Question about ViewSonic Computers & Internet
How to open the back cover of Viewsonic wa1918wm LCD
I am having the problem for blinking power button and black screen appeared.I want to know to check the electrolytic capacitors. But I do not find out the screw for open on the back cover of that set. Please show me how and where to do?
4 Suggested Answers
  • 1684 Answers
SOURCE: My Viewsonic VX724 LCD monitor just died, power
The domed capacitors are the cause of your power issues. If you replace them you should be back going again. If you are interested we do offer a repair service for $30.00 pus return shipping to repair your monitor.
Posted on Oct 11, 2009
budmrtn
  • 11361 Answers
SOURCE: i have a viewsonic v1716w when turn on it works
The power supply caps will be the first thing to check, then also check for steady 5vdc and 12vdc.
The problem can also be in the T-CON board (part of the LCD panel).
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 08, 2010
budmrtn
  • 11361 Answers
SOURCE: Dell 19" LCD E196FPf monitor
Yes,
http://s807.photobucket.com/albums/yy352/budm/Dell%20%20E196FP%20Rev%20A03/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Replacement board: http://www.lcdrepair.us
Posted on Feb 27, 2011
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
Viewsonic monitor vx2035wm goes black with a steady blue light on power button when the monitor is turned off or computer is restarted. Disconnecting it and letting it sit for a minimum of 24 hours makes...
I've been having the same problems with my Viewsonic.I plug it in and the blue light blinks but there's no picture it's just a black screen.I do know if Viewsonic doesn't repair my monitor I'll never buy anything from them again.I have the LCD Viewsonic 22' Vx2235wm monitor.
Does anyone have any idea what could be wrong with mine?I've bought a new video cable & video card but the monitor still does the same thing?Thanks
Oct 29, 2010 | ViewSonic VX2035WM LCD Monitor
The screen is black and power led is blinking green
I will assume that you have already tried it on another PC, just want to narrow down the problem before taking the monitor apart.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Apr 06, 2010 | ViewSonic VP930b 19" LCD Monitor
Green light blinking , no display ,,
look inside for bad caps, see example of failed Viewsonic monitors here: http://s807.photobucket.com/home/budm/allalbums
You should have 5v and 12v in the power supply sections.
Jan 17, 2010 | ViewSonic : 19" Graphics Series Flatpanel...
The Viewsonic LCD VA503b when powered on will only give me a blinking power button. Is it in a "power down" mode and if so how do I unlock it?
Is there an ON/OFF rocker-switch (on the side of the screen), with a '|' label on one side, and an 'O' label on the other side of the rocker?
Can you access the OSD (On Screen Display) and run through the various menu items, to control whether the front switch acts as an "ON/SLEEP" versus "ON/OFF" control?
Jan 04, 2010 | ViewSonic VA503b (Black) 15 inch LCD...
My Viewsonic VX724 LCD monitor just died, power button flashes green and flickers in between flashes, screen is black, any sugesstions? I opened it up and found a couple of capacitors domed and black stuff...
Oct 09, 2009 | ViewSonic VX724 17" LCD Monitor
ViewSonc VX924 LCD Monitor
Check the information at Viewsonic's website regarding their warranty:
http://www.viewsonic.com/support/warranties/limited-warranty/
If you have your proof-of-purchase and it shows the monitor is less than a year old, it would be covered. You would need to follow the procedure on their website to have the unit repaired or replaced, but it would not be your job to try to fix it.
Feb 11, 2009 | ViewSonic VX910 19" LCD Monitor
Viewsonic vp930b-3
MY VP930b has the same problem.
It takes a very long time (5-10 minutes) before it becomes normal.
Aug 04, 2008 | ViewSonic VP920b 19" LCD Monitor
ViewSonic N2700 Blinking power button
replace the power supply, buy it on the internet by looking up the model number on the power supply. I have this tv and it did this until I ordered a new one. it runs hot and has a loud fan.
Jun 14, 2008 | ViewSonic N2700W 27 in. HD-Ready LCD...
Computers & Internet Logo
26 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
