in the control panel.  Look at your network connections.  Choose the connected one.  Move the mouse over to the connect and select properties.  Press the status button and check the gateway address settings.
    That is the IP address to your router that you can type into internet explorer.
  • Tim Babcock
    Type in 172.18.110.1 from internet explorer using a computer wired to the router.  By default wireless admin isn't allowed.
    Then you can setup you wep security using the previous threads I left you.
  • 488 Answers
Try typing 192.168.1.1 in your internet browser..the login and password are usually admin  and admin respectively.you can then configure further settings without using any cd etc.hope it helps!
How do you Connect asus laptop to portable hotspot
On the right hand side of the taskbar you should see what appears to be an icon like signal bars on a mobile phone. Clicking on this will open a box with available hotspots or access points. Click the one you wish to join and then click connect. After an interrogation of the hotspot it will either connect automatically if there is no security required or a dialogue box will appear asking for the password or network key. This is case sensitive so enter it exactly as it appears on the hotspots sticker or as supplied by the hotspot owner. If you enter the correct key it will then connect and you will have access to all the features provided by that hotspot. Most hotspots and personal access point devices also have a button that you can press to initiate a connection without knowing the password.
Sep 25, 2014 | ASUS Computers & Internet
Check connections
The connection of the USB cable
Verify that the USB cable is connected between your Brother machine and your PC.
The connection of the LAN cable (if applicable)
Verify that the network cable is connected between your Brother machine and access point and the machine is powered on.
1.Access point/router
2.Wired Network machine (your machine)
3.Wireless capable computer connected to the access point/router
4.Wired computer connected to the access point/router
The connection of the Wireless network
2.Wireless Network machine (your machine)
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother MFC 7840W Printer
the error code means; "Cannot connect to the access point for an unknown reason"
Basically it means you are going to need to reconfigure the access point settings
Make sure the security key in the connection settings matches that of the access point. If this error code occurs even after connections are allowed, the wireless signals may be too weak at your location. Try moving closer to your access point, and make sure there are no people, objects, or other obstacles between the system and the access point. When connecting to an Internet hot-spot for which a proprietary security key has been set, make sure you configure your connection
setting.
if this does not work its a possibility that the access point has reached a maximum number of connections and is unable to connect to your device. Try again later to see if it will allow you to connect.
Oct 16, 2010 | Nintendo DSi Blue Console
I cannot connect my dsi to the internet. I try all I can but it doesnt work. How do I get it to connect?
You must either have broadband internet access and a wireless router or you can connect your Nintendo DSi at a hotspot, such as a library or coffee shop that offers internet access. Make sure you are in a location mentioned above before going to step 2.
Turn on your Nintendo DSi and click on the wrench icon. This will take you to the system settings.
Go to page 3 and select "Internet".
Click "Connection Settings".
Click "None" to the right of "Connection 1".
Click "Search for an Access Point".
Look for an access point that has a gold lock that is unlocked. Select that access point and your Nintendo DSi should now be connected.
If you are planning on playing games online with your Nintendo DSi and have WPA security, you will have to set your router to WEP security.
To do this, get back to the "Connection Settings" screen mentioned in step 4.
Click "Advanced Setup".
Click any button that says "none".
Mar 05, 2010 | Nintendo DSi Blue Console
How do I have the printer recognize the router so I can print from my laptop from another room please? I have a C27250
Make a wireless connection between an HP all-in-one with built-in wireless networking capability and a functional wireless network with an access point (router) that is SecureEZSetup enabled.
Connecting the unit to the computer
  1. Activate SecureEzSetup on the access point (router). Usually this is accomplished by pressing a button on the access point. Refer to the router or access point documentation for specific instructions.
  2. Press the Setup button on the all-in-one.
  3. Press the arrow buttons until Network displays and then press OK . The Network menu displays.
  4. Press the arrow buttons until Wireless Setup Wizard displays and then press OK .
  5. Follow the instructions in the Wireless Setup Wizard.
  6. After the all-in-one connects to the network, install the product software on the computer.
Regards,
Rizwan
Jan 19, 2010 | HP Photosmart C7250 All-In-One Thermal...
How to initially configure the access point
Should work right out of the box. Are you asking what type security you should set up?
There is password security, turn off the broadcast security, MAC address security and others.
May I suggest Network Magic to help you set up and maintain your network.
I use the paid pro version and love it.
Get it free - google Network Magic
Oct 19, 2009 | ASUS WL-330GE 802.11b/g Wireless Access...
Connected it to a network but it will not print
enable file and printer sharing from the network properties on the other computers. on the first one, make the printer a shared printer and try to install in into the other computers as a network printer
Jul 14, 2009 | Office Equipment & Supplies
Cant get internet
First, make sure you have wireless internet, than go to system settings. than internet.
For AOSS: tap connection settings tap a connection labeled none tap AOSS  press the AOSS button on the access point until the AOSS light flashes tap ok to preform a connection test
For access point: tap connection settings tap a connection labeled none tap search for an access point tap the desired access point (note: if you are using a secure access point, enter the key and tap ok) tap ok tap ok to preform an connection test
Apr 23, 2009 | Nintendo DSi White Console
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
193 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
