Question about Cuisinart Toaster Ovens
Can you turn off or change the beeps on cuisinart toaster oven broiler 40?
Great product; five beeps when toasting is done are ear-piercing. can this be disabled, lowered in volume, or lowered in pitch?
SOURCE: Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
I have the same problem. It is due to a bad relay switch in the toaster. I have found that for now, my toaster will work if I leave it on the "TOAST" function rather than "OFF" overnight. I think it lets some current or voltage hit the relay and encourages it to work.
I will try to replace the relay and post a "how to" on that when it is done.
May all of your toasting be succesful.
Posted on Jan 21, 2008
  • 5 Answers
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Posted on Apr 07, 2008
  • 5 Answers
SOURCE: broiler element
Its an on or off thing. No way to control the flow of electricity.
The elements are bigger than necessary to heat the unit quickly, the problem you have is a bad thing with food that burns easily but a good thing that makes these units come up to temp so quickly after turning on.
Unfortunately the only thing you can do is put more space between the element and your food or use aluminum foil (not suggested, its too close to the burners).
Eventually the contacks will fail (unless you are one of the lucky ones).
Good Luck
Posted on May 30, 2008
  • 1011 Answers
SOURCE: I need a manual for my toaster oven broiler
dear,
here is the manual..
check this link , scroll down and save the manual which is in pdf form..
http://www.cookware.com/Black-and-Decker-TRO700S-BND1070.html
regards,
dont forget to rate.. its hopefully work
Posted on Aug 16, 2008
SOURCE: warning tone?
Have you tried turning the function button to off? This has worked for mine.
Posted on Sep 15, 2008
We have a new cuisinart classic toaster oven broiler. It burns everything I try to bake . Never had this problem with others .
Hello, Joy -
Since your toaster oven broiler is new, after you check the warranty information in the user manual, contact the Cuisinart company and find out what you need to do to obtain a new replacement.
Note: You may need to provide a copy of the sales receipt for the toaster oven broiler in order to obtain a replacement.
See the information from Cuisinart here (Product Inquiries):
https://www.cuisinart.com/support#us_tab
Best wishes.
Mar 19, 2018 | Cuisinart Toaster Ovens
How do i get a manual for a Black& Decker toaster Conf. oven?
Free Black & Decker Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Kitchen Appliance Black & Decker
Products 1 - 50 of 75 - Black & Decker Convection Countertop Oven User Manual ...Black & Decker Use and Care Manual Toast-R-Oven Asador Broiler CTO600.
Free Black & Decker Toaster User Manuals ' ManualsOnline ...
Products 1 - 50 of 81 - Black & Decker Owner's Manual Toaster MGD100. Pages: 0 Saves: 0 ... Black & Decker Toaster Oven Use and Care Book. Pages: 0 Saves: ...
Free Black & Decker Convection Oven User Manuals ...
Feb 08, 2016 | Toaster Ovens
Why does Cuisinart TOB-40 produce steam and condensation on the glass door when toasting?
The bake/toast compartment is almost air-tight, creating an adequate seal to produce steam/moisture when the heat is applied to the water content of the food placed inside.
Mar 23, 2011 | Cuisinart Toaster Ovens
Cuisnart Toaster Oven Broiler TOB-165 Element
there not replaceable . metal straps are welded to the ends to make the electral connections . thats why there are no elements for this oven , sorry factory-store-home-dump AS FAST AS WE CAN
Jan 20, 2009 | Cuisinart TOB-165 1500 Watts Toaster Oven...
Cuisinart Toaster Oven Broiler Not working properly
This is not a defect - it is just how the unit operates. You can set it to Broil, and the top element should not come on. Make sure the wire rack is turned upside down so that it curves inward and try one more time.
-Tha Mp3 Doctor
Jan 04, 2009 | Cuisinart TOB30BW Toaster Oven with...
Cuisinart: toaster part of toaser broiler oven does not work
Definitely a defect - return to store if possible, or call Cuisinart - it has a 3-year warranty.
-Tha Mp3 Doctor
Dec 24, 2008 | Cuisinart TOB30BW Toaster Oven with...
Warning tone?
Aug 18, 2008 | Cuisinart TOB-30 Toaster Oven with...
Dec 26, 2007 | Cuisinart TOB-30 Toaster Oven with...
Toaster Ovens Logo
1,739 people viewed this question
Top Cuisinart Toaster Ovens Experts
D. E. Hev
Lawrence Oravetz
ray gallant
Are you a Cuisinart Toaster Oven Expert? Answer questions, earn points and help others
