Question about Kitchen Ranges
Range hood model# H72542130110 installation tnstructions
What do I need to do to change the air flow from coming out back in the kitchen
SOURCE: Light bulb socket replacement for a really old Air Fare kitchen hood
The chances are that your range hood light socket was fully impacted with grease from cooking. Shut the power off to the range hood or, in many applications, simply unplug the power cord. Remove the socket. Get a spray can of electrical parts cleaner and saturate the socket through the tiny pin holes you may see at back of socket. shake out all of the cleaner fluid. Somehow hang the socket up with bulb base facing up all night. Hook it up. That might solve the problem.
It worked for me very recently on a 20 year old range hood.
DON'T USE ANYTHING OTHER THAN AN OFFICIAL ELECTRICAL PARTS CLCEANER. Most hardware stores, etc., have it.
Posted on Oct 24, 2008
SOURCE: Kitchen Hood Broan Nutone RM5200 Hood won't pull air.
There is definetly somthing blocking the air from escaping, either the duct is blocked or the installer did not remove the metal plate which opens the fan up for it to be able to evacuate.
Posted on Feb 08, 2009
  • 25 Answers
SOURCE: kitchen range random chatter noise
could be clock motor or fan motor keeps running.
Posted on Feb 12, 2009
  • 24 Answers
SOURCE: Kitchen hood
Yes you can , usually they got hole on top too , just make sure when its done that the air is going out and it will be fine . I
Posted on Feb 25, 2009
manhandy
  • 146 Answers
SOURCE: JENN AIR RANGE HOOD JXT8136ADS
make sure the fan blade not touching anything. make sure are clean the grease sticking to the blades can make the fan go out of balance
Posted on Jul 05, 2009
Where is thermal fuse on arietta range hood model dk1001mk36
Likely it is mounted near where the hot-air would flow past it. If you don't have the tech info for the unit, follow the wires until you see a small device with two wires running to it... you will need a meter to test for continuity. Thermal Fuse 6930W1A003X it may look something like this one does, though this is for a microwave
May 13, 2016 | Kitchen Ranges
I'm trying to buy a replacement filter. What the part number?
hello. go to searspartsdirect.com
enter your model number
click on model
you will get a schematic showing the parts, and you can order the proper filter there too or at least get the correct part number for your model. joe
Apr 15, 2011 | Frigidaire HD4130 / HD4130W / HD4130Q...
We have question to ask you for Miele Laundry dryer model T4804 C. Our client will install this model in the apartments. They suggest us to connect Dryer vent pipe to the main kitchen exhaust duct of the...
if you use the kitchen exhaust it will ruin the kitchen ducts and forse flow hot air and lint onto the range hood into the kitchen . . stupid advise .. it needs to be ducted directly through the wall to outside using a rain gard the temp can get as high as 47 degrees hot but not too hot it forses air out at a ratio of aprox 15 psi
merry christmas
Dec 22, 2010 | Dryers
Poor burner flame
You have to adjust the air flow shutter on the burner tubes.
Jul 04, 2009 | Tappan MGF500PBW Gas Kitchen Range
GE XL44 propane to natural gas conversion.
your going back to natural from LP??? of so tyhere is no new orifice , but hte "hood" on the end of the bake, needs to be adjusted out"loosened", LP the "hood" is secured snugged down,
Jan 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Installation of down-draft exhaust duct for Jenn-Aire cook top
We're buying a JES9900BAF for an island and found ducting instructions in the installation guide. Go to jennair.com and find the page for your range model. Then click on the "Specs/Literature" tab (it's about 2/3 down the page). The installation guide is a PDF document.
Nov 07, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Kitchen hood
Aug 22, 2007 | Whirlpool (RH3736XLS) Kitchen Hood
Kitchen Ranges Logo
73 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
